  3. Fixed frame pose MPA to ROS
1 Posts 1 Posters 584 Views 2 Watching
  • J Offline
    jay.miller
    This is essentially bumping Apriltag landing fixed frame ROS interface, How can I see the apriltag offset in ROS, and How can I get fixed pose via qgc or ros topics.
    I can perform apriltag relocalization and see that it is working correctly via voxl-vision-px4 -p or other voxl means, but both /mavros/local_position/pose and /qvio/pose report position in local frame. I understand that I can issue commands in fixed frame to then be corrected by mavros en route the PX4, but this is only useful in ROS/QGC if my fixed and local frames are roughly equivalent (so using relocalization to correct for drift, but not to initialize position).
    For reference, my platform is an m500 with VOXL1:
    Firmware: 1.13.2, Custom Fw. Ver. 0.1.1
    system-image: 4.0.0
    kernel: #1 (closed) SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
    hw version: VOXL
    voxl-suite: 0.9.4
    and my parameter file is:
    MAVLINK IO
    qgc_udp_port_number: 14550
    udp_mtu: 512
    en_localhost_mavlink_udp 1
    localhost_udp_port_number: 14551
    VIO
    en_vio: 1
    vio_pipe: qvio
    en_send_vio_to_qgc: 0
    en_reset_vio_if_initialized_inverted: 1
    vio_warmup_s: 3.000000
    send_odom_while_failed: 0
    APQ8096-ONLY FEATURES
    en_set_clock_from_gps: 1
    en_force_onboard_mav1_mode: 1
    en_reset_px4_on_error: 1
    MISC FEATURES
    horizon_cal_tolerance: 0.500000
    OFFBOARD MODE
    offboard_mode: off
    follow_tag_id: 0
    figure_eight_move_home: 1
    robot_radius: 0.300000
    collision_sampling_dt: 0.100000
    max_lookahead_distance: 1.000000
    FIXED FRAME RELOCALIZATION
    en_tag_fixed_frame: 1
    fixed_frame_filter_len: 5
    en_transform_mavlink_pos_setpoints_from_fixed_frame:1
