  3. (VOXL2 PX4 ROS2) px4_msgs Unrecognized In Program
5 Posts 2 Posters 825 Views
  • G Offline
    G Offline
    GlennTee
    wrote on last edited by GlennTee
    Hello. I'm attempting to use various PX4 messages in a program I am working on, but for some reason the px4_msgs package is not recognized at all. I'm not sure if it is a path issue or if I downloaded it wrong somehow, but I tried sourcing the files and that hasn't worked. Ignoring the type also hasn't worked for me. Is there any easy fix for this that I'm missing? I am urgently seeking a fix for this. Pictured below is the error that comes up:
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @GlennTee have you sourced the right directories? If you run source /opt/ros/foxy/mpa_to_ros/install/setup.bash that should tell your package manager that the px4 messages type exists. I also notice you are running this on your local machine - have you install the necessary packages there? If you instantiate the voxl-cross or qrb5165 emulator image and then use vscode inside the docker then you should be able to see the px4 messages just fine.
      LMK if that helps!
      Zach
      G 1 Reply Last reply
        LMK if that helps!
        Zach
        G Offline
        G Offline
        GlennTee
        @Zachary-Lowell-0 I tried "source /opt/ros/foxy/setup.bash" and "source install/local_setup.bash," but this was for trying to run my program. I just tried running "source /opt/ros/foxy/mpa_to_ros/install/setup.bash" and this is what I got:
        I'm using remote ssh in order to access the files on the drone.
          Zachary Lowell 0
          Did you ever install voxl-ros2-foxy?
          • G GlennTee
            G Offline
            G Offline
            GlennTee
            @Zachary-Lowell-0 Yes I installed voxl-ros2-foxy. This time I just tried "source /opt/ros/foxy/mpa_to_ros2/install/setup.bash" and that was accepted. However, looking now px4_msgs is still not recognized within my program.
