  3. VOXL flight wifi in soft AP - only 2 connections possible
voxl-flight
4 Posts 2 Posters 1.5k Views 1 Watching
  • M Offline
    M Offline
    marian
    I use voxl flight with the Wi-Fi on soft AP mode, and its allow to connect only 2 devices at it at the same time. Can increase this limit?
    • M marian
      Alex KushleyevA Online
      Hi @marian,
      Please see the following post regarding VOXL1 wifi AP maximum number of clients : https://forum.modalai.com/topic/3523/maximum-connections-to-wi-fi . Hopefully that helps!
      M 1 Reply Last reply
        Hi @marian,
        M Offline
        M Offline
        marian
        wrote on last edited by marian
        @Alex-Kushleyev thanks for your reply.
        I follow the topic you provide, but still don't work. I have set up the max_num_sta=32, restart the wifi / reconfigure the wifi , still have only 2 connections permitted.
        I didn't find anything else in the configuartion or the scripts which can limit the connections.
        Did the hardware have a limitation instead of it?
        • M marian
          @marian , I was able to replicate it and when running dmesg, I see the following message:
          [  390.539854] R0: [VosMCThread][02:38:25.067557]  wlan: [3231:E :PE ] limProcessAssocReqFrame: 914: Max Sta count reached : 2
          Changing max_num_sta in hostapd.conf did not help.
          After doing a little bit of digging, it seems like this may be a hardware limitation of the wifi hardware on VOXL1 in SoftAP mode : https://android.googlesource.com/kernel/msm.git/+/android-msm-bullhead-3.10-n-preview-1/drivers/staging/qcacld-2.0/CORE/MAC/src/pe/lim/limProcessAssocReqFrame.c#847 .
          It could also be a setting somewhere low level and unfortunately we don't have any information on that. Sorry about that.
          The wifi module on VOXL1 is QCA6174.
