    Starling 2 Max camera questions
    Starling & Starling 2
    • ModeratorM
      Moderator ModalAI Team
      From an inbound email:
      Do the cameras have 3-axis stabilization?
      Maximum resolution of video streaming?
      Any specific information related onboard processing?
      • ModeratorM
        Moderator ModalAI Team @Moderator
        No
        4k video recording is supported
        VOXL 2 is the onboard computing, this may be helpful https://docs.modalai.com/voxl2-feature-matrix/
        h3roboticsH E 2 Replies Last reply Reply Quote 0
        • h3roboticsH
          h3robotics @Moderator
          @Moderator can we do any electronic image stabilization on the VOXL2 as supported by the Qualcom. Kindly see https://docs.qualcomm.com/bundle/publicresource/80-88500-50_REV_AA_QRB5165_LU_2_0_QUALCOMM_INTELLIGENT_MULTIMEDIA_SDK__IM_SDK__Reference.pdf
          • E
            EduardoP
            I would appreciate it if you could clarify my query regarding video streaming. Specifically, we are looking for a system capable of receiving video feeds on the ground and processing drone images in real time. The setup would include an additional ground station dedicated solely to the video feed, separate from the station controlling the drone.
            • Eric KatzfeyE
              Eric Katzfey ModalAI Team @EduardoP
              @EduardoP Yes, the video stream is separate from the command and control stream. Video is streamed using RTSP, and telemetry, command, and control is streamed using Mavlink. Beyond this, VOXL 2 is meant to be an open development platform that you can use to create your own custom methods of streaming if so desired.
              • E
                EduardoP @Moderator
                @Moderator
                Which configuration allows 2D ground mapping, does it have a downward facing camera?
                Is there a whole kit of ground control station (controller) available (meaning ready to fly/control, including receiver, display, joysticks...)?
                Resolution in real time and latency of the video streaming?
