    Color Tracking Camera w/ Global Shutter
    Image Sensors
    • wilkinsafW
      wilkinsaf ModalAI Team
      We were curious if there is a way to integrate a color tracking camera (or if there is even a color tracking camera that exists).
      The reason being, is that for extremely small UAVs it would be ideal to have 1 tracking camera that is
      1. being used for VIO
      2. being used as the FPV cam
      3. Being used to collect data of surroundings
      But, to be used as an FPV cam and data collection the camera would have to be color.
      Thank you!
      wilkinsafW 1 Reply Last reply Reply Quote 0
      • wilkinsafW
        wilkinsaf ModalAI Team @wilkinsaf
        @wilkinsaf
        A color AR0144 exists, but there is no current integration readily available
        J 1 Reply Last reply Reply Quote 1
        • J
          jakkkkobo @wilkinsaf
          Hello @wilkinsaf,
          Do you know where I can find that integration/implementation for color output on the AR 0144?
          Thank you!
          Regards,
          Jacob
            Alex Kushleyev ModalAI Team @jakkkkobo
            @jakkkkobo , the color AR0144 support (very basic) is in voxl-camera-server: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/src/hal3_camera_mgr.cpp?ref_type=heads#L1405 (PerCameraMgr::ProcessAR0144ColorFrame).
            Once you connect the color version of the AR0144 camera, just change the camera type from ar0144 to ar0144-color in voxl-camera-server.conf. Then camera server will publish the raw bayer (8 bit), mono and RGB (not yuv) images.
            If there still interest in using the color version of AR0144, we can develop the code further to follow our standard color camera pipeline:
            • debayer on GPU
            • add LSC correction for R, G and B
            • output YUV
            • add encoded video output
            Right now the implementation is very basic, just for simple testing.
            Alex KushleyevA J 2 Replies Last reply Reply Quote 1
              also see discussion here : https://forum.modalai.com/topic/4491/ar0144-rgb-output-on-voxl2/
              • J
                jakkkkobo @Alex Kushleyev
                @Alex-Kushleyev , thank you for the insights!
                I will try the basic version and see if it suits our industrial solution on field.
                If it fits I ask for the full version.
                Regards,
                Jacob
