  3. Opkg install voxl-streamer
32 Posts 7 Posters 10.2k Views 3 Watching
    @yu-zhang The emulator runs arm code on non-arm code computers using QEMU. I'm not sure anyone has ever tried on an Apple M1 chip but there is no reason the same concept wouldn't work. Are you sure you installed all of the prerequisites for voxl-emulator including QEMU?
    yu zhangY Offline
    yu zhangY Offline
    yu zhang
    @Eric-Katzfey I double-check installing qemu, but it seems it still doesn't work due to the arm64 platform.
    parallels@ubuntu-linux-20-04-desktop:~/git/voxl-docker$ sudo apt install -y qemu
    Reading package lists... Done
    Building dependency tree
    The following NEW packages will be installed:
      qemu
    0 upgraded, 1 newly installed, 0 to remove and 43 not upgraded.
    Need to get 15.2 kB of archives.
    After this operation, 125 kB of additional disk space will be used.
    Get:1 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 qemu arm64 1:4.2-3ubuntu6.19 [15.2 kB]
    Fetched 15.2 kB in 2s (9,772 B/s)
    Selecting previously unselected package qemu.
    (Reading database ... 185537 files and directories currently installed.)
    Preparing to unpack .../qemu_1%3a4.2-3ubuntu6.19_arm64.deb ...
    Unpacking qemu (1:4.2-3ubuntu6.19) ...
    Setting up qemu (1:4.2-3ubuntu6.19) ...
    parallels@ubuntu-linux-20-04-desktop:~/git/voxl-docker$ voxl-docker -i voxl-emulator
    launching image: voxl-emulator with the following command:
    docker run --rm -it --net=host --privileged -w /home/parallels --volume=/dev/bus/usb:/dev/bus/usb -e LOCAL_USER_ID=0 -e LOCAL_USER_NAME=root -e LOCAL_GID=0 -v /home/parallels/git/voxl-docker:/home/root:rw -w /home/root voxl-emulator /bin/bash -l
    WARNING: The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
    + USER_ID=0
    + USER_NAME=root
    + GID=0
    + getent group 0
    /opt/container/bin/adduser-sdk.sh: line 12: /usr/bin/getent: cannot execute binary file: Exec format error
    + groupadd -g 0 host_group
    groupadd: group 'host_group' already exists
    + echo 'Starting with UID : 0'
    + useradd --shell /bin/bash -u 0 -g 0 -o -c '' -M root
    useradd: user 'root' already exists
    + addgroup root users
    + export HOME=/home/root
    + HOME=/home/root
    + ls -ld /home/root
    /opt/container/bin/adduser-sdk.sh: line 18: /bin/ls: cannot execute binary file: Exec format error
    + echo 'root ALL=(ALL) NOPASSWD: ALL'
    + ls -l /etc/sudoers.d/
    /opt/container/bin/adduser-sdk.sh: line 21: /bin/ls: cannot execute binary file: Exec format error
    + cat /etc/sudoers.d/root
    /opt/container/bin/adduser-sdk.sh: line 22: /bin/cat: cannot execute binary file: Exec format error
    + chmod 777 /tmp
    /opt/container/bin/adduser-sdk.sh: line 24: /bin/chmod: cannot execute binary file: Exec format error
    + chmod 711 /usr/bin/sudo
    /opt/container/bin/adduser-sdk.sh: line 27: /bin/chmod: cannot execute binary file: Exec format error
    + chmod +s /usr/bin/sudo
    /opt/container/bin/adduser-sdk.sh: line 28: /bin/chmod: cannot execute binary file: Exec format error
    + ls -l /usr/local/bin/su-exec
    /opt/container/bin/adduser-sdk.sh: line 31: /bin/ls: cannot execute binary file: Exec format error
    + ls -l /bin/bash
    /opt/container/bin/adduser-sdk.sh: line 32: /bin/ls: cannot execute binary file: Exec format error
    + echo 'exec /usr/local/bin/su-exec root /bin/bash' -l
    exec /usr/local/bin/su-exec root /bin/bash -l
    + exec /usr/local/bin/su-exec root /bin/bash -l
    /opt/container/bin/adduser-sdk.sh: line 34: /usr/local/bin/su-exec: cannot execute binary file: Exec format error
    /opt/container/bin/adduser-sdk.sh: line 34: /usr/local/bin/su-exec: Success
    I am also trying to install voxl-cross, but it's failed by the same issue.
    parallels@ubuntu-linux-20-04-desktop:~/git/voxl-docker$ ./install-cross-docker.sh
    Sending build context to Docker daemon  8.327MB
    Step 1/46 : FROM  ubuntu:18.04
     ---> 1e7ccc70f4ca
    Step 2/46 : COPY sources.list /etc/apt/sources.list
     ---> Using cache
     ---> b2b4eb0123e7
    Step 3/46 : COPY xenial-sources.list /etc/apt/sources.list.d
     ---> Using cache
     ---> 6a09551e1019
    Step 4/46 : ENV DEBIAN_FRONTEND noninteractive
     ---> Using cache
     ---> e30dbea0cf3d
    Step 5/46 : RUN apt-get -y update
     ---> Using cache
     ---> f4cf6af06827
    Step 6/46 : RUN apt-get -y install apt-utils sudo
     ---> Running in 73b1c2daa50f
    Reading package lists...E: LZ4F: /var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_bionic-security_restricted_binary-amd64_Packages.lz4 Read error (18446744073709551600: ERROR_decompressionFailed)
    E: LZ4F: /var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_bionic-security_universe_binary-amd64_Packages.lz4 Read error (18446744073709551603: ERROR_frameType_unknown)
    E: The package lists or status file could not be parsed or opened.
    The command '/bin/sh -c apt-get -y install apt-utils sudo' returned a non-zero code: 100
    It seems it's a bit difficult for developing voxl on m1 chip. Please any ideas about this, or I may have to move onto another amd64 based PC?
    I am also wondering where could I locate the source code for running the off-board mode (flying as 8-path)?
    • yu zhangY yu zhang
        qemu
      + USER_ID=0
      + USER_NAME=root
      + GID=0
      + getent group 0
      + HOME=/home/root
      + ls -ld /home/root
      + chmod 777 /tmp
      + ls -l /bin/bash
       ---> 1e7ccc70f4ca
       ---> Using cache
       ---> b2b4eb0123e7
       ---> Using cache
       ---> 6a09551e1019
       ---> Using cache
       ---> e30dbea0cf3d
       ---> Using cache
       ---> f4cf6af06827
      @yu-zhang For now I'd say that switching to an amd64 PC would be the quickest route to getting something going.
          qemu
        + USER_ID=0
        + USER_NAME=root
        + GID=0
        + getent group 0
        + HOME=/home/root
        + ls -ld /home/root
        + chmod 777 /tmp
        + ls -l /bin/bash
         ---> 1e7ccc70f4ca
         ---> Using cache
         ---> b2b4eb0123e7
         ---> Using cache
         ---> 6a09551e1019
         ---> Using cache
         ---> e30dbea0cf3d
         ---> Using cache
         ---> f4cf6af06827
        @yu-zhang Figure 8 source code is here: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4/-/blob/master/src/offboard_figure_eight.c
        yu zhangY 2 Replies Last reply
          Hi @Eric-Katzfey ,
          I used the latest voxl-emulator V1.7, but it only works for amd64.
          I checked how to rebuild the emulator, but it seems that all sources should be re-built for this. So, I am wondering if you already support the binaries for arm64?
          I also am wondering if I could use voxl-cross V1.1 instead or I should have to compile arm64 binaries?
          I am using the Macbook pro 2021 14 with m1 max and running Ubuntu 20.04 in this PC. Or if I should have to change to another regular PC for developing voxl easier? Thanks.
          modaltbM Offline
          modaltbM Offline
          modaltb
          @yu-zhang
          I found this command one day searching for something similar, and it resolved my "issue", but I can't say why....
          This might work, but no warranties provided!! 😉
          docker run --rm --privileged multiarch/qemu-user-static --reset -p yes
          yu zhangY 1 Reply Last reply
            yu zhangY Offline
            yu zhangY Offline
            yu zhang
            @Eric-Katzfey Thanks so much. All right, I will try to find another PC to go through.
            Hope this issue on m1 will be addressed then.
            • modaltbM modaltb
              @yu-zhang
              yu zhangY Offline
              yu zhangY Offline
              yu zhang
              @modaltb Thanks for the information.
              I tried this one, but I got this:
              parallels@ubuntu-linux-20-04-desktop:~/git/voxl-docker$ docker run --rm --privileged multiarch/qemu-user-static --reset -p yes
              Unable to find image 'multiarch/qemu-user-static:latest' locally
              latest: Pulling from multiarch/qemu-user-static
              01c2cdc13739: Pull complete
              11933eee4160: Pull complete
              30abb83a18eb: Pull complete
              0657daef200b: Pull complete
              10094524a9f3: Pull complete
              Digest: sha256:2c8b8fcf1d6badfca797c3fb46b7bb5f705ec7e66363e1cfeb7b7d4c7086e360
              Status: Downloaded newer image for multiarch/qemu-user-static:latest
              It seems it requests to download the multiarch/qemu-user-static, but it seems this package cannot be installed on m1.
              Anyways, I may try to find another PC to do, and hope voxl could work on m1 soon 😉
                yu zhangY Offline
                yu zhangY Offline
                yu zhang
                Hi @Eric-Katzfey , I think I am still a little bit unclear about the voxl development after reviewing the documents.
                As a target example, I am thinking about how to develop my own version Figure 8 (maybe different flying path) using VIO for off-board mode (may invlove enabling GPU for running Tensflow lite model onboard).
                I list some questions based on my understanding, please correct me if anything is wrong:
                1. If I would develop the off-board flying based on the Figure 8, I should rewirte some parts of the source code, and re-build it by voxl-cross, then deploy it to the voxl on m500 for testing, right? I think I may not need to use voxl-emulator, and it should be used only for testing some new applications, right?
                2. For voxl-emulator, does voxl include a flying simulation environment that allows developers use voxl-emulator to test flying function virually, like using simulated IMU or video data?
                3. I asked you about using voxl-streamer to enable real-time video on hosting PC. I realize I don't need to use voxl-emulator to install voxl-streamer, instead I should directly use it on m500 via ssh to start a RTSP server, then config QGC to get video data on hosting PC, right?
                I tried this in QGC, but it seems QGC couldn't show anything (only "waiting for video"). So, I am not sure if I manage it correctly:
                1. For the use of voxl-portal, I should run it on m500 to start a server. Then I should make the source code on hosting PC, and using sudo ./build/voxl-portal ./web_root/ and sudo build/vins-camera-imu-server to view data in a browser on PC, right?
                2. For developing on top of the Figure 8, I would define a different flying path like a simple triangle. I am wondering how to achieve this and where I should get started? What if I would enlarge the flying area of the existing Figure 8? Or how to change the flying speed?
                3. For the voxl-qvio-server, existing VIO uses the Qualcomm MV SDK mvVISLAM algorithm. What if I would collect the tracking video of Figure 8 as input and its coordinates as labels to train a tflite model, then adding a new VIO for off-board mode, how should I first collect the tracking video and coordinates? After training, how should I deploy it on m500, and using off-board mode to test it?
                4. How could I access all 3 types (hi, stereo, and tracking) of cameras' raw data? Are there any configrations to set for recording all 3 together and storing on disk as video output?
                5. For testing m500 fly speed, it seems I could only manually speed-up to 5m/s in the Poisiton mode (maximum speed parameter is 12m/s as defult), I am wondering if there are any constraints to keep flying safe when in the Poisiton mode? I haven't tested the speed-up in a mission mode, but I will test it if m500 could fly over 10m/s+.
                Any other suggestions for my target would be much appreciated.
                • ? Offline
                  Hi Yu,
                  I've got answers to some of your questions, and will ping others to help with the rest.
                  1. voxl-cross and voxl-emulator (and voxl-hexagon if you're trying to make apps that use the SDSP) are build environments. voxl-emulator has a lot of the rootfs from voxl, allowing you to use some of the proprietary libs like MVSDK on voxl (which is why it's behind a EULA). voxl-cross is intended to be a lighter-weight image with the proper toolchains to allow you to build code for use on voxl in a more user-friendly environment. For your use case, you'll want to clone voxl-vision-px4, modify (or add your own) offboard mode to do the behavior you want, rebuild it in voxl-cross, and then deploy it to your drone.
                  2. As in 1, voxl-emulator is a build environment, we do not provide a simulator in there. If you want to test code against simulated data, you can use the voxl-logger command on voxl to log camera and imu data (look through the docs to make sure you include all the data you want), then disable the camera and imu services and use voxl-replay to replay the logs.
                  3. Will ping others for this one
                  4. All of the code that we provide is intended to run on the platform, not on your host pc. You should just run voxl-portal on the device (or enable the service to have it run in the background), and then you can view data in the browser.
                  5. The source code for the figure eight offboard mode is here. There are parameters at the top that you can play with, and looking through this file would be the right starting point for how to write your own offboard mode. Additionally, if you want a more dynamic approach, we already support "offboard trajectory" which opens up a pipe in the filesystem for you to write a polynomial trajectory to have the drone fly, but note that it WILL fly the path, so if you're trying to play with that feature, start very carefully by writing a path from it's current location to fly forward a meter or something of the likes.
                  6. The output of the vio algorithm is written via MPA to /run/mpa/qvio and can be accessed via an mpa pipe. An example of how to do this is the voxl-inspect-qvio tool, the source for which is here. I wouldn't exactly recommend trying to use an AI model for localization, as it'll run much more slowly than the VIO algorithm, which has been optimized for the hardware and outputs data much more frequently than it receives camera frames (as it uses the imu as well). For research purposes however, thish could be achieved with voxl-logger, which can log imu, camera, and vio data, which could then be used to train a model. You could then then use tflite server to run the model, and write your own offboard mode to take whatever data your model provides and behave as you wish.
                  7. All of the raw camera data is published via MPA pipes to /run/mpa/{camera_name}. you can use voxl-logger to compress the data and write it to disk, or write a simple tool (using voxl-inspect-cam as a template for reading the raw data) and write it to a file.
                  8. Will ping others for this one
                    @yu-zhang For #3, How did you configure the video input for QGC?
                    • ? Offline
                      #18
                      Hi @yu-zhang ,
                      Regarding speed, we've flown at 8-10 m/s during missions safely. You can experiment and run a simple mission to ensure the behavior is what you expect.
                      Also keep in mind wind conditions. To keep things safe, we usually fly with maximum wind velocity of 15 mph (or ~7 m/s) with gusts of 5 mph (or ~2 m/s). Always good to have enough speed to overcome current wind conditions when returning to launch.
                      Hope this helps!
                      • ? A Former User
                        Hi Yu,
                        yu zhangY Offline
                        yu zhangY Offline
                        yu zhang
                        Hi @Alex-Gardner , Thanks so much for your detailed reply!
                        It's more clear for my understanding now. And I already tried the voxl-portal, and it works well for me.
                        All right, I will follow your suggestions to start my first development on voxl, and hope I could achieve it very soon 😉
                          yu zhangY Offline
                          yu zhangY Offline
                          yu zhang
                          @Eric-Katzfey , The video input for QGC looks like this:
                          It seems the server on voxl already got a connection to QGC, but there is still no video in the fly view (showing for waiting for video).
                          So, is there anything else that I should config in QGC?
                          • ? A Former User
                            Hi @yu-zhang ,
                            Hope this helps!
                            yu zhangY Offline
                            yu zhangY Offline
                            yu zhang
                            @RichieRich Thanks for the information!
                            I would test the maximum speed m500 could achieve in a normal condition. So, I will run the mission for this purpose.
                            By the way, for the motor on m500, I noticed it's the Motor 2216-880KV for 10in props. I also saw there was a 2216-920KV version on Holybro website for s500 frame.
                            https://shop.holybro.com/spare-parts-s500-v2-kit_p1251.html
                            I double check that different the KV rating of a motor will be able to achieve different speeds. In general, the higher KV refers to the faster speed, but the lower in a heavy-lift.
                            For the defualt 880KV, m500 can achieve 1kg+ payload with up to 10m/s+ speed. So, I am thinking what if replacing 920KV on m500, will it achieve a faster speed? I am wondering do you hava any experiments to test using a higher KV motor before?
                              yu zhangY Offline
                              yu zhangY Offline
                              yu zhang
                              @Eric-Katzfey , I am wondering if the aspect ratio is incorrect to get the source video? The 1.77777 is the default one, and I am not sure what is the default aspect ratio on m500?
                                yu zhangY Offline
                                yu zhangY Offline
                                yu zhang
                                @Eric-Katzfey , I have a look at the /etc/modalai/voxl-streamer.conf.
                                It seems this config includes a set of different input and output settings. I am wondering if my issue may refer to this config? Do you have a document to introduce the mapping of this config?
                                E.g., the second line is "configuration": "tracking". Does it mean the view showing in QGC will be related to the view of the tracking camera?
                                As default, QGC will show which camera's view? If I would prefer to show the Hi-res view, how should I config it?
                                I also simply try to type in 1.3333 for aspect ratio, but it seems it doesn't work.
                                  @yu-zhang voxl-streamer documentation is located here: https://docs.modalai.com/voxl-streamer/
                                    yu zhangY Offline
                                    yu zhangY Offline
                                    yu zhang
                                    @Eric-Katzfey Thanks, I double-check the config file, and it seems everything should be good. But there is still no video showing in QGC.
                                    I am wondering if QGC blocks the stream data. I tested both QGC 4.1.4 and the latest 4.2.0 on both my Macbooks (m1 and intel). They all cannot show the video correctly.
                                    I found QGC 4.1.1 got this issue on m1 Macbook, but it should already be fixed in the later versions.
                                    I am wondering what's your QGC version? Do you have a Macbook at hand? If so, could you please make a quick test to check if it's an issue with QGC?
                                      yu zhangY Offline
                                      yu zhangY Offline
                                      yu zhang
                                      Hi @Eric-Katzfey ,
                                      I tested using VLC on amd64 Macbook, and the streamer works well. It's all the same config as in QGC. So, I assume the latest QGC (4.1.4/4.2.0) still has the issue to fail receive streaming video on host PC.
                                      I will continue to work on my target and hope QGC will cover this issue soon later.
                                      Thanks again!
                                      • ? A Former User
                                        Hi Yu,
                                        yu zhangY Offline
                                        yu zhangY Offline
                                        yu zhang
                                          [[topic:post-is-deleted]]
                                          yu zhangY Offline
                                          yu zhangY Offline
                                          yu zhang
