    ESC issue: rotors not spinning
    • Federico WyrwalF
      Federico Wyrwal
      We had an initial successful testing of our brand new starling 2 drone. By the next flight we were unable to arm. After some debugging it was clear the esc is unresponsive. How should we proceed?
      voxl-esc spin logs:
      Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.19.125 aarch64)
       * Documentation:  https://help.ubuntu.com
       * Management:     https://landscape.canonical.com
       * Support:        https://ubuntu.com/advantage
       * Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
         just raised the bar for easy, resilient and secure K8s cluster deployment.
         https://ubuntu.com/engage/secure-kubernetes-at-the-edge
      This system has been minimized by removing packages and content that are
      not required on a system that users do not log into.
      To restore this content, you can run the 'unminimize' command.
      Last login: Fri Aug 15 14:53:00 2025 from 192.168.5.14
      system-image: 1.8.04-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
      hw platform:  M0054
      mach.var:     1.0.1
      SKU:          MRB-D0014-4-V1-C27-T7-M22-X0
      voxl-suite:   1.5.0
      current IP:   wlan0: ***
      voxl2:~$ voxl-esc spin
      enabling bridge
      detected voxl-px4 is enabled
      Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
      detected voxl-px4 is running, stopping it now
      Sending kill slpi command!
      bridge enabled
      [GCC 8.4.0]
      VOXL Platform: M0054
      INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
      Updated baud rate to 230400
      WARNING: No ESC(s) detected
      ERROR:   voxl_uart_read_bytes: Bus '12' is not initialized
      ERROR: not all ESCs found
      FAILED to ping ESCs when calling spin script
      disabling bridge
      re-enabling voxl-px4
      Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
      restarting voxl-px4
      bridge disabled
      EXITING VOXL-ESC WITH ERROR
      voxl-mpa logs:
      voxl2:~$ voxl-configure-mpa
                     Welcome to voxl-configure-mpa!
      VOXL is currently thinks it is in the following hardware:
      family code:   MRB-D0014 (starling-2 (D0014))
      compute board: 4 (voxl2)
      hw version:    1
      cam config:    27
      modem config:  22 (M0141 w/ Alfa Networks WiFi Dongle AWUS036EACS)
      tx config:     7 (elrs_beta_fpv)
      extras config: 0 (none)
      If this doesn't look right, quit and run voxl-configure-sku to
      set it correctly. Then run voxl-configure-mpa again.
      Continue? y/n: y
      Continuing
      No handling specified for Modem Num: 22
      No handling specified for Misc Num: 0
      No custom voxl-streamer mods for: 27
      No custom modem mods for: 22
      About to Execute:
      systemctl enable voxl-wait-for-fs
      systemctl start voxl-wait-for-fs
      systemctl disable voxl-static-ip
      voxl-configure-extrinsics D0014_Starling_2
      voxl-configure-vio-cams tracking_front_down_rear
      voxl-configure-cameras 27
      voxl-configure-cpu-monitor factory_enable
      voxl-configure-qvio disable
      voxl-configure-dfs factory_disable
      voxl-configure-tag-detector factory_disable
      voxl-configure-tflite factory_disable
      voxl-configure-vision-hub factory_enable
      voxl-configure-mavlink-server factory_enable
      voxl-configure-portal enable
      voxl-configure-lepton disable
      voxl-configure-lepton-tracker disable
      voxl-configure-uvc disable
      voxl-configure-streamer factory_enable
      voxl-configure-modem disable
      voxl-configure-mavcam factory_enable
      voxl-configure-rangefinders 1_downward_on_m0173
      voxl-configure-vtx --disable
      voxl-configure-vrx --disable
      voxl-configure-state-estimator disable
      voxl-configure-osd disable
      voxl-configure-imu factory_enable
      voxl-configure-flow-server disable
      voxl-configure-feature-tracker disable
      voxl-configure-open-vins factory_enable
      systemctl stop voxl-px4
      systemctl disable voxl-px4
      sleep 3
      voxl-esc setup_d0014_starling_2
      voxl-elrs configure
      rm -f /data/px4/param/parameters
      voxl-configure-px4 crsf_gps_noapm
      systemctl stop voxl-mavlink-server
      sleep 1
      voxl-configure-px4-params --non-interactive --platform MRB-D0014
      set_px4_conf_param RC CRSF_RAW
      executing: systemctl enable voxl-wait-for-fs
      Success!
      executing: systemctl start voxl-wait-for-fs
      Success!
      executing: systemctl disable voxl-static-ip
      Success!
      executing: voxl-configure-extrinsics D0014_Starling_2
      wiping old extrinsic config file
      copying /usr/share/modalai/extrinsic_configs/D0014_Starling_2.conf to /etc/modalai/extrinsics.conf
      done configuring extrinsics
      you can check what was set by running voxl-inspect-extrinsics --all
      Success!
      executing: voxl-configure-vio-cams tracking_front_down_rear
      wiping old vio-cam config file
      copying /usr/share/modalai/vio_cam_configs/tracking_front_down_rear.conf to /etc/modalai/vio_cams.conf
      done configuring vio-cams
      you can check what was set by running voxl-inspect-vio-cams
      Success!
      executing: voxl-configure-cameras 27
      Camera Configuration: 27
      camera server config helper list:
      tracking_front:ar0144:0:rotate:
      hires:imx412:1:
      tracking_rear:ar0144:2:rotate:
      tof:pmd-tof-liow2:3:
      tracking_down:ar0144:4:
      driver binary list:
      /usr/share/modalai/chi-cdk/ar0144-combo/com.qti.sensormodule.ar0144_combo_0.bin
      /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_1.bin
      /usr/share/modalai/chi-cdk/ar0144-fsin/com.qti.sensormodule.ar0144_fsin_2.bin
      /usr/share/modalai/chi-cdk/irs2975c/com.qti.sensormodule.irs2975c_3.bin
      /usr/share/modalai/chi-cdk/ar0144-combo/com.qti.sensormodule.ar0144_combo_6.bin
      calling camera-server-config-helper tracking_front:ar0144:0:rotate: hires:imx412:1: tracking_rear:ar0144:2:rotate: tof:pmd-tof-liow2:3: tracking_down:ar0144:4:
      detected system image 1.8.4
      using new imx412 defaults
      MISP awb str: auto
      Setting MISP AWB to Auto
      MISP channels enabled in defaults : 0
      ERROR: object missing misp_channels
      ERROR:   Reading config file: multiple cameras with id: 0
      FAILED TO WRITE CONFIG TO DISK
      camera-server-config-helper failed on attempt 1
      MISP awb str: auto
      MISP awb str: auto
      MISP awb str: auto
      successfully wrote this camera config to disk:
      configuration for 5 cameras:
      cam #0
          sensor type:         ar0144
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 30
          en_rotate:           1
          en_rotate2:          1
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          small_video_width:   -1
          small_video_height:  -1
          en_large_video:      0
          large_video_width:   -1
          large_video_height:  -1
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          exif_focal_length:   0.000000
          exif_focal_len_35mm_format:0
          exif_fnumber:        0.000000
          ae_mode:             lme_msv
          msv_exposure_min_us: 20
          msv_exposure_max_us: 12000
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
          independent_exposure:0
      cam #1
          sensor type:         imx412
          isEnabled:           1
          camId:               1
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          0
          pre_width:           640
          pre_height:          480
          en_raw_preview:      0
          en_small_video:      1
          small_video_width:   1024
          small_video_height:  768
          en_large_video:      1
          large_video_width:   4056
          large_video_height:  3040
          en_misp:             0
          misp_width:          -1
          misp_height:         -1
          en_snapshot:         1
          snap_width:          4056
          snap_height:         3040
          exif_focal_length:   3.100000
          exif_focal_len_35mm_format:17
          exif_fnumber:        1.240000
          ae_mode:             isp
          msv_exposure_max_us: 33000
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ar0144
          isEnabled:           1
          camId:               2
          camId2:              -1
          fps:                 30
          en_rotate:           1
          en_rotate2:          1
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      cam #3
          sensor type:         pmd-tof-liow2
          isEnabled:           1
          camId:               3
          camId2:              -1
          fps:                 10
          en_rotate:           1
          en_rotate2:          0
          en_preview:          1
          pre_width:           240
          pre_height:          1629
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             0
          misp_width:          -1
          misp_height:         -1
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             off
          msv_exposure_min_us: 0
          msv_exposure_max_us: 6000
          gain_min           : 0
          gain_max           : 0
          standby_enabled:     0
          decimator:           5
      cam #4
          sensor type:         ar0144
          isEnabled:           1
          camId:               4
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          1
          pre_width:           1280
          pre_height:          800
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_misp:             1
          misp_width:          1280
          misp_height:         800
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          gain_min           : 54
          gain_max           : 8000
          standby_enabled:     0
          decimator:           1
      fsync_en:            0
      fsync_gpio:          109
      camera_server_config_helper is done
      camera-server-config-helper succeeded on attempt 2
      setting gpio pin 109 for fsync
      enabling fsync pin
      copying required camera drivers in place
      enabling voxl-camera-server
      Done Configuring Cameras
      Please power cycle VOXL to load new drivers
      camera server will start on next reboot
      Success!
      executing: voxl-configure-cpu-monitor factory_enable
      wiping old config file
      Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
      enabling  voxl-cpu-monitor systemd service
      Done configuring voxl-cpu-monitor
      Success!
      executing: voxl-configure-qvio disable
      disabling voxl-qvio-server systemd service
      stopping voxl-qvio-server systemd service
      Done configuring voxl-qvio-server
      Success!
      executing: voxl-configure-dfs factory_disable
      Creating new config file: /etc/modalai/voxl-dfs-server.conf
      disabling voxl-dfs-server systemd service
      stopping voxl-dfs-server systemd service
      Done configuring voxl-dfs-server
      Success!
      executing: voxl-configure-tag-detector factory_disable
      Creating new config file: /etc/modalai/voxl-tag-detector.conf
      disabling voxl-tag-detector systemd service
      stopping voxl-tag-detector systemd service
      Done configuring voxl-tag-detector
      Success!
      executing: voxl-configure-tflite factory_disable
      Creating new config file: /etc/modalai/voxl-tflite-server.conf
      The config file was modified during parsing, saving the changes to disk
      disabling voxl-tflite-server systemd service
      stopping voxl-tflite-server systemd service
      Done configuring voxl-tflite-server
      Success!
      executing: voxl-configure-vision-hub factory_enable
      Created new json file: /etc/modalai/voxl-vision-hub.conf
      The JSON config file data was modified during parsing, saving the changes to disk
      enabling  voxl-vision-hub systemd service
      Done configuring voxl-vision-hub
      service will start on next reboot
      Success!
      executing: voxl-configure-mavlink-server factory_enable
      Created new json file: /etc/modalai/voxl-mavlink-server.conf
      enabling  voxl-mavlink-server systemd service
      Done configuring voxl-mavlink-server
      Success!
      executing: voxl-configure-portal enable
      enabling  voxl-portal systemd service
      Done configuring voxl-portal
      Success!
      executing: voxl-configure-lepton disable
      disabling voxl-lepton-server systemd service
      stopping voxl-lepton-server systemd service
      Done configuring voxl-lepton-server
      Success!
      executing: voxl-configure-lepton-tracker disable
      disabling voxl-lepton-tracker systemd service
      stopping voxl-lepton-tracker systemd service
      Done configuring voxl-lepton-tracker
      Success!
      executing: voxl-configure-uvc disable
      disabling voxl-uvc-server systemd service
      stopping voxl-uvc-server systemd service
      Done configuring voxl-uvc-server
      Success!
      executing: voxl-configure-streamer factory_enable
      Creating new config file: /etc/modalai/voxl-streamer.conf
      writing /etc/modalai/voxl-streamer.conf to disk
      parsed config file
      enabling  voxl-streamer systemd service
      Done configuring voxl-streamer, it will start on next reboot
      Success!
      executing: voxl-configure-modem disable
      disabling voxl-modem systemd service
      stopping voxl-modem systemd service
      Done configuring voxl-modem
      Success!
      executing: voxl-configure-mavcam factory_enable
      Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
      writing /etc/modalai/voxl-mavcam-manager.conf to disk
      enabling  voxl-mavcam-manager systemd service
      Done configuring voxl-mavcam-manager
      It will start automatically on the next reboot
      Success!
      executing: voxl-configure-rangefinders 1_downward_on_m0173
      creating new config file for 1 downward TOF without multiplexer
      DONE
      enabling  voxl-rangefinder-server systemd service
      Done configuring voxl-rangefinder-server
      Success!
      executing: voxl-configure-vtx --disable
      Disabling voxl-vtx systemd service
      Detected kernel version: 4.19.125
      Default 88XXau kernel module already loaded
      Success!
      executing: voxl-configure-vrx --disable
      Success!
      executing: voxl-configure-state-estimator disable
      disabling voxl-state-estimator systemd service
      stopping voxl-state-estimator systemd service
      Done configuring voxl-state-estimator
      Success!
      executing: voxl-configure-osd disable
      disabling voxl-osd systemd service
      stopping voxl-osd systemd service
      Done configuring voxl-osd
      Success!
      executing: voxl-configure-imu factory_enable
      Creating new config file: /etc/modalai/voxl-imu-server.conf
      enabling  voxl-imu-server systemd service
      Done configuring voxl-imu-server
      Success!
      executing: voxl-configure-flow-server disable
      disabling voxl-flow-server systemd service
      stopping voxl-flow-server systemd service
      Done configuring voxl-flow-server
      Success!
      executing: voxl-configure-feature-tracker disable
      disabling voxl-feature-tracker systemd service
      stopping voxl-feature-tracker systemd service
      Done configuring voxl-feature-tracker
      Success!
      executing: voxl-configure-open-vins factory_enable
      /usr/bin/voxl-configure-open-vins: line 1: #!/bin/bash: No such file or directory
      Setting printing level to: SILENT
      Creating new config file: /etc/modalai/voxl-open-vins-server.conf
      QUIT REQUESTED
      Exiting Cleanly
      enabling  voxl-open-vins-server systemd service
      Please recycle power to reflect changes
      Done configuring voxl-open-vins-server
      Success!
      executing: systemctl stop voxl-px4
      Success!
      executing: systemctl disable voxl-px4
      Success!
      executing: sleep 3
      Success!
      executing: voxl-esc setup_d0014_starling_2
      enabling bridge
      bridge enabled
      [INFO] Setting CPU to performance mode
      [INFO] Scanning for ESC...
      successfully pinged ESCs
      [ERROR] Unknown board detected:
      disabling bridge
      bridge disabled
      first try failed, executing a second time: voxl-esc setup_d0014_starling_2
      enabling bridge
      bridge enabled
      disabling bridge
      bridge disabled
      FAILED TO EXECUTE: voxl-esc setup_d0014_starling_2
      executing: voxl-elrs configure
      Uploading config!
      Selected firmware image:
      BETAFPV 900MHz RX | v3.2.1.2
      ELRS Receiver "BETAFPV 900RX" already up to date!
      Setting pwm channels...
      Success!
      Success!
      executing: rm -f /data/px4/param/parameters
      Success!
      executing: voxl-configure-px4 crsf_gps_noapm
      enabling  voxl-px4 systemd service
      Done configuring voxl-px4
      Success!
      executing: systemctl stop voxl-mavlink-server
      Success!
      executing: sleep 1
      Success!
      executing: voxl-configure-px4-params --non-interactive --platform MRB-D0014
      [INFO] Voxl-px4 not currently running.
      [INFO] Starting voxl-px4 service...
      [INFO] Voxl-px4 started successfully!
      This process will do the following:
      1. Load the following param files:
      platforms/VOXL_2_defaults.params
      platforms/D0014_Starling_2.params
      EKF2_helpers/vio_gps_baro.params
      EKF2_helpers/exposed_baro.params
      battery_helpers/Amprius_18650_2s.params
      other_helpers/starling_2_indoor_position.params
      radio_helpers/Commando_8.params
      2. Restore calibration params
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/VOXL_2_defaults.params
      [INFO] Scanning currently loaded parameters...
      The following parameters about to be loaded differ from those currently loaded:
      	NAME    		CURRENT    	NEW
      [1]	IMU_GYRO_RATEMAX    	400.0		800.0
      [2]	CBRK_SUPPLY_CHK    	0.0		894281.0
      [3]	COM_ARM_SDCARD    	1.0		0.0
      [4]	COM_CPU_MAX    		95.0		-1.0
      [5]	MAV_TYPE    		0.0		2.0
      [6]	SYS_AUTOSTART    	0.0		4001.0
      [7]	SDLOG_PROFILE    	1.0		129.0
      [8]	EKF2_REQ_SACC    	0.5		1.5
      [9]	EKF2_REQ_GPS_H    	10.0		5.0
      [10]	COM_KILL_DISARM    	5.0		0.0
      [INFO] Setting params...
      [INFO] PX4 parameter configuration successful!
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/D0014_Starling_2.params
      	NAME    		CURRENT    	NEW
      [1]	BAT_AVRG_CURRENT    	15.0		4.3
      [2]	MPC_THR_HOVER    	0.5		0.34
      [3]	THR_MDL_FAC    		0.0		0.9
      [4]	VOXL_ESC_RPM_MIN    	5500.0		2000.0
      [5]	MPC_THR_MAX    		1.0		0.6
      [6]	MPC_THR_MIN    		0.12		0.07
      [7]	MPC_MANTHR_MIN    	0.08		0.07
      [8]	VOXL_ESC_FUNC1    	0.0		102.0
      [9]	VOXL_ESC_FUNC2    	0.0		103.0
      [10]	VOXL_ESC_FUNC3    	0.0		101.0
      [11]	VOXL_ESC_FUNC4    	0.0		104.0
      [12]	VOXL_ESC_BAUD    	250000.0	2000000.0
      [13]	VOXL_ESC_CONFIG    	0.0		1.0
      [14]	VOXL_ESC_VLOG    	0.0		1.0
      [15]	EKF2_IMU_POS_X    	0.0		0.0043
      [16]	EKF2_IMU_POS_Y    	0.0		0.0073
      [17]	EKF2_IMU_POS_Z    	0.0		-0.016
      [18]	CA_ROTOR_COUNT    	0.0		4.0
      [19]	CA_ROTOR0_PX    	0.0		0.085
      [20]	CA_ROTOR0_PY    	0.0		0.0625
      [21]	CA_ROTOR1_PX    	0.0		-0.085
      [22]	CA_ROTOR1_PY    	0.0		-0.0625
      [23]	CA_ROTOR2_PX    	0.0		0.085
      [24]	CA_ROTOR2_PY    	0.0		-0.0625
      [25]	CA_ROTOR3_PX    	0.0		-0.085
      [26]	CA_ROTOR3_PY    	0.0		0.0625
      [27]	CA_ROTOR2_KM    	0.05		-0.05
      [28]	CA_ROTOR3_KM    	0.05		-0.05
      [29]	IMU_DGYRO_CUTOFF    	30.0		60.0
      [30]	IMU_ACCEL_CUTOFF    	30.0		80.0
      [31]	IMU_GYRO_CUTOFF    	40.0		80.0
      [32]	IMU_GYRO_DNF_EN    	0.0		1.0
      [33]	MC_ROLL_CUTOFF    	0.0		30.0
      [34]	MC_PITCH_CUTOFF    	0.0		30.0
      [35]	MC_YAW_CUTOFF    	0.0		10.0
      [36]	MC_ROLL_P    		6.5		16.0
      [37]	MC_ROLLRATE_P    	0.15		0.072
      [38]	MC_ROLLRATE_I    	0.2		0.171
      [39]	MC_ROLLRATE_D    	0.003		0.0009
      [40]	MC_PITCH_P    		6.5		16.0
      [41]	MC_PITCHRATE_P    	0.15		0.097
      [42]	MC_PITCHRATE_I    	0.2		0.228
      [43]	MC_PITCHRATE_D    	0.003		0.0011
      [44]	MC_YAWRATE_P    	0.2		0.15
      [45]	MC_YAWRATE_I    	0.1		0.5
      [46]	MC_ROLLRATE_MAX    	220.0		130.0
      [47]	MC_PITCHRATE_MAX    	220.0		130.0
      [48]	MC_YAWRATE_MAX    	200.0		150.0
      [49]	MPC_TKO_RAMP_T    	3.0		1.0
      [50]	COM_SPOOLUP_TIME    	1.0		2.0
      [51]	LNDMC_ROT_MAX    	20.0		30.0
      [52]	LNDMC_TRIG_TIME    	1.0		0.5
      [53]	COM_DISARM_LAND    	2.0		0.1
      [54]	COM_DISARM_PRFLT    	10.0		20.0
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/vio_gps_baro.params
      	NAME    		CURRENT    	NEW
      [1]	EKF2_RNG_DELAY    	5.0		50.0
      [2]	EKF2_HGT_REF    	1.0		0.0
      [3]	EKF2_EV_QMIN    	0.0		1.0
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/exposed_baro.params
      	NAME    		CURRENT    	NEW
      [1]	EKF2_BARO_NOISE    	3.5		3.0
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/battery_helpers/Amprius_18650_2s.params
      	NAME    		CURRENT    	NEW
      [1]	BAT1_N_CELLS    	0.0		2.0
      [2]	BAT1_R_INTERNAL    	0.005		0.022
      [3]	BAT1_CAPACITY    	-1.0		3950.0
      [4]	BAT1_V_CHARGED    	4.05		4.1
      [5]	BAT1_V_EMPTY    	3.6		2.8
      [6]	BAT_CRIT_THR    	0.07		0.1
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/other_helpers/starling_2_indoor_position.params
      	NAME    		CURRENT    	NEW
      [1]	MPC_YAW_EXPO    	0.6		0.3
      [2]	MPC_XY_MAN_EXPO    	0.6		0.45
      [3]	MPC_Z_MAN_EXPO    	0.6		0.1
      [4]	MPC_JERK_MAX    	8.0		40.0
      [5]	MPC_TILTMAX_AIR    	45.0		30.0
      [6]	MPC_ACC_HOR_MAX    	5.0		1000.0
      [7]	MPC_ACC_UP_MAX    	4.0		3.0
      [8]	MPC_HOLD_MAX_XY    	0.8		0.0
      [9]	MPC_HOLD_MAX_Z    	0.6		0.0
      [10]	MPC_VEL_MANUAL    	10.0		3.0
      [11]	MPC_XY_VEL_MAX    	12.0		3.0
      [12]	MPC_XY_CRUISE    	5.0		3.0
      [13]	MPC_Z_VEL_MAX_DN    	1.5		1.0
      [14]	MPC_Z_V_AUTO_DN    	1.5		1.0
      [15]	MPC_Z_VEL_MAX_UP    	3.0		1.0
      [16]	MPC_Z_V_AUTO_UP    	3.0		1.0
      [17]	MPC_LAND_SPEED    	0.7		1.0
      [18]	MPC_XY_P    		0.95		3.5
      [19]	MPC_XY_VEL_P_ACC    	1.8		3.0
      [20]	MPC_XY_VEL_I_ACC    	0.4		0.1
      [21]	MPC_XY_VEL_D_ACC    	0.2		0.0
      [22]	MPC_Z_P    		1.0		5.0
      [23]	MPC_Z_VEL_P_ACC    	4.0		8.0
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/radio_helpers/Commando_8.params
      	NAME    		CURRENT    	NEW
      [1]	RC_CHAN_CNT    		0.0		16.0
      [2]	RC_MAP_ROLL    		0.0		1.0
      [3]	RC_MAP_PITCH    	0.0		2.0
      [4]	RC_MAP_THROTTLE    	0.0		3.0
      [5]	RC_MAP_YAW    		0.0		4.0
      [6]	RC_MAP_KILL_SW    	0.0		5.0
      [7]	RC_MAP_FLTMODE    	0.0		6.0
      [8]	COM_FLTMODE1    	-1.0		0.0
      [9]	COM_FLTMODE2    	-1.0		0.0
      [10]	COM_FLTMODE3    	-1.0		2.0
      [11]	COM_FLTMODE4    	-1.0		2.0
      [12]	COM_FLTMODE5    	-1.0		7.0
      [13]	COM_FLTMODE6    	-1.0		7.0
      [14]	RC5_MAX    		2000.0		1988.0
      [15]	RC5_MIN    		1000.0		1011.0
      [16]	RC6_MAX    		2000.0		1988.0
      [17]	RC6_MIN    		1000.0		1011.0
      [18]	RC7_MAX    		2000.0		1988.0
      [19]	RC7_MIN    		1000.0		1011.0
      [20]	RC8_MAX    		2000.0		1988.0
      [21]	RC8_MIN    		1000.0		1011.0
      [INFO] Loading file: /data/px4/param/parameters_gyro.cal
      	NAME    		CURRENT    	NEW
      [1]	CAL_GYRO0_ID    	0.0		2490378.0
      [2]	CAL_GYRO0_PRIO    	-1.0		50.0
      [3]	CAL_GYRO0_XOFF    	0.0		0.0005
      [4]	CAL_GYRO0_YOFF    	0.0		0.0129
      [5]	CAL_GYRO0_ZOFF    	0.0		0.0078
      [INFO] Trimming duplicate parameters...
      [INFO] Loading file: /data/px4/param/parameters_acc.cal
      	NAME    		CURRENT    	NEW
      [1]	CAL_ACC0_ID    		0.0		2490378.0
      [2]	CAL_ACC0_PRIO    	-1.0		50.0
      [3]	CAL_ACC0_XOFF    	0.0		0.0067
      [4]	CAL_ACC0_YOFF    	0.0		0.0747
      [5]	CAL_ACC0_ZOFF    	0.0		0.0884
      [INFO] Loading file: /data/px4/param/parameters_level.cal
      	NAME    		CURRENT    	NEW
      [1]	SENS_BOARD_X_OFF    	0.0		-0.3481
      [2]	SENS_BOARD_Y_OFF    	0.0		0.087
      [INFO] Loading file: /data/px4/param/parameters_mag.cal
      	NAME    		CURRENT    	NEW
      [1]	CAL_MAG0_ID    		0.0		527625.0
      [2]	CAL_MAG0_PRIO    	-1.0		75.0
      [3]	CAL_MAG0_XOFF    	0.0		0.0741
      [4]	CAL_MAG0_YOFF    	0.0		0.0822
      [5]	CAL_MAG0_ZOFF    	0.0		0.1073
      [6]	CAL_MAG0_XSCALE    	1.0		1.0064
      [7]	CAL_MAG0_YSCALE    	1.0		1.0357
      [8]	CAL_MAG0_ZSCALE    	1.0		0.9691
      [9]	CAL_MAG0_XODIAG    	0.0		-0.0151
      [10]	CAL_MAG0_YODIAG    	0.0		-0.0273
      [11]	CAL_MAG0_ZODIAG    	0.0		0.0054
      [12]	CAL_MAG0_ROT    	-1.0		0.0
      [INFO] Loading file: /data/px4/param/parameters_rc.cal
      [INFO] No difference in parameters was detected.
      [INFO] Loading file: /data/px4/param/parameters_baro_tc.cal
      	NAME    		CURRENT    	NEW
      [1]	TC_B_ENABLE    		0.0		1.0
      [2]	TC_B0_ID    		0.0		12018473.0
      [3]	TC_B0_TREF    		40.0		62.77
      [4]	TC_B0_TMIN    		5.0		55.48
      [5]	TC_B0_TMAX    		75.0		70.07
      [6]	TC_B0_X0    		0.0		0.0957
      [7]	TC_B0_X1    		0.0		-2.9135
      [INFO] Done configuring for platform MRB-D0014
      [INFO] make sure to fully power cycle VOXL before flying.
      Success!
      executing: set_px4_conf_param RC CRSF_RAW
      Success!
               FAILED TO EXECUTE the following steps:
            Encountered Problems Configuring MPA Services :-/
              Some Services may not start up on next reboot
      Calibration File Status:
      Present /data/modalai/voxl-imu-server.cal
      Present /data/modalai/opencv_tracking_front_intrinsics.yml
      Present /data/modalai/opencv_tracking_down_intrinsics.yml
      Present /data/modalai/opencv_tracking_rear_intrinsics.yml
      Present /data/px4/param/parameters_gyro.cal
      Present /data/px4/param/parameters_acc.cal
      Present /data/px4/param/parameters_level.cal
      Present /data/px4/param/parameters_baro_tc.cal
      Present /data/px4/param/parameters_mag.cal
      All Required Calibration Files Present
                      PLEASE POWER CYCLE YOUR VOXL
        Alex Kushleyev ModalAI Team @Federico Wyrwal
        @Federico-Wyrwal
        Did anything happen between flight 1 and flight 2 which could have damaged anything on the drone?
        When you power on your Starling 2, do you see blue lights blinking on the ESC? You can see the description of the expected behavior here : https://docs.modalai.com/voxl-escs/faq/#q-what-is-the-behavior-of-the-four-blue-on-board-leds. In the ESC datasheet (https://docs.modalai.com/voxl-mini-esc-datasheet/) you can see which side the LEDs are located and one of them is labeled, you should be able to spot the other three next to the each MCU.
        Do you hear a tone that the ESC typically makes (using motors) when the power is applied?
        Please check the integrity of the UART cable that connects the ESC to VOXL2.
        Federico WyrwalF 1 Reply Last reply Reply Quote 0
        • Federico WyrwalF
          Federico Wyrwal @Alex Kushleyev
          The drone was untouched between the first and the next flight. To me the ESC looks clean and I detached and reattached the UART cable.
          The 4 leds on the ESC first flash at high frequency then the come the sounds, then those leds flash another 4 times then they remain off. I see the same behavior and sound on our healthy drone.
          The drone will be sent back for inspection today!
          Thanks for the reply!
            @Federico-Wyrwal , thank you for the reply. More debugging would be needed to figure out the root cause and it looks like you already submitted an RMA for the inspection / repair, so we will take care of it. Thank you.
