  3. Obstacle_Detection messages not appearing
17 Posts 2 Posters 2.4k Views 1 Watching
  • ? Offline
    It looks like everything is set up properly, can you run voxl-inspect-cam dfs-disparityand check to see that you're getting output there?
    Daniel RyuD 1 Reply Last reply
    • ? A Former User
      Daniel RyuD Offline
      Daniel RyuD Offline
      Daniel Ryu
      @Alex-Gardner Doesn't seem like it, its stuck on this screen. Screenshot from 2021-08-25 10-23-50.png
      • ? Offline
        can you do the same but with stereo: voxl-inspect-cam stereo, if the dfs service is running and receiving frames it should be outputting data
        • ? A Former User
          Daniel RyuD Offline
          Daniel RyuD Offline
          Daniel Ryu
          @Alex-Gardner I'm getting output just fine from stereo aloneScreenshot from 2021-08-25 10-35-32.png
          • ? Offline
            What version of voxl suite/system image do you have? voxl-version should print this out
            • ? A Former User
              Daniel RyuD Offline
              Daniel RyuD Offline
              Daniel Ryu
              @Alex-Gardner System image 3.3.0. Voxl-suite 0.4.6
              • ? Offline
                do you see dfs topics when you do ls /run/mpa
                • ? Offline
                  wait the name is dfs_disparity, not dfs-disparity, what does the inspect cam say with that voxl-inspect-cam dfs_disparity
                  • ? A Former User
                    Daniel RyuD Offline
                    Daniel RyuD Offline
                    Daniel Ryu
                    @Alex-Gardner Output is generated for dfs_disparity Screenshot from 2021-08-25 10-53-01.png
                    • Daniel RyuD Offline
                      Daniel RyuD Offline
                      Daniel Ryu
                      • ? Offline
                        The image is showing some disparity data there, the image is often very dark because it will be black if the dfs algo is unable to match regions and we do a lot of filtering to get rid of noise, but you can see 2 blobs there that it recognizes. If you're shoing the stereo cameras a blank wall or a repeating pattern it will be unable to properly match data.
                        • ? A Former User
                          Daniel RyuD Offline
                          Daniel RyuD Offline
                          Daniel Ryu
                          @Alex-Gardner That's good to know! How can I get the Obstacle Detection message to be sent to the QGC?
                          • ? Offline
                            the file at /etc/modalai/voxl-vision-px4.conf has settings for QGC IP, enabling VOA, and sending VOA to QGC. Make sure that the latter two are enabled and that your qgc ip is correct and it should send to QGC
                            • ? A Former User
                              Daniel RyuD Offline
                              Daniel RyuD Offline
                              Daniel Ryu
                              @Alex-Gardner That was it, the ip address was not inputted correctly. Thanks!
