    voxl-send-command exit status implementation request
    Feature Requests
    • J
      jameskuesel
      Super super low priority but I noticed that voxl-send-command doesn't output a return code. Even on an error can look like a success since echo will return exit status 0. This is particularly frustrating when an error does actually occur.
      https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/scripts/voxl-send-command?ref_type=heads
      Here is a fix below:
      if [ -p "/run/mpa/${1}/control" ]; then
          _CONTROL_FILE="/run/mpa/${1}/control"
          shift
          echo "$@" >> "$_CONTROL_FILE"
          echo "Successfully sent command to ${_CONTROL_FILE}"
          exit 0
      elif [ -p "${1}/control" ]; then
          _CONTROL_FILE="${1}/control"
          shift
          exit 0
      else
          echo "Unable to find valid pipe that accepts control commands at: ${1}"
          exit 1
      fi
      Would love to see an update here!
      Also side note: Let me know if this is the proper channel so submit code issues like these.
        Eric Katzfey ModalAI Team @jameskuesel
        @jameskuesel Feel free to make the change and submit a PR
        • J
          jameskuesel @Eric Katzfey
          Sorry my bad! Done!
            @jameskuesel Thanks! Merged
