  3. VOXL2 NOT DETECTING APRIL TAG
apriltag
8 Posts 2 Posters 5.0k Views
  • T Offline
    T Offline
    taiwohazeez
    Hello support,
    I have an issue detecting apriltags with my voxl2 (starling 2), I looked at the documentation online to see how it works.
    I ran voxl-tag-detector, and i got this
    voxl2:/$ voxl-tag-detector
    loading tag-detector config file
    loading apriltag config file
    detector #0
    enable: 1
    input_pipe: tracking_front
    en_fast_mode: 1
    n_threads: 1
    en_undistortion: 1
    undistort_scale: 0.60
    overlay_name: tracking_tag_overlay
    lens_cal_file: /data/modalai/opencv_tracking_intrinsics.yml
    skip_n_frames: 5
    detector #1
    enable: 0
    input_pipe: stereo
    en_fast_mode: 1
    n_threads: 1
    en_undistortion: 1
    undistort_scale: 0.90
    overlay_name: stereo_tag_overlay
    lens_cal_file: /data/modalai/opencv_stereo_intrinsics.yml
    skip_n_frames: 5
    detector #2
    enable: 0
    input_pipe: extra
    en_fast_mode: 1
    n_threads: 1
    en_undistortion: 0
    undistort_scale: 1.00
    overlay_name: extra_tag_overlay
    lens_cal_file: /data/modalai/opencv_extra_intrinsics.yml
    skip_n_frames: 5
    default_size_m: 0.160
    #0:
    loc_type: unknown
    size_m: 0.400
    T_tag_wrt_fixed: 0.0 0.0 0.0
    R_tag_to_fixed: 0.0 -1.0 0.0
    1.0 0.0 0.0
    0.0 0.0 1.0
    found cam matrix with name 'M' for detector #0
    detector #0 is fisheye
    waiting for cam pipe tracking_front
    detector #0 connected to camera pipe tracking_front
    lens #0: fx:460.04 fy:460.58 cx:666.72 cy:382.58
    lens #0: fxrect:276.02 fyrect:276.35
    Then on another terminal, i ran voxl-inspect-detections -a tag_detections, but i keep getting unknown, can you help with what i might be doing wrong.
    Meanwhile, I have ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node running.
    KIndly assist @tom @teddy-zaremba
    Taiwo
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      Hi @taiwohazeez - can you paste the output? Usually you get NANS or unknown when the locations.txt file isnt filled out meaning the tag detector service is referencing an empty file. Once you paste the output of voxl-inspect-detections I will be able to give you better guidance.
      Zach
      T 1 Reply Last reply
        Zach
        T Offline
        T Offline
        taiwohazeez
        @Zachary-Lowell-0 thank you for your response, this is the output,
        Class Name Camera Class Confidence Detection Confidence Frame ID Timestamp(
        unknown nan nan 62 447765889248
        Taiwo
          Zachary Lowell 0
          Class confidence and detection confidence are pertinent towards voxl tflite server not voxl-tag-detector - are you sure this is the right output?
            T Offline
            T Offline
            taiwohazeez
            @Zachary-Lowell-0 yes, i copied that directly from the terminal after running this command voxl-inspect-detections -a tag_detections.
            • T taiwohazeez
              T Offline
              T Offline
              taiwohazeez
              @taiwohazeez @Zachary-Lowell-0 , please i am still waiting for a response, an advice on how to go about Apriltag detection on starling 2 would be greatly appreciated.
                Zachary Lowell 0
                @taiwohazeez I am not fully convinced you are running the right command still
                Running voxl-inspect-tag shoudl show the following headers:
                ID | XYZ | RPY | SIZE_M | CAM
                As shown in the code below:
                printf("\n"); printf("id:%3d name: %s\n", d.id, d.name); printf("XYZ: %6.2f %6.2f %6.2f \n", (double)d.T_tag_wrt_cam[0], (double)d.T_tag_wrt_cam[1], (double)d.T_tag_wrt_cam[2]); printf("RPY: %6.1f %6.1f %6.1f \n", (double)roll, (double)pitch, (double)yaw); printf("size_m: %4.2f latency_ms: %6.2f\n", (double)d.size_m, latency_ms); printf("cam: %s type: %s\n", d.cam, pipe_tag_location_type_to_string(d.loc_type)); printf("\n");
                https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector/-/blob/dev/clients/voxl-inspect-tags.c?ref_type=heads
                Just run voxl-inspect-tags and that will output the right data.
                Zach
                  Zachary Lowell 0
                  Detections is pertinent to voxl-tflite-server and onboard computer vision on yolo, NOT on april tags.
