  3. Unable to connect to wifi network
3 Posts 3 Posters 851 Views 1 Watching
  • K Offline
    K Offline
    KnightHawk
    I am following the tutorial for connecting the VOXL2 to the local wifi network using the purchased wifi adapter below but I'm unable to successfully connect.
    https://docs.modalai.com/voxl-2-wifi-setup/
    Wifi adapter
    https://www.modalai.com/products/voxl-2-wifi-add-on-kit?srsltid=AfmBOooGwF30Mr2uBxvZ0rWkEC-rKLMiXi49FY0LBQ6rbXoo0X4DLikz
    Voxl chip
    voxl2:/$ cat /proc/device-tree/model
    Qualcomm Technologies, Inc. qrb5165 IOT RB5code_text
    voxl2:/$ voxl-wifi
    Illegal usage
    Description:
            Configure the Wi-Fi mode.
    Usage:
      voxl-wifi getmode
            Print the current mode (softap of station)
      voxl-wifi softap <ssid>
            Set Wi-Fi to Access Point mode.
            Password defaults to '1234567890'
      voxl-wifi station <ssid> [password]
            Set the Wi-Fi to station mode and connect to the AP with provided SSID
            and (optional) password.  Note: if your password has special characters
            surround it with quotes.
      voxl-wifi -f
            Set the Wi-Fi to Access Point mode and SSID to 'SSID'
    voxl2:/$ voxl-wifi station "Alpha Bravo" "Password"
    Cannot find device "wlan0"
    Device "wlan0" does not exist.
    • K KnightHawk
      Wifi adapter
      Voxl chip
      voxl2:/$ voxl-wifi
      Illegal usage
      Description:
      Usage:
        voxl-wifi getmode
        voxl-wifi -f
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @KnightHawk you may consider reflashing your SDK image if feasible to mark out things.
      • Jetson NanoJ Jetson Nano
        @KnightHawk ,
        Please try unplugging the USB dongle from the USB extension (connected to VOXL2) then plugging it back in and check output of dmesg on your voxl2. It should say something about the new usb device connected and whether there are any errros.
        Also, in order to confirm that the wifi dongle itself is working, you could try plugging that into a standard linux PC, it should be recognized.
