  3. Camera Server Aborts
2 Posts 2 Posters 644 Views 1 Watching
  • Shivam SehgalS Offline
    Shivam Sehgal
    voxl camera server is aborting itself, what can be the issue. I was running my ros package on the drone and also using ros mpa package and then suddenly all the topics vanished.
    when I restarted the drone the camera starts for some time and them stops showing stalled missing.
    I am running tof at 15 fps also tried running at 5 but still the same issue. hires and tracking at default fps that it is configured with.
    voxl2:/$ voxl-version
    system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.1.2
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
    Last Updated: 2023-03-02 12:59:10
    List:
    	libmodal-cv                 0.4.0
    	libmodal-exposure           0.1.0
    	libmodal-journal            0.2.2
    	libmodal-json               0.4.3
    	libmodal-pipe               2.9.2
    	libqrb5165-io               0.4.2
    	libvoxl-cci-direct          0.2.1
    	libvoxl-cutils              0.1.1
    	mv-voxl                     0.1-r0
    	qrb5165-bind                0.1-r0
    	qrb5165-dfs-server          0.2.0
    	qrb5165-imu-server          1.0.1
    	qrb5165-rangefinder-server  0.1.1
    	qrb5165-slpi-test-sig       01-r0
    	qrb5165-system-tweaks       0.2.3
    	qrb5165-tflite              2.8.0-2
    	voxl-bind-spektrum          0.1.0
    	voxl-camera-calibration     0.5.3
    	voxl-camera-server          1.8.9.1
    	voxl-configurator           0.4.8
    	voxl-cpu-monitor            0.4.7
    	voxl-docker-support         1.3.0
    	voxl-elrs                   0.1.3
    	voxl-esc                    1.3.7
    	voxl-feature-tracker        0.3.2
    	voxl-flow-server            0.3.3
    	voxl-jpeg-turbo             2.1.3-5
    	voxl-lepton-server          1.2.0
    	voxl-logger                 0.3.5
    	voxl-mavcam-manager         0.5.3
    	voxl-mavlink                0.1.1
    	voxl-mavlink-server         1.3.2
    	voxl-modem                  1.0.8
    	voxl-mongoose               7.7.0-1
    	voxl-mpa-to-ros             0.3.7
    	voxl-mpa-tools              1.1.3
    	voxl-neopixel-manager       0.0.3
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.3
    	voxl-px4                    1.14.0-2.0.63
    	voxl-px4-imu-server         0.1.2
    	voxl-px4-params             0.3.3
    	voxl-qvio-server            1.0.0
    	voxl-streamer               0.7.4
    	voxl-suite                  1.1.2
    	voxl-tag-detector           0.0.4
    	voxl-tflite-server          0.3.1
    	voxl-utils                  1.3.3
    	voxl-uvc-server             0.1.6
    	voxl-vision-hub             1.7.3
    	voxl2-system-image          1.7.1-r0
    	voxl2-wlan                  1.0-r0
    voxl2:/$ voxl-camera-server
    detected system image 1.7.1
    using new imx214 defaults
    configuration for 3 cameras:
    cam #0
        sensor type:         pmd-tof
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 5
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        standby_enabled:     0
        decimator:           5
        independent_exposure:0
    cam #1
        sensor type:         imx214
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4208
        large_video_height:  3120
        en_snapshot:         1
        snap_width:          4208
        snap_height:         3120
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ov7251
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
    GPS server Connected
    Starting Camera: tof (id #0)
    Using gain limits min: 54 max: 8000
    Starting Camera: hires (id #1)
    Using gain limits min: 54 max: 431
    WARNING: Port Def 0:
    	Count Min: 8
    	Count Actual: 16
    	Buffers Contiguous: Yes
    	Buffer Alignment: 0
    WARNING: Port Def 1:
    	Count Min: 4
    	Count Actual: 16
    	Buffers Contiguous: No
    	Buffer Alignment: 0
    	Count Min: 8
    	Count Actual: 16
    	Buffer Alignment: 0
    	Count Min: 4
    	Count Actual: 16
    	Buffer Alignment: 0
    Starting Camera: tracking (id #2)
    Using gain limits min: 54 max: 3451
    setting ov7251 BLC register for cam id 2
    ------ voxl-camera-server: Started 3 of 3 cameras
    Aborted
    • Shivam SehgalS Shivam Sehgal
      hw version:   M0054
      voxl-suite:   1.1.2
      Packages:
      List:
      	libmodal-cv                 0.4.0
      	libmodal-json               0.4.3
      	libmodal-pipe               2.9.2
      	libqrb5165-io               0.4.2
      	mv-voxl                     0.1-r0
      	qrb5165-bind                0.1-r0
      	voxl-elrs                   0.1.3
      	voxl-esc                    1.3.7
      	voxl-logger                 0.3.5
      	voxl-mavlink                0.1.1
      	voxl-modem                  1.0.8
      	voxl-opencv                 4.5.5-2
      	voxl-portal                 0.6.3
      	voxl-streamer               0.7.4
      	voxl-suite                  1.1.2
      	voxl-utils                  1.3.3
      	voxl2-wlan                  1.0-r0
      cam #0
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 5
          en_rotate:           0
          en_rotate2:          0
          en_preview:          1
          pre_width:           224
          pre_height:          1557
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             off
          standby_enabled:     0
          decimator:           5
      cam #1
          sensor type:         imx214
          isEnabled:           1
          camId:               1
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          0
          pre_width:           640
          pre_height:          480
          en_raw_preview:      0
          en_small_video:      1
          en_large_video:      1
          en_snapshot:         1
          snap_width:          4208
          snap_height:         3120
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ov7251
          isEnabled:           1
          camId:               2
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          1
          pre_width:           640
          pre_height:          480
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      	Count Min: 8
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 4
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 8
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 4
      	Count Actual: 16
      	Buffer Alignment: 0
      Aborted
      @Shivam-Sehgal , it seems you are using VOXL SDK that is more than one year old, please upgrade to the latest 1.3.5.
      If you are not able to upgrade, then please try the following:
      • reduce the width/ height of hires camera large video stream to 3840x2160, if that does not help, reduce the FPS of hires camera to 25Hz
      • disable snapshot if you are not using that feature
      • try starting voxl-camera-server manually and assign upper cores 2-7 to the process, which helps with stability
        • stop camera server running in the background (if applicable) : systemctl stop voxl-camera-server
        • run camera server and assign cpu affinity using taskset : taskset -c 2-7 /usr/bin/voxl-camera-server
