  3. Making a custom mount for voxl flight deck
3 Posts 2 Posters 755 Views 1 Watching
  • M Offline
    M Offline
    mohammednaveed
    Hi all
    I wanted to miniaturise my voxl flight deck, and want to know what aspects should i consider while i make a new flight deck style mounting for the hardware?
    As per my understanding the stereo cameras need to be set at a specific distance apart.
    However i wanted to know if any parameters need to be changed so the flight core knows where the stereo camera and the tracking camera are?
    Thanks & Regards,
    Mohammed Naveed
      You will need to configure the IMU and tracking sensor relationship following this guide: https://docs.modalai.com/configure-extrinsics/
      Then you will need to calibrate the cameras following this guide: https://docs.modalai.com/calibrate-cameras/
      I would recommend seeing if you can recreate the extrinsics for your existing platform first, and then start to make the mechanical changes.
      • M Offline
        M Offline
        mohammednaveed
        Hi @Chad-Sweet
        Thank you so much!
        Will have try it out first on the flight deck.
        Thanks & Regards,
        Mohammed Naveed
