  3. Help! lossing data from camera + IMU tracking
m500
6 Posts 3 Posters 1.5k Views 1 Watching
  • Vũ Văn LongV Offline
    Vũ Văn Long
    Hello, im working with m500 drone. when i starting with ROS, i was calibration camera here. after that m500 cannot display the value of x,y in NED position in QGC (just remain Z value). after reading document i think the SNAV was reset after i ran config command. it's right?
    Then the solution is recalib the Modalai Visio Lib at here? but what is the selection for IMU and tracking camera? Please confirm if i miss anything.
    • James StrawsonJ Offline
      James Strawson
      The M500 should have been sent to you all configured and working. Do you mind stopping the voxl-vision-px4 service and running voxl-test-vision-lib to see if VIO is working? You can use the following commands:
      systemctl stop voxl-vision-px4
      voxl-test-vision-lib -o
      Vũ Văn LongV 1 Reply Last reply
        Vũ Văn Long
        @James-Strawson said in Help! lossing data from camera + IMU tracking:
        hello, i was ran that command and it's have an error.
        • Vũ Văn LongV Vũ Văn Long
          Vũ Văn Long
          @Vũ-Văn-Long and after i run command check the status
            Vũ Văn Long
            Problem Solved. for anyone in the future have similar case just perform factory configuration for VOXL Flight Deck by
            "voxl-configure-vision-px4 -f" and then re-connect to QGC and you will see the miracle.
            M 1 Reply Last reply
              M Offline
              M Offline
              mr TOKI
              @Vũ-Văn-Long wow amazing goodjob
