    Help! lossing data from camera + IMU tracking
    VOXL m500 Reference Drone
    • V
      Vũ Văn Long
      Hello, im working with m500 drone. when i starting with ROS, i was calibration camera here. after that m500 cannot display the value of x,y in NED position in QGC (just remain Z value). after reading document i think the SNAV was reset after i ran config command. it's right?
      Then the solution is recalib the Modalai Visio Lib at here? but what is the selection for IMU and tracking camera? Please confirm if i miss anything.
      • J
        James Strawson ModalAI Team
        The M500 should have been sent to you all configured and working. Do you mind stopping the voxl-vision-px4 service and running voxl-test-vision-lib to see if VIO is working? You can use the following commands:
        systemctl stop voxl-vision-px4
        voxl-test-vision-lib -o
        V 1 Reply Last reply 5 Jan 2021, 00:48 Reply Quote 0
        • V
          Vũ Văn Long @James Strawson
          @James-Strawson said in Help! lossing data from camera + IMU tracking:
          hello, i was ran that command and it's have an error.
          V 1 Reply Last reply 5 Jan 2021, 00:53 Reply Quote 0
          • V
            Vũ Văn Long @Vũ Văn Long
            @Vũ-Văn-Long and after i run command check the status
            • V
              Vũ Văn Long
              Problem Solved. for anyone in the future have similar case just perform factory configuration for VOXL Flight Deck by
              "voxl-configure-vision-px4 -f" and then re-connect to QGC and you will see the miracle.
              M 1 Reply Last reply 5 Jan 2021, 14:45 Reply Quote 1
              • M
                mr TOKI @Vũ Văn Long
                @Vũ-Văn-Long wow amazing goodjob
                1 out of 6
