  3. ESC issue: rotors not spinning
4 Posts 2 Posters 999 Views 1 Watching
  • Federico WyrwalF Offline
    Federico Wyrwal
    We had an initial successful testing of our brand new starling 2 drone. By the next flight we were unable to arm. After some debugging it was clear the esc is unresponsive. How should we proceed?
    voxl-esc spin logs:
    Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.19.125 aarch64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/advantage
     * Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
       just raised the bar for easy, resilient and secure K8s cluster deployment.
       https://ubuntu.com/engage/secure-kubernetes-at-the-edge
    This system has been minimized by removing packages and content that are
    not required on a system that users do not log into.
    To restore this content, you can run the 'unminimize' command.
    Last login: Fri Aug 15 14:53:00 2025 from 192.168.5.14
    system-image: 1.8.04-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          MRB-D0014-4-V1-C27-T7-M22-X0
    voxl-suite:   1.5.0
    current IP:   wlan0: ***
    voxl2:~$ voxl-esc spin
    enabling bridge
    detected voxl-px4 is enabled
    Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
    detected voxl-px4 is running, stopping it now
    Sending kill slpi command!
    bridge enabled
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.9
    VOXL Platform: M0054
    INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
    Updated baud rate to 230400
    WARNING: No ESC(s) detected
    ERROR:   voxl_uart_read_bytes: Bus '12' is not initialized
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600
    ERROR: not all ESCs found
    FAILED to ping ESCs when calling spin script
    disabling bridge
    re-enabling voxl-px4
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
    restarting voxl-px4
    bridge disabled
    EXITING VOXL-ESC WITH ERROR
    voxl-mpa logs:
    voxl2:~$ voxl-configure-mpa
                   Welcome to voxl-configure-mpa!
    VOXL is currently thinks it is in the following hardware:
    family code:   MRB-D0014 (starling-2 (D0014))
    compute board: 4 (voxl2)
    hw version:    1
    cam config:    27
    modem config:  22 (M0141 w/ Alfa Networks WiFi Dongle AWUS036EACS)
    tx config:     7 (elrs_beta_fpv)
    extras config: 0 (none)
    If this doesn't look right, quit and run voxl-configure-sku to
    set it correctly. Then run voxl-configure-mpa again.
    Continue? y/n: y
    Continuing
    No handling specified for Modem Num: 22
    No handling specified for Misc Num: 0
    No custom voxl-streamer mods for: 27
    No custom modem mods for: 22
    About to Execute:
    systemctl enable voxl-wait-for-fs
    systemctl start voxl-wait-for-fs
    systemctl disable voxl-static-ip
    voxl-configure-extrinsics D0014_Starling_2
    voxl-configure-vio-cams tracking_front_down_rear
    voxl-configure-cameras 27
    voxl-configure-cpu-monitor factory_enable
    voxl-configure-qvio disable
    voxl-configure-dfs factory_disable
    voxl-configure-tag-detector factory_disable
    voxl-configure-tflite factory_disable
    voxl-configure-vision-hub factory_enable
    voxl-configure-mavlink-server factory_enable
    voxl-configure-portal enable
    voxl-configure-lepton disable
    voxl-configure-lepton-tracker disable
    voxl-configure-uvc disable
    voxl-configure-streamer factory_enable
    voxl-configure-modem disable
    voxl-configure-mavcam factory_enable
    voxl-configure-rangefinders 1_downward_on_m0173
    voxl-configure-vtx --disable
    voxl-configure-vrx --disable
    voxl-configure-state-estimator disable
    voxl-configure-osd disable
    voxl-configure-imu factory_enable
    voxl-configure-flow-server disable
    voxl-configure-feature-tracker disable
    voxl-configure-open-vins factory_enable
    systemctl stop voxl-px4
    systemctl disable voxl-px4
    sleep 3
    voxl-esc setup_d0014_starling_2
    voxl-elrs configure
    rm -f /data/px4/param/parameters
    voxl-configure-px4 crsf_gps_noapm
    systemctl stop voxl-mavlink-server
    sleep 1
    voxl-configure-px4-params --non-interactive --platform MRB-D0014
    set_px4_conf_param RC CRSF_RAW
    executing: systemctl enable voxl-wait-for-fs
    Success!
    executing: systemctl start voxl-wait-for-fs
    Success!
    executing: systemctl disable voxl-static-ip
    Success!
    executing: voxl-configure-extrinsics D0014_Starling_2
    wiping old extrinsic config file
    copying /usr/share/modalai/extrinsic_configs/D0014_Starling_2.conf to /etc/modalai/extrinsics.conf
    done configuring extrinsics
    you can check what was set by running voxl-inspect-extrinsics --all
    Success!
    executing: voxl-configure-vio-cams tracking_front_down_rear
    wiping old vio-cam config file
    copying /usr/share/modalai/vio_cam_configs/tracking_front_down_rear.conf to /etc/modalai/vio_cams.conf
    done configuring vio-cams
    you can check what was set by running voxl-inspect-vio-cams
    Success!
    executing: voxl-configure-cameras 27
    Camera Configuration: 27
    camera server config helper list:
    tracking_front:ar0144:0:rotate:
    hires:imx412:1:
    tracking_rear:ar0144:2:rotate:
    tof:pmd-tof-liow2:3:
    tracking_down:ar0144:4:
    driver binary list:
    /usr/share/modalai/chi-cdk/ar0144-combo/com.qti.sensormodule.ar0144_combo_0.bin
    /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_1.bin
    /usr/share/modalai/chi-cdk/ar0144-fsin/com.qti.sensormodule.ar0144_fsin_2.bin
    /usr/share/modalai/chi-cdk/irs2975c/com.qti.sensormodule.irs2975c_3.bin
    /usr/share/modalai/chi-cdk/ar0144-combo/com.qti.sensormodule.ar0144_combo_6.bin
    calling camera-server-config-helper tracking_front:ar0144:0:rotate: hires:imx412:1: tracking_rear:ar0144:2:rotate: tof:pmd-tof-liow2:3: tracking_down:ar0144:4:
    detected system image 1.8.4
    using new imx412 defaults
    MISP awb str: auto
    Setting MISP AWB to Auto
    MISP channels enabled in defaults : 0
    ERROR: object missing misp_channels
    ERROR:   Reading config file: multiple cameras with id: 0
    FAILED TO WRITE CONFIG TO DISK
    camera-server-config-helper failed on attempt 1
    MISP awb str: auto
    MISP awb str: auto
    MISP awb str: auto
    successfully wrote this camera config to disk:
    configuration for 5 cameras:
    cam #0
        sensor type:         ar0144
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           1
        en_rotate2:          1
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             lme_msv
        msv_exposure_min_us: 20
        msv_exposure_max_us: 12000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    cam #1
        sensor type:         imx412
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4056
        large_video_height:  3040
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         1
        snap_width:          4056
        snap_height:         3040
        exif_focal_length:   3.100000
        exif_focal_len_35mm_format:17
        exif_fnumber:        1.240000
        ae_mode:             isp
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ar0144
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 30
        en_rotate:           1
        en_rotate2:          1
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #3
        sensor type:         pmd-tof-liow2
        isEnabled:           1
        camId:               3
        camId2:              -1
        fps:                 10
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           240
        pre_height:          1629
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        msv_exposure_min_us: 0
        msv_exposure_max_us: 6000
        gain_min           : 0
        gain_max           : 0
        standby_enabled:     0
        decimator:           5
    cam #4
        sensor type:         ar0144
        isEnabled:           1
        camId:               4
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    fsync_en:            0
    fsync_gpio:          109
    camera_server_config_helper is done
    camera-server-config-helper succeeded on attempt 2
    setting gpio pin 109 for fsync
    enabling fsync pin
    copying required camera drivers in place
    enabling voxl-camera-server
    Done Configuring Cameras
    Please power cycle VOXL to load new drivers
    camera server will start on next reboot
    Success!
    executing: voxl-configure-cpu-monitor factory_enable
    wiping old config file
    Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
    enabling  voxl-cpu-monitor systemd service
    Done configuring voxl-cpu-monitor
    Success!
    executing: voxl-configure-qvio disable
    disabling voxl-qvio-server systemd service
    stopping voxl-qvio-server systemd service
    Done configuring voxl-qvio-server
    Success!
    executing: voxl-configure-dfs factory_disable
    Creating new config file: /etc/modalai/voxl-dfs-server.conf
    disabling voxl-dfs-server systemd service
    stopping voxl-dfs-server systemd service
    Done configuring voxl-dfs-server
    Success!
    executing: voxl-configure-tag-detector factory_disable
    Creating new config file: /etc/modalai/voxl-tag-detector.conf
    disabling voxl-tag-detector systemd service
    stopping voxl-tag-detector systemd service
    Done configuring voxl-tag-detector
    Success!
    executing: voxl-configure-tflite factory_disable
    Creating new config file: /etc/modalai/voxl-tflite-server.conf
    The config file was modified during parsing, saving the changes to disk
    disabling voxl-tflite-server systemd service
    stopping voxl-tflite-server systemd service
    Done configuring voxl-tflite-server
    Success!
    executing: voxl-configure-vision-hub factory_enable
    Created new json file: /etc/modalai/voxl-vision-hub.conf
    The JSON config file data was modified during parsing, saving the changes to disk
    enabling  voxl-vision-hub systemd service
    Done configuring voxl-vision-hub
    service will start on next reboot
    Success!
    executing: voxl-configure-mavlink-server factory_enable
    Created new json file: /etc/modalai/voxl-mavlink-server.conf
    enabling  voxl-mavlink-server systemd service
    Done configuring voxl-mavlink-server
    Success!
    executing: voxl-configure-portal enable
    enabling  voxl-portal systemd service
    Done configuring voxl-portal
    Success!
    executing: voxl-configure-lepton disable
    disabling voxl-lepton-server systemd service
    stopping voxl-lepton-server systemd service
    Done configuring voxl-lepton-server
    Success!
    executing: voxl-configure-lepton-tracker disable
    disabling voxl-lepton-tracker systemd service
    stopping voxl-lepton-tracker systemd service
    Done configuring voxl-lepton-tracker
    Success!
    executing: voxl-configure-uvc disable
    disabling voxl-uvc-server systemd service
    stopping voxl-uvc-server systemd service
    Done configuring voxl-uvc-server
    Success!
    executing: voxl-configure-streamer factory_enable
    Creating new config file: /etc/modalai/voxl-streamer.conf
    writing /etc/modalai/voxl-streamer.conf to disk
    parsed config file
    enabling  voxl-streamer systemd service
    Done configuring voxl-streamer, it will start on next reboot
    Success!
    executing: voxl-configure-modem disable
    disabling voxl-modem systemd service
    stopping voxl-modem systemd service
    Done configuring voxl-modem
    Success!
    executing: voxl-configure-mavcam factory_enable
    Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
    writing /etc/modalai/voxl-mavcam-manager.conf to disk
    enabling  voxl-mavcam-manager systemd service
    Done configuring voxl-mavcam-manager
    It will start automatically on the next reboot
    Success!
    executing: voxl-configure-rangefinders 1_downward_on_m0173
    creating new config file for 1 downward TOF without multiplexer
    DONE
    enabling  voxl-rangefinder-server systemd service
    Done configuring voxl-rangefinder-server
    Success!
    executing: voxl-configure-vtx --disable
    Disabling voxl-vtx systemd service
    Detected kernel version: 4.19.125
    Default 88XXau kernel module already loaded
    Success!
    executing: voxl-configure-vrx --disable
    Success!
    executing: voxl-configure-state-estimator disable
    disabling voxl-state-estimator systemd service
    stopping voxl-state-estimator systemd service
    Done configuring voxl-state-estimator
    Success!
    executing: voxl-configure-osd disable
    disabling voxl-osd systemd service
    stopping voxl-osd systemd service
    Done configuring voxl-osd
    Success!
    executing: voxl-configure-imu factory_enable
    Creating new config file: /etc/modalai/voxl-imu-server.conf
    enabling  voxl-imu-server systemd service
    Done configuring voxl-imu-server
    Success!
    executing: voxl-configure-flow-server disable
    disabling voxl-flow-server systemd service
    stopping voxl-flow-server systemd service
    Done configuring voxl-flow-server
    Success!
    executing: voxl-configure-feature-tracker disable
    disabling voxl-feature-tracker systemd service
    stopping voxl-feature-tracker systemd service
    Done configuring voxl-feature-tracker
    Success!
    executing: voxl-configure-open-vins factory_enable
    /usr/bin/voxl-configure-open-vins: line 1: #!/bin/bash: No such file or directory
    Setting printing level to: SILENT
    Creating new config file: /etc/modalai/voxl-open-vins-server.conf
    QUIT REQUESTED
    Exiting Cleanly
    enabling  voxl-open-vins-server systemd service
    Please recycle power to reflect changes
    Done configuring voxl-open-vins-server
    Success!
    executing: systemctl stop voxl-px4
    Success!
    executing: systemctl disable voxl-px4
    Success!
    executing: sleep 3
    Success!
    executing: voxl-esc setup_d0014_starling_2
    enabling bridge
    bridge enabled
    [INFO] Setting CPU to performance mode
    [INFO] Scanning for ESC...
    successfully pinged ESCs
    [ERROR] Unknown board detected:
    disabling bridge
    bridge disabled
    first try failed, executing a second time: voxl-esc setup_d0014_starling_2
    enabling bridge
    bridge enabled
    disabling bridge
    bridge disabled
    FAILED TO EXECUTE: voxl-esc setup_d0014_starling_2
    executing: voxl-elrs configure
    Uploading config!
    Selected firmware image:
    BETAFPV 900MHz RX | v3.2.1.2
    ELRS Receiver "BETAFPV 900RX" already up to date!
    Setting pwm channels...
    Success!
    Success!
    executing: rm -f /data/px4/param/parameters
    Success!
    executing: voxl-configure-px4 crsf_gps_noapm
    enabling  voxl-px4 systemd service
    Done configuring voxl-px4
    Success!
    executing: systemctl stop voxl-mavlink-server
    Success!
    executing: sleep 1
    Success!
    executing: voxl-configure-px4-params --non-interactive --platform MRB-D0014
    [INFO] Voxl-px4 not currently running.
    [INFO] Starting voxl-px4 service...
    [INFO] Voxl-px4 started successfully!
    This process will do the following:
    1. Load the following param files:
    platforms/VOXL_2_defaults.params
    platforms/D0014_Starling_2.params
    EKF2_helpers/vio_gps_baro.params
    EKF2_helpers/exposed_baro.params
    battery_helpers/Amprius_18650_2s.params
    other_helpers/starling_2_indoor_position.params
    radio_helpers/Commando_8.params
    2. Restore calibration params
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/VOXL_2_defaults.params
    [INFO] Scanning currently loaded parameters...
    The following parameters about to be loaded differ from those currently loaded:
    	NAME    		CURRENT    	NEW
    [1]	IMU_GYRO_RATEMAX    	400.0		800.0
    [2]	CBRK_SUPPLY_CHK    	0.0		894281.0
    [3]	COM_ARM_SDCARD    	1.0		0.0
    [4]	COM_CPU_MAX    		95.0		-1.0
    [5]	MAV_TYPE    		0.0		2.0
    [6]	SYS_AUTOSTART    	0.0		4001.0
    [7]	SDLOG_PROFILE    	1.0		129.0
    [8]	EKF2_REQ_SACC    	0.5		1.5
    [9]	EKF2_REQ_GPS_H    	10.0		5.0
    [10]	COM_KILL_DISARM    	5.0		0.0
    [INFO] Setting params...
    [INFO] PX4 parameter configuration successful!
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/D0014_Starling_2.params
    	NAME    		CURRENT    	NEW
    [1]	BAT_AVRG_CURRENT    	15.0		4.3
    [2]	MPC_THR_HOVER    	0.5		0.34
    [3]	THR_MDL_FAC    		0.0		0.9
    [4]	VOXL_ESC_RPM_MIN    	5500.0		2000.0
    [5]	MPC_THR_MAX    		1.0		0.6
    [6]	MPC_THR_MIN    		0.12		0.07
    [7]	MPC_MANTHR_MIN    	0.08		0.07
    [8]	VOXL_ESC_FUNC1    	0.0		102.0
    [9]	VOXL_ESC_FUNC2    	0.0		103.0
    [10]	VOXL_ESC_FUNC3    	0.0		101.0
    [11]	VOXL_ESC_FUNC4    	0.0		104.0
    [12]	VOXL_ESC_BAUD    	250000.0	2000000.0
    [13]	VOXL_ESC_CONFIG    	0.0		1.0
    [14]	VOXL_ESC_VLOG    	0.0		1.0
    [15]	EKF2_IMU_POS_X    	0.0		0.0043
    [16]	EKF2_IMU_POS_Y    	0.0		0.0073
    [17]	EKF2_IMU_POS_Z    	0.0		-0.016
    [18]	CA_ROTOR_COUNT    	0.0		4.0
    [19]	CA_ROTOR0_PX    	0.0		0.085
    [20]	CA_ROTOR0_PY    	0.0		0.0625
    [21]	CA_ROTOR1_PX    	0.0		-0.085
    [22]	CA_ROTOR1_PY    	0.0		-0.0625
    [23]	CA_ROTOR2_PX    	0.0		0.085
    [24]	CA_ROTOR2_PY    	0.0		-0.0625
    [25]	CA_ROTOR3_PX    	0.0		-0.085
    [26]	CA_ROTOR3_PY    	0.0		0.0625
    [27]	CA_ROTOR2_KM    	0.05		-0.05
    [28]	CA_ROTOR3_KM    	0.05		-0.05
    [29]	IMU_DGYRO_CUTOFF    	30.0		60.0
    [30]	IMU_ACCEL_CUTOFF    	30.0		80.0
    [31]	IMU_GYRO_CUTOFF    	40.0		80.0
    [32]	IMU_GYRO_DNF_EN    	0.0		1.0
    [33]	MC_ROLL_CUTOFF    	0.0		30.0
    [34]	MC_PITCH_CUTOFF    	0.0		30.0
    [35]	MC_YAW_CUTOFF    	0.0		10.0
    [36]	MC_ROLL_P    		6.5		16.0
    [37]	MC_ROLLRATE_P    	0.15		0.072
    [38]	MC_ROLLRATE_I    	0.2		0.171
    [39]	MC_ROLLRATE_D    	0.003		0.0009
    [40]	MC_PITCH_P    		6.5		16.0
    [41]	MC_PITCHRATE_P    	0.15		0.097
    [42]	MC_PITCHRATE_I    	0.2		0.228
    [43]	MC_PITCHRATE_D    	0.003		0.0011
    [44]	MC_YAWRATE_P    	0.2		0.15
    [45]	MC_YAWRATE_I    	0.1		0.5
    [46]	MC_ROLLRATE_MAX    	220.0		130.0
    [47]	MC_PITCHRATE_MAX    	220.0		130.0
    [48]	MC_YAWRATE_MAX    	200.0		150.0
    [49]	MPC_TKO_RAMP_T    	3.0		1.0
    [50]	COM_SPOOLUP_TIME    	1.0		2.0
    [51]	LNDMC_ROT_MAX    	20.0		30.0
    [52]	LNDMC_TRIG_TIME    	1.0		0.5
    [53]	COM_DISARM_LAND    	2.0		0.1
    [54]	COM_DISARM_PRFLT    	10.0		20.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/vio_gps_baro.params
    	NAME    		CURRENT    	NEW
    [1]	EKF2_RNG_DELAY    	5.0		50.0
    [2]	EKF2_HGT_REF    	1.0		0.0
    [3]	EKF2_EV_QMIN    	0.0		1.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/exposed_baro.params
    	NAME    		CURRENT    	NEW
    [1]	EKF2_BARO_NOISE    	3.5		3.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/battery_helpers/Amprius_18650_2s.params
    	NAME    		CURRENT    	NEW
    [1]	BAT1_N_CELLS    	0.0		2.0
    [2]	BAT1_R_INTERNAL    	0.005		0.022
    [3]	BAT1_CAPACITY    	-1.0		3950.0
    [4]	BAT1_V_CHARGED    	4.05		4.1
    [5]	BAT1_V_EMPTY    	3.6		2.8
    [6]	BAT_CRIT_THR    	0.07		0.1
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/other_helpers/starling_2_indoor_position.params
    	NAME    		CURRENT    	NEW
    [1]	MPC_YAW_EXPO    	0.6		0.3
    [2]	MPC_XY_MAN_EXPO    	0.6		0.45
    [3]	MPC_Z_MAN_EXPO    	0.6		0.1
    [4]	MPC_JERK_MAX    	8.0		40.0
    [5]	MPC_TILTMAX_AIR    	45.0		30.0
    [6]	MPC_ACC_HOR_MAX    	5.0		1000.0
    [7]	MPC_ACC_UP_MAX    	4.0		3.0
    [8]	MPC_HOLD_MAX_XY    	0.8		0.0
    [9]	MPC_HOLD_MAX_Z    	0.6		0.0
    [10]	MPC_VEL_MANUAL    	10.0		3.0
    [11]	MPC_XY_VEL_MAX    	12.0		3.0
    [12]	MPC_XY_CRUISE    	5.0		3.0
    [13]	MPC_Z_VEL_MAX_DN    	1.5		1.0
    [14]	MPC_Z_V_AUTO_DN    	1.5		1.0
    [15]	MPC_Z_VEL_MAX_UP    	3.0		1.0
    [16]	MPC_Z_V_AUTO_UP    	3.0		1.0
    [17]	MPC_LAND_SPEED    	0.7		1.0
    [18]	MPC_XY_P    		0.95		3.5
    [19]	MPC_XY_VEL_P_ACC    	1.8		3.0
    [20]	MPC_XY_VEL_I_ACC    	0.4		0.1
    [21]	MPC_XY_VEL_D_ACC    	0.2		0.0
    [22]	MPC_Z_P    		1.0		5.0
    [23]	MPC_Z_VEL_P_ACC    	4.0		8.0
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/radio_helpers/Commando_8.params
    	NAME    		CURRENT    	NEW
    [1]	RC_CHAN_CNT    		0.0		16.0
    [2]	RC_MAP_ROLL    		0.0		1.0
    [3]	RC_MAP_PITCH    	0.0		2.0
    [4]	RC_MAP_THROTTLE    	0.0		3.0
    [5]	RC_MAP_YAW    		0.0		4.0
    [6]	RC_MAP_KILL_SW    	0.0		5.0
    [7]	RC_MAP_FLTMODE    	0.0		6.0
    [8]	COM_FLTMODE1    	-1.0		0.0
    [9]	COM_FLTMODE2    	-1.0		0.0
    [10]	COM_FLTMODE3    	-1.0		2.0
    [11]	COM_FLTMODE4    	-1.0		2.0
    [12]	COM_FLTMODE5    	-1.0		7.0
    [13]	COM_FLTMODE6    	-1.0		7.0
    [14]	RC5_MAX    		2000.0		1988.0
    [15]	RC5_MIN    		1000.0		1011.0
    [16]	RC6_MAX    		2000.0		1988.0
    [17]	RC6_MIN    		1000.0		1011.0
    [18]	RC7_MAX    		2000.0		1988.0
    [19]	RC7_MIN    		1000.0		1011.0
    [20]	RC8_MAX    		2000.0		1988.0
    [21]	RC8_MIN    		1000.0		1011.0
    [INFO] Loading file: /data/px4/param/parameters_gyro.cal
    	NAME    		CURRENT    	NEW
    [1]	CAL_GYRO0_ID    	0.0		2490378.0
    [2]	CAL_GYRO0_PRIO    	-1.0		50.0
    [3]	CAL_GYRO0_XOFF    	0.0		0.0005
    [4]	CAL_GYRO0_YOFF    	0.0		0.0129
    [5]	CAL_GYRO0_ZOFF    	0.0		0.0078
    [INFO] Trimming duplicate parameters...
    [INFO] Loading file: /data/px4/param/parameters_acc.cal
    	NAME    		CURRENT    	NEW
    [1]	CAL_ACC0_ID    		0.0		2490378.0
    [2]	CAL_ACC0_PRIO    	-1.0		50.0
    [3]	CAL_ACC0_XOFF    	0.0		0.0067
    [4]	CAL_ACC0_YOFF    	0.0		0.0747
    [5]	CAL_ACC0_ZOFF    	0.0		0.0884
    [INFO] Loading file: /data/px4/param/parameters_level.cal
    	NAME    		CURRENT    	NEW
    [1]	SENS_BOARD_X_OFF    	0.0		-0.3481
    [2]	SENS_BOARD_Y_OFF    	0.0		0.087
    [INFO] Loading file: /data/px4/param/parameters_mag.cal
    	NAME    		CURRENT    	NEW
    [1]	CAL_MAG0_ID    		0.0		527625.0
    [2]	CAL_MAG0_PRIO    	-1.0		75.0
    [3]	CAL_MAG0_XOFF    	0.0		0.0741
    [4]	CAL_MAG0_YOFF    	0.0		0.0822
    [5]	CAL_MAG0_ZOFF    	0.0		0.1073
    [6]	CAL_MAG0_XSCALE    	1.0		1.0064
    [7]	CAL_MAG0_YSCALE    	1.0		1.0357
    [8]	CAL_MAG0_ZSCALE    	1.0		0.9691
    [9]	CAL_MAG0_XODIAG    	0.0		-0.0151
    [10]	CAL_MAG0_YODIAG    	0.0		-0.0273
    [11]	CAL_MAG0_ZODIAG    	0.0		0.0054
    [12]	CAL_MAG0_ROT    	-1.0		0.0
    [INFO] Loading file: /data/px4/param/parameters_rc.cal
    [INFO] No difference in parameters was detected.
    [INFO] Loading file: /data/px4/param/parameters_baro_tc.cal
    	NAME    		CURRENT    	NEW
    [1]	TC_B_ENABLE    		0.0		1.0
    [2]	TC_B0_ID    		0.0		12018473.0
    [3]	TC_B0_TREF    		40.0		62.77
    [4]	TC_B0_TMIN    		5.0		55.48
    [5]	TC_B0_TMAX    		75.0		70.07
    [6]	TC_B0_X0    		0.0		0.0957
    [7]	TC_B0_X1    		0.0		-2.9135
    [INFO] Done configuring for platform MRB-D0014
    [INFO] make sure to fully power cycle VOXL before flying.
    Success!
    executing: set_px4_conf_param RC CRSF_RAW
    Success!
             FAILED TO EXECUTE the following steps:
          Encountered Problems Configuring MPA Services :-/
            Some Services may not start up on next reboot
    Calibration File Status:
    Present /data/modalai/voxl-imu-server.cal
    Present /data/modalai/opencv_tracking_front_intrinsics.yml
    Present /data/modalai/opencv_tracking_down_intrinsics.yml
    Present /data/modalai/opencv_tracking_rear_intrinsics.yml
    Present /data/px4/param/parameters_gyro.cal
    Present /data/px4/param/parameters_acc.cal
    Present /data/px4/param/parameters_level.cal
    Present /data/px4/param/parameters_baro_tc.cal
    Present /data/px4/param/parameters_mag.cal
    All Required Calibration Files Present
                    PLEASE POWER CYCLE YOUR VOXL
    • Federico WyrwalF Federico Wyrwal
      voxl-esc spin logs:
      hw platform:  M0054
      mach.var:     1.0.1
      voxl-suite:   1.5.0
      enabling bridge
      bridge enabled
      [GCC 8.4.0]
      disabling bridge
      restarting voxl-px4
      bridge disabled
      voxl-mpa logs:
      hw version:    1
      cam config:    27
      Continue? y/n: y
      Continuing
      About to Execute:
      sleep 3
      voxl-elrs configure
      sleep 1
      Success!
      Success!
      Success!
      Success!
      Success!
      hires:imx412:1:
      driver binary list:
      MISP awb str: auto
      MISP awb str: auto
      MISP awb str: auto
      MISP awb str: auto
      cam #0
          sensor type:         ar0144
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 30
          en_rotate:           1
          en_rotate2:          1
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      cam #1
          sensor type:         imx412
          isEnabled:           1
          camId:               1
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          0
          pre_width:           640
          pre_height:          480
          en_raw_preview:      0
          en_small_video:      1
          en_large_video:      1
          en_misp:             0
          misp_width:          -1
          misp_height:         -1
          en_snapshot:         1
          snap_width:          4056
          snap_height:         3040
          ae_mode:             isp
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ar0144
          isEnabled:           1
          camId:               2
          camId2:              -1
          fps:                 30
          en_rotate:           1
          en_rotate2:          1
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      cam #3
          isEnabled:           1
          camId:               3
          camId2:              -1
          fps:                 10
          en_rotate:           1
          en_rotate2:          0
          en_preview:          1
          pre_width:           240
          pre_height:          1629
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             0
          misp_width:          -1
          misp_height:         -1
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             off
          gain_min           : 0
          gain_max           : 0
          standby_enabled:     0
          decimator:           5
      cam #4
          sensor type:         ar0144
          isEnabled:           1
          camId:               4
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      fsync_en:            0
      fsync_gpio:          109
      enabling fsync pin
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      parsed config file
      Success!
      Success!
      Success!
      DONE
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      Success!
      QUIT REQUESTED
      Exiting Cleanly
      Success!
      Success!
      Success!
      executing: sleep 3
      Success!
      enabling bridge
      bridge enabled
      disabling bridge
      bridge disabled
      enabling bridge
      bridge enabled
      disabling bridge
      bridge disabled
      Uploading config!
      Success!
      Success!
      Success!
      Success!
      Success!
      executing: sleep 1
      Success!
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      	NAME    		CURRENT    	NEW
      Success!
      Success!
      @Federico-Wyrwal
      Did anything happen between flight 1 and flight 2 which could have damaged anything on the drone?
      When you power on your Starling 2, do you see blue lights blinking on the ESC? You can see the description of the expected behavior here : https://docs.modalai.com/voxl-escs/faq/#q-what-is-the-behavior-of-the-four-blue-on-board-leds. In the ESC datasheet (https://docs.modalai.com/voxl-mini-esc-datasheet/) you can see which side the LEDs are located and one of them is labeled, you should be able to spot the other three next to the each MCU.
      Do you hear a tone that the ESC typically makes (using motors) when the power is applied?
      Please check the integrity of the UART cable that connects the ESC to VOXL2.
      Federico WyrwalF 1 Reply Last reply
        @Federico-Wyrwal
        Federico Wyrwal
        wrote on last edited by Federico Wyrwal
        @Alex-Kushleyev
        The drone was untouched between the first and the next flight. To me the ESC looks clean and I detached and reattached the UART cable.
        The 4 leds on the ESC first flash at high frequency then the come the sounds, then those leds flash another 4 times then they remain off. I see the same behavior and sound on our healthy drone.
        The drone will be sent back for inspection today!
        Thanks for the reply!
          @Alex-Kushleyev
          @Federico-Wyrwal , thank you for the reply. More debugging would be needed to figure out the root cause and it looks like you already submitted an RMA for the inspection / repair, so we will take care of it. Thank you.
