  3. Retrieving Apriltag offset from MAV local frame offset
3 Posts 2 Posters 612 Views
  • J Offline
    JoeAR_21
    Re: Fixed frame pose MPA to ROS
    Similar to the various above threads, I am trying to figure out if there already exists some way of getting the detected April tag's offset relative the the MAV's local frame (for reference I'm using the frame that /mavros/local_position/pose provides). I'm unsure of how I can achieve this aside from manually piping and shifting through the data outputted by the voxl-inspect-tags command and converting into a ROS Pose. Do let me know if there already exists a method for accomplishing this or if there would be an easier way to retrieve this offset into a ROS pose.
    For reference I am using a Starling with VOXL2 and system image: 1.7.6
    My goal is to visualize the position of the drone relative to the detected April tag for accurate position targeting.
    ModeratorM 1 Reply Last reply
    • J JoeAR_21
      @JoeAR_21 to correct VIO drift, voxl-vision-hub can correct using an AprilTag without any ROS involvement. If you just need to send the data to ROS for another purpose, you should extend voxl-mpa-to-ros to support tag detections
      Source: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros/-/tree/master/catkin_ws/src/src/interfaces?ref_type=heads
      We love incorporating merge requests if you do end up with something useful!
      J 1 Reply Last reply
      • ModeratorM Moderator
        JoeAR_21
        @Moderator said in Retrieving Apriltag offset from MAV local frame offset:
        I've made a quick fix here for anyone looking for it, ill try to make a merge request/real fix for it soon
        https://github.com/Joe1Ontiveros/ApriltagPublisher_Starling
