    VOXL2 NOT DETECTING APRIL TAG
    AprilTag Relocalization
    1002
    • T
      taiwohazeez
      Hello support,
      I have an issue detecting apriltags with my voxl2 (starling 2), I looked at the documentation online to see how it works.
      I ran voxl-tag-detector, and i got this
      voxl2:/$ voxl-tag-detector
      loading tag-detector config file
      loading apriltag config file
      detector #0
      enable: 1
      input_pipe: tracking_front
      en_fast_mode: 1
      n_threads: 1
      en_undistortion: 1
      undistort_scale: 0.60
      overlay_name: tracking_tag_overlay
      lens_cal_file: /data/modalai/opencv_tracking_intrinsics.yml
      skip_n_frames: 5
      detector #1
      enable: 0
      input_pipe: stereo
      en_fast_mode: 1
      n_threads: 1
      en_undistortion: 1
      undistort_scale: 0.90
      overlay_name: stereo_tag_overlay
      lens_cal_file: /data/modalai/opencv_stereo_intrinsics.yml
      skip_n_frames: 5
      detector #2
      enable: 0
      input_pipe: extra
      en_fast_mode: 1
      n_threads: 1
      en_undistortion: 0
      undistort_scale: 1.00
      overlay_name: extra_tag_overlay
      lens_cal_file: /data/modalai/opencv_extra_intrinsics.yml
      skip_n_frames: 5
      default_size_m: 0.160
      #0:
      loc_type: unknown
      size_m: 0.400
      T_tag_wrt_fixed: 0.0 0.0 0.0
      R_tag_to_fixed: 0.0 -1.0 0.0
      1.0 0.0 0.0
      0.0 0.0 1.0
      found cam matrix with name 'M' for detector #0
      detector #0 is fisheye
      waiting for cam pipe tracking_front
      detector #0 connected to camera pipe tracking_front
      lens #0: fx:460.04 fy:460.58 cx:666.72 cy:382.58
      lens #0: fxrect:276.02 fyrect:276.35
      Then on another terminal, i ran voxl-inspect-detections -a tag_detections, but i keep getting unknown, can you help with what i might be doing wrong.
      Meanwhile, I have ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node running.
      KIndly assist @tom @teddy-zaremba
      Taiwo
      • Zachary Lowell 0Z
        Zachary Lowell 0 ModalAI Team
        Hi @taiwohazeez - can you paste the output? Usually you get NANS or unknown when the locations.txt file isnt filled out meaning the tag detector service is referencing an empty file. Once you paste the output of voxl-inspect-detections I will be able to give you better guidance.
        Zach
        T 1 Reply Last reply Reply Quote 0
        • T
          taiwohazeez @Zachary Lowell 0
          @Zachary-Lowell-0 thank you for your response, this is the output,
          Class Name Camera Class Confidence Detection Confidence Frame ID Timestamp(
          unknown nan nan 62 447765889248
          Taiwo
          • Zachary Lowell 0Z
            Class confidence and detection confidence are pertinent towards voxl tflite server not voxl-tag-detector - are you sure this is the right output?
            • T
              @Zachary-Lowell-0 yes, i copied that directly from the terminal after running this command voxl-inspect-detections -a tag_detections.
              • T
                taiwohazeez @taiwohazeez
                @taiwohazeez @Zachary-Lowell-0 , please i am still waiting for a response, an advice on how to go about Apriltag detection on starling 2 would be greatly appreciated.
                • Zachary Lowell 0Z
                  @taiwohazeez I am not fully convinced you are running the right command still
                  Running voxl-inspect-tag shoudl show the following headers:
                  ID | XYZ | RPY | SIZE_M | CAM
                  As shown in the code below:
                  printf("\n"); printf("id:%3d name: %s\n", d.id, d.name); printf("XYZ: %6.2f %6.2f %6.2f \n", (double)d.T_tag_wrt_cam[0], (double)d.T_tag_wrt_cam[1], (double)d.T_tag_wrt_cam[2]); printf("RPY: %6.1f %6.1f %6.1f \n", (double)roll, (double)pitch, (double)yaw); printf("size_m: %4.2f latency_ms: %6.2f\n", (double)d.size_m, latency_ms); printf("cam: %s type: %s\n", d.cam, pipe_tag_location_type_to_string(d.loc_type)); printf("\n");
                  https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector/-/blob/dev/clients/voxl-inspect-tags.c?ref_type=heads
                  Just run voxl-inspect-tags and that will output the right data.
                  Zach
                  • Zachary Lowell 0Z
                    Detections is pertinent to voxl-tflite-server and onboard computer vision on yolo, NOT on april tags.
