  3. voxl-io-server won't run
5 Posts 2 Posters 921 Views 1 Watching
  • T Offline
    T Offline
    tonygurney
    Hello Modal AI team,
    I am trying to enable and run voxl-io-server. I was successfully able to enable it but when starting the system, it would not run. I ran into this error when I asked for its status
    voxl2:/$ systemctl status voxl-io-server
    ● voxl-io-server.service - voxl-io-server
    Loaded: loaded (/usr/bin/voxl-io-server; enabled; vendor preset: enabled)
    Active: failed (Result: exit-code) since Mon 2025-07-14 14:19:26 UTC; 25ms ago
    Process: 2571 ExecStart=/usr/bin/voxl-io-server (code=exited, status=255)
    Main PID: 2571 (code=exited, status=255)
    Jul 14 14:19:26 m0054 systemd[1]: Started voxl-io-server.
    Jul 14 14:19:26 m0054 voxl-io-server[2571]: no config file found, please run voxl-configure-rangefinders
    Jul 14 14:19:26 m0054 systemd[1]: voxl-io-server.service: Main process exited, code=exited, status=255/n/a
    Jul 14 14:19:26 m0054 systemd[1]: voxl-io-server.service: Failed with result 'exit-code'.
    • T tonygurney
      @tonygurney said in voxl-io-server won't run:
      Did you try running voxl-configure-rangefinders?
      T 1 Reply Last reply
        T Offline
        T Offline
        tonygurney
        wrote on last edited by tonygurney
        Yes I have, and these are the outputs:
        voxl2:/$ voxl-configure-rangefinders
        missing required argument
        Start wizard with prompts:
        Shortcut configuration arguments for scripted setup.
        factory_enable will reset the config file to factory defaults
        before enabling the service.
        voxl-configure-rangefinders disable
        voxl-configure-rangefinders 1_on_m0141
        voxl-configure-rangefinders 1_downward_on_m0141
        voxl-configure-rangefinders 4_on_m0141
        voxl-configure-rangefinders 1_downward_on_m0173
        voxl-configure-rangefinders enable
        1_downward_on_m0141 is for a downward sensor, this enables mavlink
        broadcast to the autopilot as a landing sensor
        show this help message:
        voxl-configure-rangefinders help
        is there a certain option I should select?
        • T tonygurney
          @tonygurney What are you trying to accomplish with voxl-io-server?
            T Offline
            T Offline
            tonygurney
            @Eric-Katzfey I figured out that I did not need it for my project, Thank you thought!
