  3. IBSS does not work on Starling 2
starling
3 Posts 2 Posters 654 Views 1 Watching
  • S Offline
    S Offline
    sssagara
    Hi! I'm exploring a way to control a group of Starling 2 as part of a swarming project. One of the ways that I'm looking at doing this is by using IBSS. When I queried the driver for the USB WiFi, it says that IBSS mode is supported (pic below). However, I'm unable to get 2 drones to ping each other. I think I found the github repo for the driver that the Starling 2 uses but it doesn't explicitly says it supports IBSS.
    Is there a way to enable this function in the Starling 2? Else, is there a way to upgrade the USB WiFi to something more recent? As far as I know, that might be a problem too as the kernel is pretty old and doesn't support the newer WiFi drivers that are on the newer kernels
    ModeratorM 1 Reply Last reply
    • S sssagara
      @sssagara IBSS is not something we have any experience with. As you see, it is an open source driver. You can also use different wifi adapters
      S 1 Reply Last reply
      • ModeratorM Moderator
        S Offline
        S Offline
        sssagara
        @Moderator When you mentioned different WiFi adapters, do you mean that the Starling 2 is able to support newer WiFi adapters that are WiFi 6E capable too? Or only those that are listed here?
