  3. Issues Streaming and Taking Snapshots Simultaneously with OV64B on VOXL2 (Hadron 640 Setup)
3 Posts 2 Posters 643 Views 1 Watching
  • R Offline
    R Offline
    restore
    I'm working with a VOXL2 and the FLIR Hadron 640 camera, and I'm trying to stream video from the OV64B sensor while taking snapshots at the same time.
    Initially, I attempted to use "en_preview": true along with "en_snapshot": true, but that configuration did not allow me to stream video. I assumed it might be a resolution constraint, so I modified the configuration to use "en_small_video": true and "en_snapshot": true instead.
    Now I can stream video, and when I enter the following command:
    voxl2:/data/snapshots$ voxl-send-command hires_snapshot
    Successfully sent command to /run/mpa/hires_snapshot/control
    In the voxl-camera-server terminal, I receive this error:
    ERROR: Camera: hires got unknown Command:
    However, when I enter:
    voxl2:/data/snapshots$ voxl-send-command hires_snapshot snapshot-no-save
    The camera server shows:
    Camera: hires taking snapshot for pipe only (not saving it)
    But I’m unable to access the snapshot data, even after running adb pull.
    My Questions:
    Is it possible to stream and take snapshots simultaneously on the OV64B?
    What does the error message “Camera: hires got unknown Command” mean?
    How can I access the output of snapshot-no-save if it's not being saved to disk?
    Thanks in advance for your help!
    Below is my camera config code:
    "version": 0.1,
    "fsync_en": false,
    "fsync_gpio": 109,
    "cameras": [
    "type": "boson",
    "name": "boson",
    "enabled": true,
    "camera_id": 0,
    "fps": 30,
    "en_preview": true,
    "en_misp": false,
    "preview_width": 640,
    "preview_height": 512,
    "en_raw_preview": true,
    "en_small_video": false,
    "en_large_video": false,
    "ae_mode": "off"
    "type": "ov64b",
    "name": "hires",
    "enabled": true,
    "camera_id": 1,
    "fps": 15,
    "en_preview": false,
    "en_misp": false,
    "preview_width": 1920,
    "preview_height": 1080,
    "en_raw_preview": false,
    "en_small_video": true,
    "small_video_width": 1024,
    "small_video_height": 768,
    "small_venc_mode": "h265",
    "small_venc_br_ctrl": "cqp",
    "small_venc_Qfixed": 30,
    "small_venc_Qmin": 15,
    "small_venc_Qmax": 40,
    "small_venc_nPframes": 9,
    "small_venc_mbps": 2,
    "en_snapshot_width": 1920,
    "en_snapshot_height": 1080,
    "ae_mode": "isp",
    "gain_min": 54,
    "gain_max": 32000
    • R restore
      My Questions:
      "version": 0.1,
      "fsync_en": false,
      "fsync_gpio": 109,
      "cameras": [
      "type": "boson",
      "name": "boson",
      "enabled": true,
      "camera_id": 0,
      "fps": 30,
      "en_preview": true,
      "en_misp": false,
      "ae_mode": "off"
      "type": "ov64b",
      "name": "hires",
      "enabled": true,
      "camera_id": 1,
      "fps": 15,
      "en_misp": false,
      "ae_mode": "isp",
      "gain_min": 54,
      "gain_max": 32000
      @restore
      When you use voxl-send-command, the format of the arguments is as follows:
      voxl-send-command <image-pipe-name> <command>, so when you run voxl-send-command hires_snapshot, you are sending an empty command to the pipe hires_snapshot. The correct usage would be:
      Please try it.
      R 1 Reply Last reply
        @restore
        Please try it.
        R Offline
        R Offline
        restore
        @Alex-Kushleyev thank you! It works now.
