VOXL flight wifi in soft AP - only 2 connections possible
I use voxl flight with the Wi-Fi on soft AP mode, and its allow to connect only 2 devices at it at the same time. Can increase this limit?
Hi @marian,
Please see the following post regarding VOXL1 wifi AP maximum number of clients : https://forum.modalai.com/topic/3523/maximum-connections-to-wi-fi . Hopefully that helps!
Hi @marian,
@Alex-Kushleyev thanks for your reply.
I follow the topic you provide, but still don't work. I have set up the max_num_sta=32, restart the wifi / reconfigure the wifi , still have only 2 connections permitted.
I didn't find anything else in the configuartion or the scripts which can limit the connections.
Did the hardware have a limitation instead of it? -
Did the hardware have a limitation instead of it?@marian , I was able to replicate it and when running
dmesg, I see the following message:[ 390.539854] R0: [VosMCThread][02:38:25.067557] wlan: [3231:E :PE ] limProcessAssocReqFrame: 914: Max Sta count reached : 2Changing
max_num_stainhostapd.confdid not help.After doing a little bit of digging, it seems like this may be a hardware limitation of the wifi hardware on VOXL1 in SoftAP mode : https://android.googlesource.com/kernel/msm.git/+/android-msm-bullhead-3.10-n-preview-1/drivers/staging/qcacld-2.0/CORE/MAC/src/pe/lim/limProcessAssocReqFrame.c#847 .
It could also be a setting somewhere low level and unfortunately we don't have any information on that. Sorry about that.
The wifi module on VOXL1 is QCA6174.
