  2. Feature Requests
  3. voxl-send-command exit status implementation request
Scheduled Pinned Locked Moved Unsolved Feature Requests
4 Posts 2 Posters 2.5k Views 1 Watching
  • J Offline
    jameskuesel
    wrote on last edited by jameskuesel
    Super super low priority but I noticed that voxl-send-command doesn't output a return code. Even on an error can look like a success since echo will return exit status 0. This is particularly frustrating when an error does actually occur.
    https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/scripts/voxl-send-command?ref_type=heads
    Here is a fix below:
    if [ -p "/run/mpa/${1}/control" ]; then
        _CONTROL_FILE="/run/mpa/${1}/control"
        shift
        echo "$@" >> "$_CONTROL_FILE"
        echo "Successfully sent command to ${_CONTROL_FILE}"
        exit 0
    elif [ -p "${1}/control" ]; then
        _CONTROL_FILE="${1}/control"
        shift
        exit 0
    else
        echo "Unable to find valid pipe that accepts control commands at: ${1}"
        exit 1
    fi
    Would love to see an update here!
    Also side note: Let me know if this is the proper channel so submit code issues like these.
    • J jameskuesel
          shift
          exit 0
          shift
          exit 0
      else
          exit 1
      fi
      @jameskuesel Feel free to make the change and submit a PR
      J 1 Reply Last reply
        jameskuesel
        @Eric-Katzfey
        Sorry my bad! Done!
        • J jameskuesel
          @Eric-Katzfey
          Sorry my bad! Done!
          @jameskuesel Thanks! Merged
