  3. Swapping out RC Receiver
4 Posts 2 Posters 545 Views 1 Watching
  • B Offline
    B Offline
    buem799
    Hi devs, I'm working with a VOXL2 and wondering if I can easily swap out the "915 MHz ELRS" RC receiver and replace it with a "Nano RX|868MHz". I cannot work on 915 MHz due to some regulations forbidding the usage of that.
    Thanks for any feedback.
    • B buem799
      @buem799 If it uses CRSF on the UART then should be fine. Do you have a pointer to the data sheet for the exact receiver you are considering?
      B 1 Reply Last reply
        B Offline
        B Offline
        buem799
        @Eric-Katzfey I couldn't find a datasheet apart from this site https://betafpv.com/collections/rx-tx/products/elrs-nano-receiver. I'm pretty sure it uses CRSF over UART since it also uses ELRS.
        • B buem799
          @buem799 Yes, I think that one should work fine. But there's probably a bunch of configuration options for the receiver so you have to make sure that it has been setup properly to do CRSF.
