  2. VOXL Compute & Autopilot
  3. VOXL 2 IO
  4. Neopixel Integration with PX4
Scheduled Pinned Locked Moved VOXL 2 IO
3 Posts 2 Posters 1.5k Views 1 Watching
  • J Offline
    jakkkkobo
    Re: Neopixel GPIO control on VOXL2 SPI port
    Hello all,
    We have been trying to integrate Neopixel on io_0 and io_3 in PX4 to control with "led_control" and, in case not possible, with voxl-send-neopixel-cmd.
    However, with voxl-send-neopixel-cmd, we can't define color, just turn the RGB strip on or change the number of LEDs. When trying to use it on PX4 with "voxl-esc led -l 0x001", it does not run, due to the modal_io_bridge priority.
    system-image 1.7.8-M0054-14.1a-perf
    hx platform: M0054 1.0.0
    voxl-suite:1.3.2
    Thank you in advance for any help!
    Regards,
    Jacob
    • J jakkkkobo
      Hello all,
      voxl-suite:1.3.2
      Regards,
      Jacob
      @jakkkkobo ,
      The source code of voxl-send-neopixel-cmd test tool is here : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-io-server/-/blob/master/tools/voxl-send-neopixel-cmd.c
      The function that creates a binary packet (which is forwarded to the ESC via PX4) is here : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-io-server/-/blob/master/lib/modal_io.c#L181 . Basically you need to provide the following information to this function:
      • number of LEDs you are controlling
      • LED type (RGB or RGBW)
      • array of LED colors (3 bytes for each LED in case of RGB, or 4 bytes per LED for RGBW).
      • the array should contain all LED values ranging from 0-255, so if you had 3 LEDs and first should be red, second green and third blue (50% power), the LED color array would be : [127, 0, 0, 0, 127, 0, 0,0,127].
      • this function will create a packet with checksum and send it to PX4, and PX4 will forward the packet to the ESC.
      You can modify the voxl-send-neopixel-cmd to do what you need, maybe you can make it accept an array of LED color values via command line.
      I know the tool could have been more helpful. If you describe your use case, maybe I can help improve the voxl-send-neopixel-cmd tool.
      J 1 Reply Last reply
        @jakkkkobo ,
        jakkkkobo
        @Alex-Kushleyev ,
        Thank you for the clarification!
        We will change the service and see if it meets our needs.
        Regards,
        Jacob
