Opkg install voxl-streamer
Hi @yu-zhang ,
Regarding speed, we've flown at 8-10 m/s during missions safely. You can experiment and run a simple mission to ensure the behavior is what you expect.
Also keep in mind wind conditions. To keep things safe, we usually fly with maximum wind velocity of 15 mph (or ~7 m/s) with gusts of 5 mph (or ~2 m/s). Always good to have enough speed to overcome current wind conditions when returning to launch.
Hope this helps!
@RichieRich Thanks for the information!
I would test the maximum speed m500 could achieve in a normal condition. So, I will run the mission for this purpose.
By the way, for the motor on m500, I noticed it's the Motor 2216-880KV for 10in props. I also saw there was a 2216-920KV version on Holybro website for s500 frame.
https://shop.holybro.com/spare-parts-s500-v2-kit_p1251.htmlI double check that different the KV rating of a motor will be able to achieve different speeds. In general, the higher KV refers to the faster speed, but the lower in a heavy-lift.
For the defualt 880KV, m500 can achieve 1kg+ payload with up to 10m/s+ speed. So, I am thinking what if replacing 920KV on m500, will it achieve a faster speed? I am wondering do you hava any experiments to test using a higher KV motor before?
@Eric-Katzfey , The video input for QGC looks like this:
It seems the server on voxl already got a connection to QGC, but there is still no video in the fly view (showing for waiting for video).
So, is there anything else that I should config in QGC?
@yu-zhang For #3, How did you configure the video input for QGC?
@Eric-Katzfey , I have a look at the /etc/modalai/voxl-streamer.conf.
It seems this config includes a set of different input and output settings. I am wondering if my issue may refer to this config? Do you have a document to introduce the mapping of this config?
E.g., the second line is
"configuration": "tracking". Does it mean the view showing in QGC will be related to the view of the tracking camera?As default, QGC will show which camera's view? If I would prefer to show the Hi-res view, how should I config it?
I also simply try to type in 1.3333 for aspect ratio, but it seems it doesn't work.
@yu-zhang voxl-streamer documentation is located here: https://docs.modalai.com/voxl-streamer/
@Eric-Katzfey Thanks, I double-check the config file, and it seems everything should be good. But there is still no video showing in QGC.
I am wondering if QGC blocks the stream data. I tested both QGC 4.1.4 and the latest 4.2.0 on both my Macbooks (m1 and intel). They all cannot show the video correctly.
I found QGC 4.1.1 got this issue on m1 Macbook, but it should already be fixed in the later versions.
I am wondering what's your QGC version? Do you have a Macbook at hand? If so, could you please make a quick test to check if it's an issue with QGC?
Hi @Eric-Katzfey ,
I tested using VLC on amd64 Macbook, and the streamer works well. It's all the same config as in QGC. So, I assume the latest QGC (4.1.4/4.2.0) still has the issue to fail receive streaming video on host PC.
I will continue to work on my target and hope QGC will cover this issue soon later.
Thanks again!
Hi Yu,
I've got answers to some of your questions, and will ping others to help with the rest.
voxl-crossandvoxl-emulator(andvoxl-hexagonif you're trying to make apps that use the SDSP) are build environments.voxl-emulatorhas a lot of the rootfs from voxl, allowing you to use some of the proprietary libs like MVSDK on voxl (which is why it's behind a EULA).voxl-crossis intended to be a lighter-weight image with the proper toolchains to allow you to build code for use on voxl in a more user-friendly environment. For your use case, you'll want to clonevoxl-vision-px4, modify (or add your own) offboard mode to do the behavior you want, rebuild it invoxl-cross, and then deploy it to your drone. -
As in 1, voxl-emulator is a build environment, we do not provide a simulator in there. If you want to test code against simulated data, you can use the
voxl-loggercommand on voxl to log camera and imu data (look through the docs to make sure you include all the data you want), then disable the camera and imu services and usevoxl-replayto replay the logs. -
Will ping others for this one
All of the code that we provide is intended to run on the platform, not on your host pc. You should just run
voxl-portalon the device (or enable the service to have it run in the background), and then you can view data in the browser. -
The source code for the figure eight offboard mode is here. There are parameters at the top that you can play with, and looking through this file would be the right starting point for how to write your own offboard mode. Additionally, if you want a more dynamic approach, we already support "offboard trajectory" which opens up a pipe in the filesystem for you to write a polynomial trajectory to have the drone fly, but note that it WILL fly the path, so if you're trying to play with that feature, start very carefully by writing a path from it's current location to fly forward a meter or something of the likes.
The output of the vio algorithm is written via MPA to
/run/mpa/qvioand can be accessed via an mpa pipe. An example of how to do this is thevoxl-inspect-qviotool, the source for which is here. I wouldn't exactly recommend trying to use an AI model for localization, as it'll run much more slowly than the VIO algorithm, which has been optimized for the hardware and outputs data much more frequently than it receives camera frames (as it uses the imu as well). For research purposes however, thish could be achieved withvoxl-logger, which can log imu, camera, and vio data, which could then be used to train a model. You could then then use tflite server to run the model, and write your own offboard mode to take whatever data your model provides and behave as you wish. -
All of the raw camera data is published via MPA pipes to
/run/mpa/{camera_name}. you can usevoxl-loggerto compress the data and write it to disk, or write a simple tool (using voxl-inspect-cam as a template for reading the raw data) and write it to a file. -
Hi @Eric-Katzfey ,
Thanks again!
@yu-zhang Can you please do us a big favor and ask your questions in separate posts instead just adding them all on to a single post? The forum is a resource for all of our customers and having each question in it's own forum posting makes it much easier for other people to benefit from the information in it. And regarding QGC 4.1.4, I use that version for testing but I am on a Linux Ubuntu 20.04 machine so maybe that's the difference.
Late to the party on this -- but I have been able to build ipk's off of an M1 recently.
I followed: https://docs.modalai.com/install-voxl-docker/
And then also downloaded the image from the developer portal as laid out: https://docs.modalai.com/voxl-cross/
To load:
docker load --input voxl-cross_V1.8.tarTo run:
voxl-docker -i voxl-cross:V1.8Then the docs in all of the Modal repo's work well.
I do have buildkit etc enabled as laid out here: https://medium.com/nerd-for-tech/developing-on-apple-m1-silicon-with-virtual-environments-4f5f0765fd2f but you shouldn't need any of that. Let me know if that helps you. Worked just fine for me -- no special rosetta2 terminal or Docker version.
I'll see if I can contribute something to the docs when I have a moment.
To load:
