  3. VOXL2 Camera Configuration not found
11 Posts 4 Posters 2.1k Views 3 Watching
  • J Offline
    jcai
    wrote on last edited by jcai
    I'm using a VOXL2 (board only), a micro-coax camera adapter (M0173), and an IMX412 (M0161).
    I'm following the documentation here. When configuring SKU, I can set 20 for VOXL2-board-only but camera configurations 26-30 don't appear. The same is true if I run voxl-configure-camera.
    Any ideas as to the cause? All components are connected to the VOXL already.
    VOXL currently thinks it is in the following hardware:
    family code:   MCCA-M0054 (voxl2-board-only)
    compute board: 4 (voxl2)
    hw version:    1
    cam config:    0
    modem config:   ()
    tx config:      ()
    extras config:  ()
    SKU:           MCCA-M0054-C0-M0-X0
    If this is what you want, select 1 (accept and continue) to
    leave it as-is. Otherwise, select the desired product family:
     1) accept and continue      12) voxlcam
     2) starling-2               13) seeker
     3) starling-2-max           14) rb5-flight
     4) starling                 15) flight-deck
     5) px4-autonomy-dev-kit     16) voxl-deck
     6) sentinel                 17) voxl2-flight-deck
     7) fpv                      18) voxl2-test-fixture
     8) D0010                    19) voxl2-mini-test-fixture
     9) stinger                  20) voxl2-board-only
    10) D0015                    21) voxl2-mini-board-only
    11) m500                     22) quit
    #? 20
    selected voxl2-board-only
    If you would like to select a special camera config that differs
    from the default for your product family, please select an option.
    Simply hit ENTER to use the default
    01 - ov7251 tracking ov7251 stereo
    02 - ov7251 tracking
    03 - ov7251 tracking ov7251 stereo imx214 hires
    04 - ov7251 tracking imx214 hires
    05 - pmd-tof ov7251 tracking
    06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
    08 - imx214
    09 - pmd-tof
    10 - ov7251 stereo
    11 - D0006 Sentinel
    12 - ov9782 stereo
    13 - ov9782 stereo imx214 hires
    14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
    15 - D0008 dual 9782 tracking
    16 - pmd-tof ov7251 dual tracking imx214 hires
    17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
    18 - D0008 triple ov9782
    19 - D0005 without tof imx214 hires ov7251 tracking
    20 - D0011 imx412 hires ar0144 tracking
    21 - old C6
    22 - D0013 voxl2 mini dual ar0144
    23 - D0010 without stereo
    24 - pmd-tof LIOW2 (new TOF)
    25 - dual ar0144
    31 - D0013 COAX dual ar0144 tracking
    32 - D0008 triple ov9782 rotated
     C - use user-defined custom camera config in
         (/data/modalai/custom_camera_config.txt)
     q - Quit The Wizard
    selection: ^C
    Josh
    • J jcai
      hw version:    1
      cam config:    0
      modem config:   ()
      tx config:      ()
      extras config:  ()
      11) m500                     22) quit
      #? 20
      08 - imx214
      09 - pmd-tof
      10 - ov7251 stereo
      11 - D0006 Sentinel
      12 - ov9782 stereo
      21 - old C6
      25 - dual ar0144
       q - Quit The Wizard
      selection: ^C
      Josh
      @jcai You'll need to re-flash the latest SDK and select a kernel option for M0173 support. Different kernels are required to unlock different camera configs
      J 1 Reply Last reply
        jcai
        @tom I just flashed 1.3.5 and was able to configure C28. However, there still seems to be an issue.
        My camera is connected to J5 on the breakout, which should be hires_down. Using voxl-inspect-cam, the camera shows up as hires_front.
        Furthermore, if I disable just tracking_front in the camera server config file, the server will fail to initialize hires_front. Since I only have one camera physically connected, the camera server will not find any cameras and fail to start.
        J 3 Replies Last reply
        • J jcai
          jcai
          Also, I have a custom kernel build (that wasn't being used during my issues in my last comment) created by following this guide: https://docs.modalai.com/voxl2-kernel-build-guide/
          The only change I made in this kernel was to enable CONFIG_MACVLAN=y by editing kona-perf_defconfig in
          apps_proc/poky/meta-voxl2-bsp/recipes-kernel/linux-msm/files/configs/m0054
          However, as you said, this kernel version doesn't support the M0173 breakout board. How do I build a version that does while also adding my macvlan config?
          modaltbM 1 Reply Last reply
          • J jcai
            jcai
            • J jcai
              Hi @jcai ,
              Please build the kernel using the argument to specify a 'variant' of the kernel:
              ./qrb5165-build.sh -m M0054 -v var00.1
              I'm using this var00.1 variable to pull in these device tree files basically:
              https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/tree/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/variant/m0054/var00.1
              Specifically for cameras:
              https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/variant/m0054/var00.1/m0054-modalai-camera.dtsi?ref_type=heads#L4
              This happens here:
              https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/linux-msm_4.19.bbappend?ref_type=heads#L187
              For reference, the kernel tracks and exports info about itself to filesystem using this:
              https://gitlab.com/voxl-public/system-image-build/meta-voxl2/-/tree/qrb5165-ubun1.0-14.1a/recipes-kernel/voxl-platform-mod
              -Travis
              • J jcai
                jcai
                @jcai said in VOXL2 Camera Configuration not found:
                Thanks Travis, I was able to get a build with the correct configuration options as well as my own changes. However, the issues I described above are still present. Could this be a hardware fault?
                • J jcai
                  @jcai are you using a single IMX412 off M0173 J5?
                  C28 will setup a additional 4 sensors that likely will create some 'noise' in the logs when they fail to probe (assuming above sentence is accurate).
                  The sensor off J5 is "sensor ID 2", so we will want to use something like com.qti.sensormodule.imx412_fpv_2.bin:
                  E.g.
                  cp /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_2.bin /usr/lib/camera
                  If only a single sensor off J5, you won't want other com.qti.sensormodule*.bins in /usr/lib/camera/
                  After copying the .bin above to /usr/lib/camera, If you run voxl-camera-server -l , do you get a single sensor?
                  • modaltbM modaltb
                    E.g.
                    jcai
                    @modaltb yup, a single IMX412 on M0173 J5.
                    I've removed all the other com.qti.sensormodule*.bin files. These are the outputs I get when I run voxl-camera-server -l and voxl-camera-server with and without tracking_front enabled in the config file.
                    As you can see, I'm still getting the same strange behaviour.
                    Default C28:
                    voxl2:/$ voxl-camera-server -l
                    existing instance of voxl-camera-server found, attempting to stop it
                    DEBUG:   ----------- Number of cameras: 1
                    DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0577
                    DEBUG:   Note: This list comes from the HAL module and may not be indicative
                    DEBUG:          of configurations that have full pipelines
                    DEBUG:   Number of cameras: 1
                    Stats for camera: 0
                    ANDROID_SCALER_AVAILABLE_RAW_SIZES:
                    These are likely supported by the sensor
                    4056 x 3040
                    3840 x 2160
                    1920 x 1080
                    1920 x 1080
                    1920 x 1080
                    1280 x  720
                    1280 x  720
                    ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS:
                    These are NOT necessarily supported by the sensor
                    4056 x 3040 HAL_PIXEL_FORMAT_YCbCr_420_888
                    4056 x 3040 HAL_PIXEL_FORMAT_BLOB
                    4000 x 3000 HAL_PIXEL_FORMAT_YCbCr_420_888
                    4000 x 3000 HAL_PIXEL_FORMAT_BLOB
                    3840 x 2160 HAL_PIXEL_FORMAT_YCbCr_420_888
                    3840 x 2160 HAL_PIXEL_FORMAT_BLOB
                    3264 x 2448 HAL_PIXEL_FORMAT_YCbCr_420_888
                    3264 x 2448 HAL_PIXEL_FORMAT_BLOB
                    3200 x 2400 HAL_PIXEL_FORMAT_YCbCr_420_888
                    3200 x 2400 HAL_PIXEL_FORMAT_BLOB
                    2976 x 2976 HAL_PIXEL_FORMAT_YCbCr_420_888
                    2976 x 2976 HAL_PIXEL_FORMAT_BLOB
                    2688 x 1512 HAL_PIXEL_FORMAT_YCbCr_420_888
                    2688 x 1512 HAL_PIXEL_FORMAT_BLOB
                    2592 x 1944 HAL_PIXEL_FORMAT_YCbCr_420_888
                    2592 x 1944 HAL_PIXEL_FORMAT_BLOB
                    2048 x 1536 HAL_PIXEL_FORMAT_YCbCr_420_888
                    2048 x 1536 HAL_PIXEL_FORMAT_BLOB
                    1920 x 1440 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1920 x 1440 HAL_PIXEL_FORMAT_BLOB
                    1928 x 1208 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1928 x 1208 HAL_PIXEL_FORMAT_BLOB
                    1920 x 1080 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1920 x 1080 HAL_PIXEL_FORMAT_BLOB
                    1600 x 1200 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1600 x 1200 HAL_PIXEL_FORMAT_BLOB
                    1440 x 1080 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1440 x 1080 HAL_PIXEL_FORMAT_BLOB
                    1280 x  960 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1280 x  960 HAL_PIXEL_FORMAT_BLOB
                    1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1280 x  800 HAL_PIXEL_FORMAT_BLOB
                    1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1280 x  768 HAL_PIXEL_FORMAT_BLOB
                    1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1280 x  720 HAL_PIXEL_FORMAT_BLOB
                    1080 x 1080 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1080 x 1080 HAL_PIXEL_FORMAT_BLOB
                    1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1024 x  738 HAL_PIXEL_FORMAT_BLOB
                    1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
                    1024 x  768 HAL_PIXEL_FORMAT_BLOB
                     864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                     864 x  480 HAL_PIXEL_FORMAT_BLOB
                     800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
                     800 x  600 HAL_PIXEL_FORMAT_BLOB
                     800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                     800 x  480 HAL_PIXEL_FORMAT_BLOB
                     720 x 1280 HAL_PIXEL_FORMAT_YCbCr_420_888
                     720 x 1280 HAL_PIXEL_FORMAT_BLOB
                     720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                     720 x  480 HAL_PIXEL_FORMAT_BLOB
                     640 x  512 HAL_PIXEL_FORMAT_YCbCr_420_888
                     640 x  512 HAL_PIXEL_FORMAT_BLOB
                     640 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                     640 x  480 HAL_PIXEL_FORMAT_BLOB
                     640 x  400 HAL_PIXEL_FORMAT_YCbCr_420_888
                     640 x  400 HAL_PIXEL_FORMAT_BLOB
                     640 x  360 HAL_PIXEL_FORMAT_YCbCr_420_888
                     640 x  360 HAL_PIXEL_FORMAT_BLOB
                     352 x  288 HAL_PIXEL_FORMAT_YCbCr_420_888
                     352 x  288 HAL_PIXEL_FORMAT_BLOB
                     320 x  240 HAL_PIXEL_FORMAT_YCbCr_420_888
                     320 x  240 HAL_PIXEL_FORMAT_BLOB
                     240 x  320 HAL_PIXEL_FORMAT_YCbCr_420_888
                     240 x  320 HAL_PIXEL_FORMAT_BLOB
                     176 x  144 HAL_PIXEL_FORMAT_YCbCr_420_888
                     176 x  144 HAL_PIXEL_FORMAT_BLOB
                    4056 x 3040 HAL_PIXEL_FORMAT_RAW10
                    4056 x 3040 HAL_PIXEL_FORMAT_RAW12
                    4056 x 3040 HAL_PIXEL_FORMAT_RAW16
                    4056 x 3040 HAL_PIXEL_FORMAT_RAW_OPAQUE
                    ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
                            min = 100
                            max = 35200
                    ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
                            2200
                    ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
                            min = 0ns
                            max = 243753000ns
                    Number of cameras detected: 1
                    detected system image 1.7.10
                    using new imx412 defaults
                    configuration for 4 cameras:
                    cam #0
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               0
                        camId2:              -1
                        fps:                 30
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        small_video_width:   -1
                        small_video_height:  -1
                        en_large_video:      0
                        large_video_width:   -1
                        large_video_height:  -1
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        exif_focal_length:   0.000000
                        exif_focal_len_35mm_format:0
                        exif_fnumber:        0.000000
                        ae_mode:             lme_msv
                        msv_exposure_min_us: 20
                        msv_exposure_max_us: 33000
                        standby_enabled:     0
                        decimator:           1
                        independent_exposure:0
                    cam #1
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               1
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        small_video_width:   640
                        small_video_height:  480
                        en_large_video:      0
                        large_video_width:   4056
                        large_video_height:  3040
                        en_snapshot:         0
                        snap_width:          4056
                        snap_height:         3040
                        exif_focal_length:   3.100000
                        exif_focal_len_35mm_format:17
                        exif_fnumber:        1.240000
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #2
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               2
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      1
                        en_snapshot:         1
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #3
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               3
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    fsync_en:            1
                    fsync_gpio:          109
                    Starting Camera: tracking_front (id #0)
                    Connected to cpu-monitor
                    ERROR:   Camera 0 failed to find supported preview config: 1280x800
                    WARNING: Failed to start cam tracking_front due to invalid resolution
                    WARNING: assuming cam is missing and trying to compensate
                    Starting Camera: hires_front (originally id #1) with id offset: 1
                    Starting Camera: hires_down (originally id #2) with id offset: 1
                    WARNING: cam hires_down (id 1) does not seem to be alive
                    Starting Camera: tracking_down (originally id #3) with id offset: 1
                    WARNING: cam tracking_down (id 2) does not seem to be alive
                    ------ voxl-camera-server: Started 1 of 4 cameras
                    C28 with tracking_front disabled:
                    Stats for camera: 0
                    4056 x 3040
                    3840 x 2160
                    1920 x 1080
                    1920 x 1080
                    1920 x 1080
                    1280 x  720
                    1280 x  720
                            min = 100
                            max = 35200
                            2200
                            min = 0ns
                            max = 243753000ns
                    cam #0
                        sensor type:         ar0144
                        isEnabled:           0
                        camId:               0
                        camId2:              -1
                        fps:                 30
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    cam #1
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               1
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #2
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               2
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      1
                        en_snapshot:         1
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #3
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               3
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    fsync_en:            1
                    fsync_gpio:          109
                    Skipping Camera: tracking_front, configuration marked disabled
                    Starting Camera: hires_front (id #1)
                    WARNING: cam hires_front (id 1) does not seem to be alive
                    Starting Camera: hires_down (id #2)
                    WARNING: cam hires_down (id 2) does not seem to be alive
                    Starting Camera: tracking_down (id #3)
                    WARNING: cam tracking_down (id 3) does not seem to be alive
                    ERROR:   failed to initialize any cameras
                    ------ voxl-camera-server: Started 0 of 4 cameras
                    ------ voxl-camera-server: Camera server is now stopping
                    ------ voxl-camera-server: Camera server exited gracefully, returning -1
                    • J jcai
                      Default C28:
                      Stats for camera: 0
                      4056 x 3040
                      3840 x 2160
                      1920 x 1080
                      1920 x 1080
                      1920 x 1080
                      1280 x  720
                      1280 x  720
                              min = 100
                              max = 35200
                              2200
                              min = 0ns
                              max = 243753000ns
                      cam #0
                          sensor type:         ar0144
                          isEnabled:           1
                          camId:               0
                          camId2:              -1
                          fps:                 30
                          en_rotate:           1
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           1280
                          pre_height:          800
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             lme_msv
                          standby_enabled:     0
                          decimator:           1
                      cam #1
                          sensor type:         imx412
                          isEnabled:           1
                          camId:               1
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          0
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      0
                          en_small_video:      1
                          en_large_video:      0
                          en_snapshot:         0
                          snap_width:          4056
                          snap_height:         3040
                          ae_mode:             isp
                          standby_enabled:     0
                          decimator:           1
                      cam #2
                          sensor type:         imx412
                          isEnabled:           1
                          camId:               2
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          0
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      0
                          en_small_video:      1
                          en_large_video:      1
                          en_snapshot:         1
                          snap_width:          4056
                          snap_height:         3040
                          ae_mode:             isp
                          standby_enabled:     0
                          decimator:           1
                      cam #3
                          sensor type:         ar0144
                          isEnabled:           1
                          camId:               3
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           1280
                          pre_height:          800
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             lme_msv
                          standby_enabled:     0
                          decimator:           1
                      fsync_en:            1
                      fsync_gpio:          109
                      Stats for camera: 0
                      4056 x 3040
                      3840 x 2160
                      1920 x 1080
                      1920 x 1080
                      1920 x 1080
                      1280 x  720
                      1280 x  720
                              min = 100
                              max = 35200
                              2200
                              min = 0ns
                              max = 243753000ns
                      cam #0
                          sensor type:         ar0144
                          isEnabled:           0
                          camId:               0
                          camId2:              -1
                          fps:                 30
                          en_rotate:           1
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           1280
                          pre_height:          800
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             lme_msv
                          standby_enabled:     0
                          decimator:           1
                      cam #1
                          sensor type:         imx412
                          isEnabled:           1
                          camId:               1
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          0
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      0
                          en_small_video:      1
                          en_large_video:      0
                          en_snapshot:         0
                          snap_width:          4056
                          snap_height:         3040
                          ae_mode:             isp
                          standby_enabled:     0
                          decimator:           1
                      cam #2
                          sensor type:         imx412
                          isEnabled:           1
                          camId:               2
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          0
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      0
                          en_small_video:      1
                          en_large_video:      1
                          en_snapshot:         1
                          snap_width:          4056
                          snap_height:         3040
                          ae_mode:             isp
                          standby_enabled:     0
                          decimator:           1
                      cam #3
                          sensor type:         ar0144
                          isEnabled:           1
                          camId:               3
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           1280
                          pre_height:          800
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             lme_msv
                          standby_enabled:     0
                          decimator:           1
                      fsync_en:            1
                      fsync_gpio:          109
                      Alex KushleyevA Online
                      #10
                      @jcai , please back up your camera configuration file for your reference and then modify it.
                      Since you only have one camera connected, please remove all the camera configs except for one imx412 and change the camera id for that camera to 0.
                      The camera configuration file is located in /etc/modalai/voxl-camera-server.conf. It is probably going to be easier to edit the file in a text editor, unless you are comfortable with vi / vim
                      If you want to add back other cameras, you first add the sensormodules back to /usr/lib/camera, then perform voxl-camera-server -l scan and see which cameras are detected as which IDs. Then update camera config file to add back the camera you need and double check the camera IDs that are listed in the camera config should match what you saw in voxl-camera-server -l. you can tell which camera is which by looking at Slave Address and Sensor Id output of voxl-camera-server -l.
                      For example the signature for IMX412 is:
                      When camera server starts up, it goes through all the sensormodules in /usr/lib/camera and tries to use them to detect cameras on corresponding camera slots (each sensormodule is specific to a camera slot). Then the camera IDs are assigned the following way: lets say you detected three cameras in slots 1, 3, 4, so they will correspond to camera IDs (to be used in camera server config) as 0,1,2 (in the order of slot ids).
                        jcai
                        @Alex-Kushleyev Thanks, everything looks alright now that I've removed the other cameras from the config file
