  3. voxl-camera-server
voxl-camera-server
2 Posts 2 Posters 509 Views 1 Watching
  • KnightHawk06K Offline
    KnightHawk06
    I'm running voxl2 out of the box with no changes, the board is powered by an external LIPO battery and plugged into the desktop computer via USB-C. I'm trying to follow the tutorial to access the camera data but I'm unable to start voxl-camera-server. Can this server be started without an internet connection?
    system-image: 1.5.5-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Fri Mar 24 00:48:55 UTC 2023 4.19.125
    hw version: M0054
    voxl-suite: 0.9.5
    Packages:
    Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-0.9/binary-arm64/
    Last Updated: 2023-09-29 20:33:03
    voxl-configure-cameras 11
    Camera Configuration: 11
    enabling and starting voxl-camera-server
    voxl-camera-server
    Segmentation fault:
    Fault thread: voxl-camera-ser(tid: 2596)
    Fault address: 0x566595d321
    Address not mapped.
    Segmentation fault
    • KnightHawk06K KnightHawk06
      hw version: M0054
      voxl-suite: 0.9.5
      Packages:
      voxl-camera-server
      Segmentation fault:
      Address not mapped.
      Segmentation fault
      @KnightHawk06 , please upgrade your VOXL2 SDK, as you have very old release, you can get the latest SDK 1.4.0 and then configure your cameras.
      https://docs.modalai.com/sdk-1.4-release-notes/
      After installing latest SDK and configuring cameras, confirm via ADB shell that camera server is getting camera data:
      #this test app will subscribe to all camera streams and report stream resolution, fps, etc
      #please note that this test can put unnecessary stress on the system because it will stream ALL the possible camera streams, so normally you would not run this test all the time
      voxl-inspect-cam -a
      after that, if you want to view the camera stream using voxl-portal but you do not have internet connection, you can do that using adb port forwarding trick : https://docs.modalai.com/voxl-portal-via-adb/
      Let us know if you have any other questions.
