  3. Obstacle_Detection messages not appearing
17 Posts 2 Posters 2.7k Views 1 Watching
  • Daniel RyuD Offline
    Daniel RyuD Offline
    Daniel Ryu
    Hello, I am trying to figure out how to turn on the collision prevention in voxl based systems, and despite following the linked instructions, I am unable to get Obstacle_Detection messages to appear in the QGC mavlink inspector. I enabled voa and voa messages to qgc, and configured the PX4 parameters using the given helper file. What should I try to receive Obstacle Detection messages?
    https://docs.modalai.com/voxl-vision-px4-collision-prevention/
      Daniel RyuD Offline
      Daniel Ryu
      wrote on last edited by Daniel Ryu
      I also calibrated the Stereo cameras and confirmed that output was coming out from the voxl-vision-px4 debug mode (-s flag)
        Daniel RyuD Offline
        Daniel Ryu
          It looks like everything is set up properly, can you run voxl-inspect-cam dfs-disparityand check to see that you're getting output there?
          Daniel RyuD 1 Reply Last reply
          • ? A Former User
            Daniel RyuD Offline
            Daniel RyuD Offline
            Daniel Ryu
            @Alex-Gardner Doesn't seem like it, its stuck on this screen. Screenshot from 2021-08-25 10-23-50.png
              can you do the same but with stereo: voxl-inspect-cam stereo, if the dfs service is running and receiving frames it should be outputting data
              • ? A Former User
                Daniel RyuD Offline
                Daniel RyuD Offline
                Daniel Ryu
                @Alex-Gardner I'm getting output just fine from stereo aloneScreenshot from 2021-08-25 10-35-32.png
                  What version of voxl suite/system image do you have? voxl-version should print this out
                  • ? A Former User
                    Daniel RyuD Offline
                    Daniel RyuD Offline
                    Daniel Ryu
                    @Alex-Gardner System image 3.3.0. Voxl-suite 0.4.6
                      do you see dfs topics when you do ls /run/mpa
                        wait the name is dfs_disparity, not dfs-disparity, what does the inspect cam say with that voxl-inspect-cam dfs_disparity
                        • ? A Former User
                          Daniel RyuD Offline
                          Daniel RyuD Offline
                          Daniel Ryu
                          @Alex-Gardner Output is generated for dfs_disparity Screenshot from 2021-08-25 10-53-01.png
                            Daniel RyuD Offline
                            Daniel Ryu
                              The image is showing some disparity data there, the image is often very dark because it will be black if the dfs algo is unable to match regions and we do a lot of filtering to get rid of noise, but you can see 2 blobs there that it recognizes. If you're shoing the stereo cameras a blank wall or a repeating pattern it will be unable to properly match data.
                              • ? A Former User
                                Daniel RyuD Offline
                                Daniel RyuD Offline
                                Daniel Ryu
                                @Alex-Gardner That's good to know! How can I get the Obstacle Detection message to be sent to the QGC?
                                  the file at /etc/modalai/voxl-vision-px4.conf has settings for QGC IP, enabling VOA, and sending VOA to QGC. Make sure that the latter two are enabled and that your qgc ip is correct and it should send to QGC
                                  • ? A Former User
                                    Daniel RyuD Offline
                                    Daniel RyuD Offline
                                    Daniel Ryu
                                    @Alex-Gardner That was it, the ip address was not inputted correctly. Thanks!
