    Making a custom mount for voxl flight deck
    • M
      mohammednaveed
      Hi all
      I wanted to miniaturise my voxl flight deck, and want to know what aspects should i consider while i make a new flight deck style mounting for the hardware?
      As per my understanding the stereo cameras need to be set at a specific distance apart.
      However i wanted to know if any parameters need to be changed so the flight core knows where the stereo camera and the tracking camera are?
      Thanks & Regards,
      Mohammed Naveed
      • Chad SweetC
        Chad Sweet ModalAI Team
        You will need to configure the IMU and tracking sensor relationship following this guide: https://docs.modalai.com/configure-extrinsics/
        Then you will need to calibrate the cameras following this guide: https://docs.modalai.com/calibrate-cameras/
        I would recommend seeing if you can recreate the extrinsics for your existing platform first, and then start to make the mechanical changes.
        • M
          mohammednaveed
          Hi @Chad-Sweet
          Thank you so much!
          Will have try it out first on the flight deck.
          Thanks & Regards,
          Mohammed Naveed
