  3. Requesting the factory original calibration files for ADK Ser#M2500000185
24 Posts 3 Posters 11.9k Views 1 Watching
    @latif You'll want to load the GPS specific px4 param file in order for "position" mode to use GPS position as opposed to VIO position.
    If you run voxl-configure-px4-params -w and navigate to EKF2_helpers you should be able to see the relevant options.
    L Offline
    L Offline
    latif
    @tom Now that I seem to have a good health check and the cameras working, I'd like to do the simplest possible first flight -- I went through the video directions in the Bootcamp, but wasn't able to go beyond trying to "arm" it.
    • I can't tell if it is binding or not. Tried the voxl-elrs -b, which seems to take it as the blue flashing lights become steady, but no movement of the propellers on trying to arm. I'm seeing a "model mismatch" message on the Commando8 Remote Controller. This shipped with the ADK and nothing has been done to it.
    • I need some help in flying it, indoors if that's ealier without GPS, but ultimately with GPS mission-planning, but I seem to be far from it, because I haven't done even a simple off-the-shelf type of flight.
    • This is my first time handling a drone of any kind, so I'm lacking some knowledge and could use some instructions to get this simple first flight job done.
    L 1 Reply Last reply
    • L latif
      L Offline
      L Offline
      latif
      @latif 88031482-bb56-49e6-887e-5152cc35af1e-image.png ![7999568d-997f-482e-9793-7c056611fb7b-image.png](Request Entity Too Large)
      Maxwell SchaeferM 1 Reply Last reply
      • L latif
        Maxwell SchaeferM Online
        Maxwell Schaefer
        wrote on last edited by Maxwell Schaefer
        #23
        @latif You should be able to disable the model match feature on the same screen which displayed the "Model Mismatch" error. By setting the model match id to 0, it will ignore the model match id set on the receiver and connect. The ExpressLRS documentation has more detail about how to set up the RC connection here.
        • Maxwell SchaeferM Maxwell Schaefer
          L Offline
          L Offline
          latif
          @Maxwell-Schaefer Thank you! I was able to set the model match to off using the controller screen.
