  3. VOXL portal wont display live camera feeds after SDK 1.4.0 upgrade
5 Posts 2 Posters 945 Views 1 Watching
  • Gary HolmgrenG Offline
    Gary Holmgren
    Hi, I have the ar0144 tracking as well as the imx214 setup with VOXL 2 and they worked perfect on SDK 1.3.5 in the portal I could see there stream live. However after upgrading to SDK 1.4.0 no matter which feed i choose it only shows a snapshot and not the live feed.
    I am also curious what the three new options below "tracking" are as they didnt appear before.
    When i inspect in the terminal i can see
    Not quite sure whats causing the feed to freeze up. My WiFi connection is the same as before when it streamed normally on 1.3.5
    • Gary HolmgrenG Gary Holmgren
      @Gary-Holmgren We believe there was a bug introduced to portal in 1.4.0 that'l be fixed in the next release.
      In the meantime can you try installing the latest version of voxl-portal from the dev branch and see if that fixes the issue?
      404 Not Found
      favicon
      (voxl-packages.modalai.com)
      Gary HolmgrenG 2 Replies Last reply
        404 Not Found
        favicon
        Gary Holmgren
        @tom Thankyou!
          404 Not Found
          favicon
          Gary Holmgren
          @tom This indeed fixed the issue!
            @Gary-Holmgren Great to hear, new SDK release with that fix coming soon
            • B brandon referenced this topic on
