  3. Use lidar for localization instead of Qvio
starling
6 Posts 2 Posters 753 Views 2 Watching
  • Muqing CaoM Offline
    Muqing CaoM Offline
    Muqing Cao
    About using another state estimation source, we would like to replace the onboard qvio with some lidar based odometry for localization and position hold purpose. Say we can get lidar-based position estimate in ROS message, can we disable the onboard VIO and feed our position estimate to the onboard flight controller through MAVROS or something else?
    Please advise!
    • Muqing CaoM Muqing Cao
      Please advise!
      Eric KatzfeyE Online
      @Muqing-Cao Yes, definitely. The applications are auto started using systemd services and can be stopped / disabled using standard commands as desired.
      Muqing CaoM 1 Reply Last reply
        Muqing CaoM Offline
        Muqing CaoM Offline
        Muqing Cao
        @Eric-Katzfey Thanks for your reply. Can we have more details about the interface we could use to feed position estimate?
          @Muqing-Cao Just the standard Mavlink ODOMETRY message is what we have used. Not exactly sure how that translates into ROS land. But it isn't anything ModalAI specific.
            Muqing CaoM Offline
            Muqing CaoM Offline
            Muqing Cao
            @Eric-Katzfey Thank you. Could you lead me to the part of the code that sends the odometry mavlink msg in voxl sdk? That would be very helpful.
              @Muqing-Cao Here you go: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/dev/src/vio_manager.c?ref_type=heads#L450
