  3. VOXL2 J19 QUP3
VOXL2 J19 QUP3
24 Posts 2 Posters 3.1k Views 1 Watching
  • voxltesterV voxltester
    @Eric-Katzfey
    Isn't this I2C (J19 7&8) APP I2C or DPS I2C?
    7  I2C3 SDA 3P3V   slpi_proc, SSC_QUP3
    8  I2C3 SCL 3P3V   slpi_proc, SSC_QUP3
    Is it possible to access DPS I2C from PX4?
    Please see the outputs of the -X and -I options.
    pxh> lightware_laser_i2c start -X -b 4
    WARN  [SPI_I2C] UnknownApp: no instance started (no device on bus?)
    Command 'lightware_laser_i2c' failed, returned -1.
    pxh> lightware_laser_i2c start -I -b 4
    FYI, the following is an initialization of the VOXL-PX4.
    voxl2:~$ voxl-px4 -d
    Found DSP signature file
    [INFO] Disabling daemon mode
    AIRFRAME=MULTICOPTER
    GPS=AUTODETECT
    RC=GHST
    ESC=VOXL_ESC
    POWER MANAGER=NONE
    AIRSPEED SENSOR=NONE
    DISTANCE SENSOR=LIGHTWARE_SF000
    OSD=DISABLE
    DAEMON_MODE=DISABLE
    SENSOR_CAL=ACTUAL
    ARTIFACT_MODE=DISABLE
    EXTRA STEPS:
    INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread running
    INFO  [muorb] [modules__muorb__slpi] muorb keepalive thread running
    INFO  [muorb] [tasks] Creating pthread test_MUORB
    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [muorb] [uORB] Advertising remote topic log_message
    AIRFRAME: MULTICOPTER
    GPS: AUTODETECT
    RC: GHST
    ESC: VOXL_ESC
    POWER MANAGER: NONE
    AIRSPEED SENSOR: NONE
    DISTANCE SENSOR: LIGHTWARE_SF000
    OSD: DISABLE
    ARTIFACT_MODE: DISABLE
    EXTRA STEPS:
    INFO  [muorb] [parameters] Starting param sync THREAD
    Running on M0054
    INFO  [muorb] [qshell] before starting the qshell_entry task
    INFO  [muorb] [tasks] Creating pthread qshell
    INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
    INFO  [muorb] [qshell] qshell entry.....
    INFO  [muorb] [qshell] after starting the qshell_entry task
    INFO  [muorb] [qshell] Init app map initialized
    INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    INFO  [muorb] [uORB] Advertising remote topic parameter_update
    INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
    INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
    INFO  [parameters] BSON document size 3307 bytes, decoded 3307 bytes (INT32:44, FLOAT:109)
    INFO  [qshell] Send cmd: 'icm42688p start -s'
    INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    INFO  [muorb] [qshell] qshell gotten: icm42688p start -s
    INFO  [muorb] [qshell]   arg0 = 'icm42688p'
    INFO  [muorb] [qshell]   arg1 = 'start'
    INFO  [muorb] [qshell]   arg2 = '-s'
    INFO  [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
    INFO  [muorb] [icm42688p] ICM42688P::probe successful!
    INFO  [muorb] [drivers__device] on SPI bus 1
    INFO  [muorb] icm42688p #0 on SPI bus 1
    INFO  [muorb]
    INFO  [muorb] [icm42688p] >>> ICM42688P this: b26024d8
    INFO  [muorb] [qshell] Ok executing command: icm42688p start -s
    INFO  [qshell] qshell return value timestamp: 83014023, local time: 83018955
    Looking for external DPS368 barometer
    INFO  [muorb] [drivers__device] Register interrupt b214f094 e612a80c b26024d8
    INFO  [uORB] Advertising remote topic sensor_gyro_fifo
    INFO  [uORB] Advertising remote topic sensor_accel_fifo
    ERROR [dps310] Product_ID mismatch
    Looking for external ICP10100 barometer
    Did not detect an external barometer, starting onboard ICP10100 barometer
    INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
    INFO  [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
    INFO  [muorb] [qshell]   arg0 = 'icp101xx'
    INFO  [muorb] [qshell]   arg2 = '-I'
    INFO  [muorb] [qshell]   arg3 = '-b'
    INFO  [muorb] [qshell]   arg4 = '5'
    INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
    INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5
    INFO  [muorb] icp101xx #0 on I2C bus 5
    INFO  [muorb]  address 0x63
    INFO  [muorb]
    INFO  [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
    INFO  [qshell] qshell return value timestamp: 83111693, local time: 83114593
    INFO  [qshell] Send cmd: 'temperature_compensation start'
    INFO  [muorb] [qshell] qshell gotten: temperature_compensation start
    INFO  [muorb] [qshell]   arg0 = 'temperature_compensation'
    INFO  [uORB] Advertising remote topic sensor_correction
    INFO  [muorb] [qshell] Ok executing command: temperature_compensation start
    INFO  [qshell] qshell return value timestamp: 83262606, local time: 83264812
    INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
    INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
    INFO  [muorb] [qshell]   arg0 = 'qmc5883l'
    INFO  [muorb] [qshell]   arg2 = '-R'
    INFO  [muorb] [qshell]   arg3 = '10'
    INFO  [muorb] [qshell]   arg4 = '-X'
    INFO  [muorb] [qshell]   arg5 = '-b'
    INFO  [muorb] [qshell]   arg6 = '1'
    INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
    INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1
    ERROR [muorb] [drivers__device] i2c probe failed
    INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)
    ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R 10 -X -b 1
    INFO  [qshell] cmd returned with: -1
    INFO  [qshell] qshell return value timestamp: 83324177, local time: 83325854
    ERROR [qshell] Command failed
    INFO  [uORB] Advertising remote topic sensor_baro
    INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
    INFO  [muorb] [qshell]   arg0 = 'ist8310'
    INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
    ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1
    INFO  [qshell] qshell return value timestamp: 83374408, local time: 83377531
    Looking for ist8308 magnetometer
    INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
    INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
    INFO  [muorb] [qshell]   arg0 = 'ist8308'
    INFO  [muorb] [qshell]   arg3 = '12'
    INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
    ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1
    INFO  [qshell] qshell return value timestamp: 83413213, local time: 83416595
    INFO  [muorb] [qshell] qshell gotten: gps start
    INFO  [muorb] [qshell]   arg0 = 'gps'
    INFO  [muorb] [tasks] Creating pthread gps
    INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097645
    INFO  [muorb] [qshell] Ok executing command: gps start
    INFO  [qshell] qshell return value timestamp: 83445422, local time: 83446602
    Looking for ncp5623c RGB LED
    INFO  [muorb] [gps] GPS UART baudrate set to 115200
    INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    INFO  [muorb] [qshell] qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO  [muorb] [qshell]   arg0 = 'rgbled_ncp5623c'
    INFO  [muorb] [qshell]   arg2 = '-X'
    INFO  [muorb] [qshell]   arg4 = '1'
    INFO  [muorb] [qshell]   arg5 = '-f'
    INFO  [muorb] [qshell]   arg6 = '400'
    INFO  [muorb] [qshell]   arg7 = '-a'
    INFO  [muorb] [qshell]   arg8 = '56'
    INFO  [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273
    INFO  [muorb] [drivers__device] Set i2c address 0x38, fd 4
    ERROR [muorb] [qshell] Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO  [qshell] qshell return value timestamp: 83487606, local time: 83489160
    Starting VOXL ESC driver
    INFO  [qshell] Send cmd: 'voxl_esc start'
    INFO  [muorb] [qshell] qshell gotten: voxl_esc start
    INFO  [muorb] [qshell]   arg0 = 'voxl_esc'
    INFO  [uORB] Advertising remote topic actuator_outputs
    INFO  [muorb] [voxl_esc] Starting VOXL ESC driver
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CONFIG: 1
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_MODE: 0
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC1: 102
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC2: 103
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC3: 101
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_FUNC4: 104
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR1: 0
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR2: 0
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR3: 0
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_SDIR4: 0
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PWR_MIN: 0.050000
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MIN: 2000
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MAX: 12000
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_PERC: 90
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_VLOG: 1
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_WARN: 0
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_T_OVER: 0
    INFO  [muorb] [voxl_esc] Params: GPIO_CTL_CH: 0
    INFO  [muorb] [voxl_esc] Params: VOXL_ESC_CMD: 0
    INFO  [muorb] [qshell] Ok executing command: voxl_esc start
    INFO  [muorb] [voxl_esc] Opening UART ESC device 2, baud rate 2000000
    INFO  [muorb] [voxl_esc] Successfully opened UART ESC device
    INFO  [muorb] [voxl_esc] Detecting ESCs...
    INFO  [muorb] [voxl_esc] 	ESC ID     : 0
    INFO  [muorb] [voxl_esc] 	Board Type : 40: ModalAi 4-in-1 ESC (M0129-3)
    INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0024
    INFO  [muorb] [voxl_esc] 	Firmware   : version   39, hash 9c6233d6
    INFO  [muorb] [voxl_esc] 	Bootloader : version  184, hash 10bf24c8
    INFO  [muorb] [voxl_esc] 	Reply time : 723us
    INFO  [muorb] [voxl_esc] VOXL_ESC:
    INFO  [muorb] [voxl_esc] 	ESC ID     : 1
    INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0028
    INFO  [muorb] [voxl_esc] 	Reply time : 728us
    INFO  [qshell] qshell return value timestamp: 83652589, local time: 83657098
    INFO  [muorb] [voxl_esc] 	ESC ID     : 2
    INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0026
    INFO  [muorb] [voxl_esc] 	Reply time : 718us
    INFO  [muorb] [voxl_esc] 	ESC ID     : 3
    INFO  [muorb] [voxl_esc] 	Unique ID  : 0x2039333557555313000F0022
    INFO  [muorb] [voxl_esc] 	Reply time : 739us
    INFO  [muorb] [voxl_esc] Use extended rpm packet : 1
    INFO  [muorb] [voxl_esc] All ESCs successfully detected
    Starting GHST RC driver
    INFO  [qshell] Send cmd: 'ghst_rc start -d 7'
    INFO  [muorb] [qshell] qshell gotten: ghst_rc start -d 7
    INFO  [muorb] [qshell]   arg0 = 'ghst_rc'
    INFO  [uORB] Advertising remote topic actuator_outputs_debug
    INFO  [uORB] Advertising remote topic esc_status
    INFO  [muorb] [qshell]   arg2 = '-d'
    INFO  [muorb] [qshell]   arg3 = '7'
    INFO  [muorb] [qshell] Ok executing command: ghst_rc start -d 7
    INFO  [uORB] Advertising remote topic input_rc
    INFO  [qshell] qshell return value timestamp: 83712270, local time: 83715195
    INFO  [qshell] Send cmd: 'lightware_laser_i2c start -b 4'
    INFO  [muorb] [qshell] qshell gotten: lightware_laser_i2c start -b 4
    ERROR [muorb] [qshell] Command lightware_laser_i2c not found
    ERROR [muorb] [qshell] Failed to execute command: lightware_laser_i2c start -b 4
    INFO  [qshell] cmd returned with: 1
    INFO  [qshell] qshell return value timestamp: 83743015, local time: 83745263
    INFO  [qshell] Send cmd: 'sensors start'
    INFO  [muorb] [qshell] qshell gotten: sensors start
    INFO  [muorb] [qshell]   arg0 = 'sensors'
    INFO  [uORB] Advertising remote topic sensor_selection
    INFO  [uORB] Advertising remote topic sensors_status_imu
    INFO  [muorb] [modules__muorb__slpi] Deleting /data/px4/slpi/keepalive_fail
    INFO  [uORB] Advertising remote topic vehicle_acceleration
    INFO  [uORB] Advertising remote topic vehicle_angular_velocity
    INFO  [uORB] Advertising remote topic sensor_combined
    INFO  [uORB] Advertising remote topic battery_status
    INFO  [uORB] Advertising remote topic vehicle_air_data
    INFO  [uORB] Advertising remote topic vehicle_gps_position
    INFO  [uORB] Advertising remote topic vehicle_magnetometer
    INFO  [uORB] Advertising remote topic sensor_preflight_mag
    INFO  [uORB] Advertising remote topic vehicle_imu
    INFO  [uORB] Advertising remote topic vehicle_imu_status
    INFO  [muorb] [qshell] Ok executing command: sensors start
    INFO  [qshell] qshell return value timestamp: 83931906, local time: 83935646
    INFO  [uORB] Advertising remote topic sensors_status_baro
    INFO  [qshell] Send cmd: 'ekf2 start'
    INFO  [muorb] [qshell] qshell gotten: ekf2 start
    INFO  [muorb] [qshell]   arg0 = 'ekf2'
    INFO  [uORB] Advertising remote topic vehicle_attitude
    INFO  [uORB] Advertising remote topic vehicle_local_position
    INFO  [uORB] Advertising remote topic estimator_event_flags
    INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
    INFO  [uORB] Advertising remote topic estimator_innovation_variances
    INFO  [uORB] Advertising remote topic estimator_innovations
    INFO  [uORB] Advertising remote topic estimator_sensor_bias
    INFO  [uORB] Advertising remote topic estimator_states
    INFO  [uORB] Advertising remote topic estimator_status_flags
    INFO  [muorb] [qshell] Ok executing command: ekf2 start
    INFO  [qshell] qshell return value timestamp: 84173695, local time: 84177522
    INFO  [uORB] Advertising remote topic ekf2_timestamps
    INFO  [uORB] Advertising remote topic vehicle_odometry
    INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
    INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
    INFO  [qshell] Send cmd: 'mc_pos_control start'
    INFO  [muorb] [qshell] qshell gotten: mc_pos_control start
    INFO  [muorb] [qshell]   arg0 = 'mc_pos_control'
    INFO  [uORB] Advertising remote topic takeoff_status
    INFO  [muorb] [qshell] Ok executing command: mc_pos_control start
    INFO  [qshell] qshell return value timestamp: 84266732, local time: 84268823
    INFO  [qshell] Send cmd: 'mc_att_control start'
    INFO  [muorb] [qshell] qshell gotten: mc_att_control start
    INFO  [muorb] [qshell]   arg0 = 'mc_att_control'
    INFO  [muorb] [qshell] Ok executing command: mc_att_control start
    INFO  [qshell] qshell return value timestamp: 84320268, local time: 84321796
    INFO  [qshell] Send cmd: 'mc_rate_control start'
    INFO  [muorb] [qshell] qshell gotten: mc_rate_control start
    INFO  [muorb] [qshell]   arg0 = 'mc_rate_control'
    INFO  [uORB] Advertising remote topic rate_ctrl_status
    INFO  [muorb] [qshell] Ok executing command: mc_rate_control start
    INFO  [qshell] qshell return value timestamp: 84408066, local time: 84410267
    INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO  [muorb] [qshell] qshell gotten: mc_hover_thrust_estimator start
    INFO  [muorb] [qshell]   arg0 = 'mc_hover_thrust_estimator'
    INFO  [muorb] [qshell] Ok executing command: mc_hover_thrust_estimator start
    INFO  [qshell] qshell return value timestamp: 84462789, local time: 84464375
    INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
    INFO  [muorb] [qshell] qshell gotten: mc_autotune_attitude_control start
    INFO  [muorb] [qshell]   arg0 = 'mc_autotune_attitude_control'
    INFO  [uORB] Advertising remote topic autotune_attitude_control_status
    INFO  [muorb] [qshell] Ok executing command: mc_autotune_attitude_control start
    INFO  [qshell] qshell return value timestamp: 84514600, local time: 84516557
    INFO  [qshell] Send cmd: 'land_detector start multicopter'
    INFO  [muorb] [qshell] qshell gotten: land_detector start multicopter
    INFO  [muorb] [qshell]   arg0 = 'land_detector'
    INFO  [muorb] [qshell]   arg2 = 'multicopter'
    INFO  [muorb] [qshell] Ok executing command: land_detector start multicopter
    INFO  [qshell] qshell return value timestamp: 84553505, local time: 84556075
    INFO  [uORB] Advertising remote topic vehicle_land_detected
    INFO  [qshell] Send cmd: 'manual_control start'
    INFO  [muorb] [qshell] qshell gotten: manual_control start
    INFO  [muorb] [qshell]   arg0 = 'manual_control'
    INFO  [muorb] [qshell] Ok executing command: manual_control start
    INFO  [qshell] qshell return value timestamp: 84597175, local time: 84598418
    INFO  [uORB] Advertising remote topic manual_control_setpoint
    INFO  [qshell] Send cmd: 'control_allocator start'
    INFO  [muorb] [qshell] qshell gotten: control_allocator start
    INFO  [muorb] [qshell]   arg0 = 'control_allocator'
    INFO  [uORB] Advertising remote topic control_allocator_status
    INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic actuator_motors
    INFO  [uORB] Advertising remote topic actuator_servos
    INFO  [uORB] Advertising remote topic actuator_servos_trim
    INFO  [muorb] [qshell] Ok executing command: control_allocator start
    INFO  [qshell] qshell return value timestamp: 84809648, local time: 84811022
    INFO  [qshell] Send cmd: 'load_mon start'
    INFO  [muorb] [qshell] qshell gotten: load_mon start
    INFO  [muorb] [qshell]   arg0 = 'load_mon'
    INFO  [muorb] [qshell] Ok executing command: load_mon start
    INFO  [uORB] Advertising remote topic cpuload
    INFO  [qshell] qshell return value timestamp: 84866816, local time: 84868801
    INFO  [qshell] Send cmd: 'rc_update start'
    INFO  [muorb] [qshell] qshell gotten: rc_update start
    INFO  [muorb] [qshell]   arg0 = 'rc_update'
    INFO  [muorb] [qshell] Ok executing command: rc_update start
    INFO  [qshell] qshell return value timestamp: 85094704, local time: 85096473
    INFO  [uORB] Advertising remote topic rc_channels
    INFO  [qshell] Send cmd: 'commander start'
    INFO  [muorb] [qshell] qshell gotten: commander start
    INFO  [muorb] [qshell]   arg0 = 'commander'
    INFO  [muorb] [tasks] Creating pthread commander
    INFO  [muorb] [tasks] Successfully created px4 task PX4_commander with tid 2097638
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] [commander] LED: open /dev/led0 failed (22)
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [muorb] [qshell] Ok executing command: commander start
    INFO  [qshell] qshell return value timestamp: 85278466, local time: 85282382
    INFO  [uORB] Advertising remote topic event
    INFO  [uORB] Advertising remote topic mavlink_log
    INFO  [muorb] [health_and_arming_checks] Preflight Fail: Compass Sensor 0 missing
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [muorb] [qshell] qshell gotten: flight_mode_manager start
    INFO  [muorb] [qshell]   arg0 = 'flight_mode_manager'
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] [qshell] Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 85385231, local time: 85387168
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO  [muorb] [uORB] Advertising remote topic transponder_report
    INFO  [muorb] [uORB] Advertising remote topic rtl_time_estimate
    INFO  [muorb] [uORB] Advertising remote topic position_setpoint_triplet
    INFO  [mpa] Successfully loaded library libmodal_pipe.so
    INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO  [muorb] [uORB] Advertising remote topic telemetry_status
    INFO  [mavlink] partner IP: 127.0.0.1
    INFO  [muorb] [uORB] Advertising remote topic offboard_control_mode
    INFO  [muorb] [uORB] Advertising remote topic obstacle_distance
    INFO  [uORB] Advertising remote topic actuator_controls_status_0
    INFO  [muorb] [uORB] Advertising remote topic timesync_status
    INFO  [muorb] [uORB] Advertising remote topic vehicle_visual_odometry
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] [uORB] Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    pxh> INFO  [logger] logger started (mode=all)
    INFO  [muorb] [gps] GPS UART baudrate set to 9600
    @voxltester In order to execute on the DSP side you have to have qshell before the command. When you have it you get the error that command is not found. That's probably because the driver has not been built into the DSP image. It only seems to be on the apps side.
    voxltesterV 2 Replies Last reply
      voxltesterV Offline
      voxltesterV Offline
      voxltester
      wrote on last edited by voxltester
      #22
        voxltesterV Offline
        voxltesterV Offline
        voxltester
        #23
        @Eric-Katzfey
        Never mind. I finally received the DISTANCE_SENSOR data!
        I added
        CONFIG_DRIVERS_DISTANCE_SENSOR_LIGHTWARE_LASER_I2C=y
        to px4-firmware/board/modalai/voxl2-slpi/dafault.px4board.
        Thank you for your help.
          @Eric-Katzfey
          I added
          @voxltester Great! Glad you got it working.
