  3. Unbricking a VOXL 2 - Pass but no ADB?
15 Posts 2 Posters 2.6k Views 1 Watching
  • C Offline
    C Offline
    czarsimon
    I'm trying to follow the steps listed here to unbrick a VOXL 2: https://docs.modalai.com/voxl2-unbricking. However, after the process completes I'm unable to access it through adb. I tried running it on two computers and multiple VOXL 2s with the same results. The following is the output of the QDL Tool:
    Selected Flat Build:2024-06-17-1.7.4-M0054-1
    Provisioning UFS...
    {"message": "UFS provisioning succeeded, please reset power to the device\n"}
    Flashing CDT...
    {"message": "Flash CDT succeeded\n"}
    Flashing Flat Build...
    {"message": "Flash flat build passed\n"}
    After that and a reboot adb wait-for-device hangs for over 5 minutes
    • C czarsimon
      Provisioning UFS...
      Flashing CDT...
      @czarsimon Can you confirm that you are flashing the correct image for your board? M0054-1 (QRB) vs M0054-2 (QSM)?
      https://docs.modalai.com/m0054-versions/#m0054-1-and-m0054-2
      C 1 Reply Last reply
        C Offline
        C Offline
        czarsimon
        Hi @tom I can confirm the VOXL 2s I have are QRB5165M.
        • C czarsimon
          @czarsimon And after the QDL process are you turning the switch back off and power cycling the board?
            C Offline
            C Offline
            czarsimon
            @tom Yes correct
            • C czarsimon
              @tom Yes correct
              @czarsimon Does the board enumerate via lsusb? If so, what do you see?
                C Offline
                C Offline
                czarsimon
                @tom With the QDL switch in the ON position:
                Bus 002 Device 010: ID 05c6:9008 Qualcomm, Inc QUSB_BULK_CID:0412_SN:68E7EC23
                With the QDL switch in the OFF position:
                Bus 002 Device 010: ID 18d1:d00d Google Inc. Android Serial: f75e1ba6
                • C czarsimon
                  @czarsimon Okay so with the switch off it is booting to fastboot, are you able to install the SDK at this point?
                  C 2 Replies Last reply
                    C Offline
                    C Offline
                    czarsimon
                      C Offline
                      C Offline
                      czarsimon
                      @tom No, the device is not found in fastboot mode.
                      • C czarsimon
                        @czarsimon I can see by the output that the device is in fastboot mode, but it is still possible that fastboot itself isn't picking it up if the permissions on your machine aren't correct. If you try flashing the board with sudo does it detect the device?
                          C Offline
                          C Offline
                          czarsimon
                          @tom The system image flashes with sudo, but the SDK does not; no adb devices are showing up and lsusb shows the same output after the flash.
                          • C czarsimon
                            @czarsimon Can you verify whether your board has a QSM8250 (M0054-2) or a QRB5165 (M0054-1) and that you're flashing the correct QDL image as well as kernel choice when flashing the SDK?
                              C Offline
                              C Offline
                              czarsimon
                              @tom This is the SOM, our company only gets the QRB5165M and we've been flashing the same system image for months so I'm confident that's not where the issue is:
                              • C czarsimon
                                @czarsimon When you run through the QDL process how long does it take for the flash to finish? seconds? minutes?
                                Also, are you able to ADB onto functional devices on this machine? Want to rule it weird permission issues
