  3. voxl-camera-server failed to set pipe size: Cannot allocate memory
3 Posts 3 Posters 450 Views 1 Watching
  • P Offline
    P Offline
    paul.foley
    I have a C++ application for doing image processing of frames from voxl-camera-server. When I run it, within a few minutes, my application stops receiving frames and I see the following from the camera server about failing to set pipe size. Once that occurs, restarting my application or the camera server does not help. Rebooting is the only thing I have found that consistently gets the camera server back in a good state.
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: thread is locked to cores: 4 5 6 7
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: Connected to cpu-monitor
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: Skipping Camera: tracking_front, configuration marked disabled
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: Skipping Camera: hires_front, configuration marked disabled
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: Starting Camera: hires_down (id #2)
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: gbm_create_device(156): Info: backend name is: msm_drm
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: Skipping Camera: tracking_down, configuration marked disabled
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: ------ voxl-camera-server: Started 1 of 4 cameras
    Oct 03 14:11:21 m0054 voxl-camera-server[10625]: ------ voxl-camera-server: Camera server is now running
    Oct 03 14:16:48 m0054 voxl-camera-server[10625]: WARNING failed to set pipe size: Cannot allocate memory
    I'm on a Starling 2 Max. Below is the version information.
    voxl2:~$ voxl-version
    kernel:       #1 SMP PREEMPT Mon Nov 11 22:59:41 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.2.1
    voxl-suite:   1.4.1
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
    Last Updated: 2023-03-02 12:58:40
    List:
    libmodal-cv                               0.5.16
    libmodal-exposure                         0.1.3
    libmodal-pipe                             2.10.6
    libqrb5165-io                             0.4.9
    libvoxl-cci-direct                        0.2.5
    modalai-slpi                              1.1.19
    qrb5165-imu-server                        1.1.2
    qrb5165-rangefinder-server                0.1.4
    qrb5165-system-tweaks                     0.3.4
    voxl-camera-calibration                   0.5.9
    voxl-camera-server                        2.1.1
    voxl-configurator                         0.9.7
    voxl-cpu-monitor                          0.5.3
    voxl-elrs                                 0.4.1
    voxl-esc                                  1.5.1
    voxl-feature-tracker                      0.5.2
    voxl-io-server                            0.0.4
    voxl-lepton-server                        1.3.3
    voxl-lepton-tracker                       0.0.4
    voxl-logger                               0.4.9
    voxl-mavcam-manager                       0.5.7
    voxl-mavlink-server                       1.4.4
    voxl-modem                                1.1.5
    voxl-mpa-tools                            1.3.7
    voxl-open-vins                            0.4.16
    voxl-open-vins-server                     0.3.0
    voxl-opencv                               4.5.5-2
    voxl-osd                                  0.1.1
    voxl-portal                               0.7.5
    voxl-px4                                  1.14.0-2.0.94
    voxl-px4-params                           0.6.3
    voxl-qvio-server                          1.1.1
    voxl-reset-slpi                           0.0.1
    voxl-state-estimator                      0.0.4
    voxl-streamer                             0.7.5
    voxl-suite                                1.4.1
    voxl-tflite-server                        0.3.9
    voxl-utils                                1.4.4
    voxl-vision-hub                           1.8.17
    voxl-vtx                                  1.1.8
    voxl2-system-image                        1.8.02-r0
    As a test I created a very simple application that just connects to the camera pipe and logs each time it receives a frame. I've included the code below. This exhibits the same behavior as my more complex image processing application. Is there any issue with the way I am connecting to the pipe and processing frames?
    #include <atomic>
    #include <csignal>
    #include <cstdint>
    #include <iostream>
    #include <modal_pipe.h>
    #include <thread>
    #include <unistd.h>
    #include <mutex>
    #include <chrono>
    using namespace std::chrono_literals;
    std::string g_cameraString="hires_down_small_color";
    uint32_t g_frameCounter=0;
    uint32_t g_numIterations=100;
    std::mutex g_iterationMutex;
    bool g_keepRunning=true;
    // Use atomic to ensure safety in signal handlers
    std::atomic<bool> got_signal{false};
    void _camera_connect_cb( int   ch,
                                    void* context){
        printf("Connected to camera server\n");
    void _camera_disconnect_cb( int   ch,
                                       void* context) {
        fprintf(stderr, "Disonnected from camera server\n");
    void _camera_helper_cb( int ch,
                                  camera_image_metadata_t meta, char* frame,
                                  void* context) {
      std::cout<<__func__<<"Got notified of new frame #"<<g_frameCounter++<<"..."<<std::endl;
      //if pipe_client_bytes_in_pipe returns a positive number it means we have fallen behind and should skip this frame
      if (pipe_client_bytes_in_pipe(ch) > 0) {
                fprintf(
                    stderr,
                    "WARNING, skipping frame on channel %d due to frame backup\n",
                    ch);
            return;
          std::lock_guard<std::mutex> lg(g_iterationMutex);
          g_numIterations--;
      return;
    void cleanup()
      std::cout<<__func__<<std::endl;
      pipe_client_close_all();
    void connectToCameraPipe()
        // connect to camera pipe
        int ch = pipe_client_get_next_available_channel();
        pipe_client_set_connect_cb(ch, _camera_connect_cb, NULL);
        pipe_client_set_disconnect_cb(ch, _camera_disconnect_cb, NULL);
        pipe_client_set_camera_helper_cb(ch, _camera_helper_cb, NULL);
        //pipes all live under /run/mpa on VOXL
        std::string input_pipe_dir( "/run/mpa/");
        // add the name of the camera we want to get frames from
        std::string camera_pipe_path=input_pipe_dir;
        camera_pipe_path.append(g_cameraString);
        if (pipe_client_open(ch, camera_pipe_path.c_str(), "VoxlCameaFramePipeTest",
                             CLIENT_FLAG_EN_CAMERA_HELPER, 0)) {
            printf("%s | Failed to open pipe: %s \n", __func__, camera_pipe_path.c_str());
            return;
        else {
            printf("%s | Successfully opened pipe: %s \n", __func__, camera_pipe_path.c_str());
    void usage() {
        std::cout << "Usage: VoxlCameraFramePipeTest <options> \n"
                  << "Options:\n"
                  << "  -c <camera_name>   Name of the camera (string). Default value is "<<g_cameraString<<"\n"
                  << "  -n <iterations>    Number of iterations (unsigned integer). Default value is "<<g_numIterations<<"\n"
                  << "  -h                 Print this help message"<<std::endl;
    bool parseArgs(int argc, char** argv) {
      int opt;
      while ( (opt = getopt (argc, argv, "c:n:h") ) != -1)
        switch (opt)
          case 'c':
            g_cameraString=optarg;
            break;
          case 'n':
            g_numIterations=std::stoul(optarg);
            break;
          case 'h':
            usage();
            g_keepRunning=false;
            break;
          default:
            printf("%s | received unexpected argument.", __func__);
            usage();
            return false;
      return true;
    void signal_handler(int signal) {
        if (signal == SIGINT) {
            std::cout<<"Got signal"<<std::endl;
            got_signal = true;
    int main(int argc, char** argv)
      if(!parseArgs(argc, argv))
        return -1;
      if(g_keepRunning)
        // Register the signal handler
        std::signal(SIGINT, signal_handler);
        std::cout << "Press Ctrl+C to trigger SIGINT...\n";
        connectToCameraPipe();
        while (g_keepRunning && !got_signal) {
          std::this_thread::sleep_for(10ms);
            g_keepRunning=(g_numIterations>0);
          cleanup();
      return 0;
    Thank you,
    Paul
    • Riccardo BenedettiR Offline
      Riccardo Benedetti
      wrote on last edited by Riccardo Benedetti
      Same issue and same SDK here:
      voxl2:~$ voxl-camera-server
      detected system image 1.8.2
      using new imx412 defaults
      MISP awb str: auto
      Setting MISP AWB to AutoMISP awb str: auto
      Setting MISP AWB to Auto=================================================================
      configuration for 3 cameras:
      cam #0
          sensor type:         imx412
          isEnabled:           1
          camId:               1
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          0
          pre_width:           640
          pre_height:          480
          en_raw_preview:      0
          en_small_video:      1
          small_video_width:   1024
          small_video_height:  768
          en_large_video:      1
          large_video_width:   4056
          large_video_height:  3040
          en_misp:             0
          misp_width:          -1
          misp_height:         -1
          en_snapshot:         1
          snap_width:          4056
          snap_height:         3040
          exif_focal_length:   3.100000
          exif_focal_len_35mm_format:17
          exif_fnumber:        1.240000
          ae_mode:             isp
          msv_exposure_min_us: 20
          msv_exposure_max_us: 33000
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
          independent_exposure:0
      cam #1
          sensor type:         ar0144
          isEnabled:           0
          camId:               2
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          small_video_width:   -1
          small_video_height:  -1
          en_large_video:      0
          large_video_width:   -1
          large_video_height:  -1
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          exif_focal_length:   0.000000
          exif_focal_len_35mm_format:0
          exif_fnumber:        0.000000
          ae_mode:             lme_msv
          msv_exposure_max_us: 12000
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ar0144
          isEnabled:           0
          camId:               0
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      fsync_en:            1
      fsync_gpio:          109
      connected to mavlink pipe
      Starting Camera: hires (id #1)
      Skipping Camera: tracking_rear, configuration marked disabled
      ------ voxl-camera-server: Started 1 of 3 cameras
      PIPE NOT CREATED!!
      pipe 5 size achieved: -1 requested: 1048576
      Killed
      voxl2:~$
      kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
      hw platform:  M0054
      mach.var:     1.0.1
      voxl-suite:   1.4.1
      Any insight?
      • Riccardo BenedettiR Riccardo Benedetti
        MISP awb str: auto
        cam #0
            sensor type:         imx412
            isEnabled:           1
            camId:               1
            camId2:              -1
            fps:                 30
            en_rotate:           0
            en_rotate2:          0
            en_preview:          0
            pre_width:           640
            pre_height:          480
            en_raw_preview:      0
            en_small_video:      1
            en_large_video:      1
            en_misp:             0
            misp_width:          -1
            misp_height:         -1
            en_snapshot:         1
            snap_width:          4056
            snap_height:         3040
            ae_mode:             isp
            gain_min           : 54
            gain_max           : 8000
            standby_enabled:     0
            decimator:           1
        cam #1
            sensor type:         ar0144
            isEnabled:           0
            camId:               2
            camId2:              -1
            fps:                 30
            en_rotate:           0
            en_rotate2:          0
            en_preview:          1
            pre_width:           1280
            pre_height:          800
            en_raw_preview:      1
            en_small_video:      0
            en_large_video:      0
            en_misp:             1
            misp_width:          1280
            misp_height:         800
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             lme_msv
            gain_min           : 54
            gain_max           : 8000
            standby_enabled:     0
            decimator:           1
        cam #2
            sensor type:         ar0144
            isEnabled:           0
            camId:               0
            camId2:              -1
            fps:                 30
            en_rotate:           0
            en_rotate2:          0
            en_preview:          1
            pre_width:           1280
            pre_height:          800
            en_raw_preview:      1
            en_small_video:      0
            en_large_video:      0
            en_misp:             1
            misp_width:          1280
            misp_height:         800
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             lme_msv
            gain_min           : 54
            gain_max           : 8000
            standby_enabled:     0
            decimator:           1
        fsync_en:            1
        fsync_gpio:          109
        PIPE NOT CREATED!!
        Killed
        voxl2:~$
        hw platform:  M0054
        mach.var:     1.0.1
        voxl-suite:   1.4.1
        Any insight?
        Hi @Riccardo-Benedetti and @paul-foley ,
        This issue is not common. There is a potential condition (which we are going to look into) when a MPA client crashes and does not close the pipes properly, the MPA server side will keep the allocated resources open. If the client crashes repeatedly, eventually there will be no more memory for the Kernel to allocate for the new pipes.
        Please check to make sure that you have no client processes that are subscribing to image streams and are crashing and restarting (perhaps restarting automatically by systemd). It is possible that a process that is not your test app is misbehaving for some reason and is causing this memory leak by continuous crashing and re-starting.
        Also, what if you just use voxl-inspect-cam to inspect the single camera stream and no other camera clients running, does the same issue happen?
