  3. VOXL2 Camera Configuration not found
11 Posts 4 Posters 2.3k Views 3 Watching
  • J jcai
    I'm using a VOXL2 (board only), a micro-coax camera adapter (M0173), and an IMX412 (M0161).
    I'm following the documentation here. When configuring SKU, I can set 20 for VOXL2-board-only but camera configurations 26-30 don't appear. The same is true if I run voxl-configure-camera.
    Any ideas as to the cause? All components are connected to the VOXL already.
    VOXL currently thinks it is in the following hardware:
    family code:   MCCA-M0054 (voxl2-board-only)
    compute board: 4 (voxl2)
    hw version:    1
    cam config:    0
    modem config:   ()
    tx config:      ()
    extras config:  ()
    SKU:           MCCA-M0054-C0-M0-X0
    If this is what you want, select 1 (accept and continue) to
    leave it as-is. Otherwise, select the desired product family:
     1) accept and continue      12) voxlcam
     2) starling-2               13) seeker
     3) starling-2-max           14) rb5-flight
     4) starling                 15) flight-deck
     5) px4-autonomy-dev-kit     16) voxl-deck
     6) sentinel                 17) voxl2-flight-deck
     7) fpv                      18) voxl2-test-fixture
     8) D0010                    19) voxl2-mini-test-fixture
     9) stinger                  20) voxl2-board-only
    10) D0015                    21) voxl2-mini-board-only
    11) m500                     22) quit
    #? 20
    selected voxl2-board-only
    If you would like to select a special camera config that differs
    from the default for your product family, please select an option.
    Simply hit ENTER to use the default
    01 - ov7251 tracking ov7251 stereo
    02 - ov7251 tracking
    03 - ov7251 tracking ov7251 stereo imx214 hires
    04 - ov7251 tracking imx214 hires
    05 - pmd-tof ov7251 tracking
    06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
    08 - imx214
    09 - pmd-tof
    10 - ov7251 stereo
    11 - D0006 Sentinel
    12 - ov9782 stereo
    13 - ov9782 stereo imx214 hires
    14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
    15 - D0008 dual 9782 tracking
    16 - pmd-tof ov7251 dual tracking imx214 hires
    17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
    18 - D0008 triple ov9782
    19 - D0005 without tof imx214 hires ov7251 tracking
    20 - D0011 imx412 hires ar0144 tracking
    21 - old C6
    22 - D0013 voxl2 mini dual ar0144
    23 - D0010 without stereo
    24 - pmd-tof LIOW2 (new TOF)
    25 - dual ar0144
    31 - D0013 COAX dual ar0144 tracking
    32 - D0008 triple ov9782 rotated
     C - use user-defined custom camera config in
         (/data/modalai/custom_camera_config.txt)
     q - Quit The Wizard
    selection: ^C
    Josh
    @jcai You'll need to re-flash the latest SDK and select a kernel option for M0173 support. Different kernels are required to unlock different camera configs
    J 1 Reply Last reply
      J Offline
      J Offline
      jcai
      @tom I just flashed 1.3.5 and was able to configure C28. However, there still seems to be an issue.
      My camera is connected to J5 on the breakout, which should be hires_down. Using voxl-inspect-cam, the camera shows up as hires_front.
      Furthermore, if I disable just tracking_front in the camera server config file, the server will fail to initialize hires_front. Since I only have one camera physically connected, the camera server will not find any cameras and fail to start.
      J 3 Replies Last reply
      • J jcai
        J Offline
        J Offline
        jcai
        Also, I have a custom kernel build (that wasn't being used during my issues in my last comment) created by following this guide: https://docs.modalai.com/voxl2-kernel-build-guide/
        The only change I made in this kernel was to enable CONFIG_MACVLAN=y by editing kona-perf_defconfig in
        apps_proc/poky/meta-voxl2-bsp/recipes-kernel/linux-msm/files/configs/m0054
        However, as you said, this kernel version doesn't support the M0173 breakout board. How do I build a version that does while also adding my macvlan config?
        modaltbM 1 Reply Last reply
        • J jcai
          J Offline
          J Offline
          jcai
          • J jcai
            modaltbM Offline
            modaltbM Offline
            modaltb
            Hi @jcai ,
            Please build the kernel using the argument to specify a 'variant' of the kernel:
            ./qrb5165-build.sh -m M0054 -v var00.1
            I'm using this var00.1 variable to pull in these device tree files basically:
            https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/tree/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/variant/m0054/var00.1
            Specifically for cameras:
            https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/variant/m0054/var00.1/m0054-modalai-camera.dtsi?ref_type=heads#L4
            This happens here:
            https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/linux-msm_4.19.bbappend?ref_type=heads#L187
            For reference, the kernel tracks and exports info about itself to filesystem using this:
            https://gitlab.com/voxl-public/system-image-build/meta-voxl2/-/tree/qrb5165-ubun1.0-14.1a/recipes-kernel/voxl-platform-mod
            -Travis
            • J jcai
              J Offline
              J Offline
              jcai
              @jcai said in VOXL2 Camera Configuration not found:
              Thanks Travis, I was able to get a build with the correct configuration options as well as my own changes. However, the issues I described above are still present. Could this be a hardware fault?
              • J jcai
                modaltbM Offline
                modaltbM Offline
                modaltb
                @jcai are you using a single IMX412 off M0173 J5?
                C28 will setup a additional 4 sensors that likely will create some 'noise' in the logs when they fail to probe (assuming above sentence is accurate).
                The sensor off J5 is "sensor ID 2", so we will want to use something like com.qti.sensormodule.imx412_fpv_2.bin:
                E.g.
                cp /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_2.bin /usr/lib/camera
                If only a single sensor off J5, you won't want other com.qti.sensormodule*.bins in /usr/lib/camera/
                After copying the .bin above to /usr/lib/camera, If you run voxl-camera-server -l , do you get a single sensor?
                • modaltbM modaltb
                  E.g.
                  J Offline
                  J Offline
                  jcai
                  @modaltb yup, a single IMX412 on M0173 J5.
                  I've removed all the other com.qti.sensormodule*.bin files. These are the outputs I get when I run voxl-camera-server -l and voxl-camera-server with and without tracking_front enabled in the config file.
                  As you can see, I'm still getting the same strange behaviour.
                  Default C28:
                  voxl2:/$ voxl-camera-server -l
                  DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0577
                  DEBUG:          of configurations that have full pipelines
                  DEBUG:   Number of cameras: 1
                  Stats for camera: 0
                  4056 x 3040
                  3840 x 2160
                  1920 x 1080
                  1920 x 1080
                  1920 x 1080
                  1280 x  720
                  1280 x  720
                  1280 x  960 HAL_PIXEL_FORMAT_YCbCr_420_888
                  1280 x  960 HAL_PIXEL_FORMAT_BLOB
                  1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
                  1280 x  800 HAL_PIXEL_FORMAT_BLOB
                  1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
                  1280 x  768 HAL_PIXEL_FORMAT_BLOB
                  1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
                  1280 x  720 HAL_PIXEL_FORMAT_BLOB
                  1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
                  1024 x  738 HAL_PIXEL_FORMAT_BLOB
                  1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
                  1024 x  768 HAL_PIXEL_FORMAT_BLOB
                   864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                   864 x  480 HAL_PIXEL_FORMAT_BLOB
                   800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
                   800 x  600 HAL_PIXEL_FORMAT_BLOB
                   800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                   800 x  480 HAL_PIXEL_FORMAT_BLOB
                   720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                   720 x  480 HAL_PIXEL_FORMAT_BLOB
                   640 x  512 HAL_PIXEL_FORMAT_YCbCr_420_888
                   640 x  512 HAL_PIXEL_FORMAT_BLOB
                  4056 x 3040 HAL_PIXEL_FORMAT_RAW10
                  4056 x 3040 HAL_PIXEL_FORMAT_RAW12
                  4056 x 3040 HAL_PIXEL_FORMAT_RAW16
                  4056 x 3040 HAL_PIXEL_FORMAT_RAW_OPAQUE
                          min = 100
                          max = 35200
                          2200
                          min = 0ns
                          max = 243753000ns
                  Number of cameras detected: 1
                  detected system image 1.7.10
                  using new imx412 defaults
                  configuration for 4 cameras:
                  cam #0
                      sensor type:         ar0144
                      isEnabled:           1
                      camId:               0
                      camId2:              -1
                      fps:                 30
                      en_rotate:           1
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           1280
                      pre_height:          800
                      en_raw_preview:      1
                      en_small_video:      0
                      small_video_width:   -1
                      small_video_height:  -1
                      en_large_video:      0
                      large_video_width:   -1
                      large_video_height:  -1
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      exif_focal_length:   0.000000
                      exif_focal_len_35mm_format:0
                      exif_fnumber:        0.000000
                      ae_mode:             lme_msv
                      msv_exposure_min_us: 20
                      msv_exposure_max_us: 33000
                      standby_enabled:     0
                      decimator:           1
                      independent_exposure:0
                  cam #1
                      sensor type:         imx412
                      isEnabled:           1
                      camId:               1
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          0
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      0
                      en_small_video:      1
                      small_video_width:   640
                      small_video_height:  480
                      en_large_video:      0
                      large_video_width:   4056
                      large_video_height:  3040
                      en_snapshot:         0
                      snap_width:          4056
                      snap_height:         3040
                      exif_focal_length:   3.100000
                      exif_focal_len_35mm_format:17
                      exif_fnumber:        1.240000
                      ae_mode:             isp
                      standby_enabled:     0
                      decimator:           1
                  cam #2
                      sensor type:         imx412
                      isEnabled:           1
                      camId:               2
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          0
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      0
                      en_small_video:      1
                      en_large_video:      1
                      en_snapshot:         1
                      snap_width:          4056
                      snap_height:         3040
                      ae_mode:             isp
                      standby_enabled:     0
                      decimator:           1
                  cam #3
                      sensor type:         ar0144
                      isEnabled:           1
                      camId:               3
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           1280
                      pre_height:          800
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             lme_msv
                      standby_enabled:     0
                      decimator:           1
                  fsync_en:            1
                  fsync_gpio:          109
                  Starting Camera: tracking_front (id #0)
                  Connected to cpu-monitor
                  ERROR:   Camera 0 failed to find supported preview config: 1280x800
                  WARNING: Failed to start cam tracking_front due to invalid resolution
                  WARNING: assuming cam is missing and trying to compensate
                  Starting Camera: hires_front (originally id #1) with id offset: 1
                  Starting Camera: hires_down (originally id #2) with id offset: 1
                  WARNING: cam hires_down (id 1) does not seem to be alive
                  Starting Camera: tracking_down (originally id #3) with id offset: 1
                  WARNING: cam tracking_down (id 2) does not seem to be alive
                  ------ voxl-camera-server: Started 1 of 4 cameras
                  C28 with tracking_front disabled:
                  Stats for camera: 0
                  4056 x 3040
                  3840 x 2160
                  1920 x 1080
                  1920 x 1080
                  1920 x 1080
                  1280 x  720
                  1280 x  720
                          min = 100
                          max = 35200
                          2200
                          min = 0ns
                          max = 243753000ns
                  cam #0
                      sensor type:         ar0144
                      isEnabled:           0
                      camId:               0
                      camId2:              -1
                      fps:                 30
                      en_rotate:           1
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           1280
                      pre_height:          800
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             lme_msv
                      standby_enabled:     0
                      decimator:           1
                  cam #1
                      sensor type:         imx412
                      isEnabled:           1
                      camId:               1
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          0
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      0
                      en_small_video:      1
                      en_large_video:      0
                      en_snapshot:         0
                      snap_width:          4056
                      snap_height:         3040
                      ae_mode:             isp
                      standby_enabled:     0
                      decimator:           1
                  cam #2
                      sensor type:         imx412
                      isEnabled:           1
                      camId:               2
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          0
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      0
                      en_small_video:      1
                      en_large_video:      1
                      en_snapshot:         1
                      snap_width:          4056
                      snap_height:         3040
                      ae_mode:             isp
                      standby_enabled:     0
                      decimator:           1
                  cam #3
                      sensor type:         ar0144
                      isEnabled:           1
                      camId:               3
                      camId2:              -1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      pre_width:           1280
                      pre_height:          800
                      en_raw_preview:      1
                      en_small_video:      0
                      en_large_video:      0
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             lme_msv
                      standby_enabled:     0
                      decimator:           1
                  fsync_en:            1
                  fsync_gpio:          109
                  Skipping Camera: tracking_front, configuration marked disabled
                  Starting Camera: hires_front (id #1)
                  WARNING: cam hires_front (id 1) does not seem to be alive
                  Starting Camera: hires_down (id #2)
                  WARNING: cam hires_down (id 2) does not seem to be alive
                  Starting Camera: tracking_down (id #3)
                  WARNING: cam tracking_down (id 3) does not seem to be alive
                  ERROR:   failed to initialize any cameras
                  ------ voxl-camera-server: Started 0 of 4 cameras
                  ------ voxl-camera-server: Camera server is now stopping
                  ------ voxl-camera-server: Camera server exited gracefully, returning -1
                  • J jcai
                    Default C28:
                    Stats for camera: 0
                    4056 x 3040
                    3840 x 2160
                    1920 x 1080
                    1920 x 1080
                    1920 x 1080
                    1280 x  720
                    1280 x  720
                            min = 100
                            max = 35200
                            2200
                            min = 0ns
                            max = 243753000ns
                    cam #0
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               0
                        camId2:              -1
                        fps:                 30
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    cam #1
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               1
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #2
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               2
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      1
                        en_snapshot:         1
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #3
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               3
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    fsync_en:            1
                    fsync_gpio:          109
                    Stats for camera: 0
                    4056 x 3040
                    3840 x 2160
                    1920 x 1080
                    1920 x 1080
                    1920 x 1080
                    1280 x  720
                    1280 x  720
                            min = 100
                            max = 35200
                            2200
                            min = 0ns
                            max = 243753000ns
                    cam #0
                        sensor type:         ar0144
                        isEnabled:           0
                        camId:               0
                        camId2:              -1
                        fps:                 30
                        en_rotate:           1
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    cam #1
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               1
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #2
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               2
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          0
                        pre_width:           640
                        pre_height:          480
                        en_raw_preview:      0
                        en_small_video:      1
                        en_large_video:      1
                        en_snapshot:         1
                        snap_width:          4056
                        snap_height:         3040
                        ae_mode:             isp
                        standby_enabled:     0
                        decimator:           1
                    cam #3
                        sensor type:         ar0144
                        isEnabled:           1
                        camId:               3
                        camId2:              -1
                        fps:                 30
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           1280
                        pre_height:          800
                        en_raw_preview:      1
                        en_small_video:      0
                        en_large_video:      0
                        en_snapshot:         0
                        snap_width:          -1
                        snap_height:         -1
                        ae_mode:             lme_msv
                        standby_enabled:     0
                        decimator:           1
                    fsync_en:            1
                    fsync_gpio:          109
                    #10
                    @jcai , please back up your camera configuration file for your reference and then modify it.
                    Since you only have one camera connected, please remove all the camera configs except for one imx412 and change the camera id for that camera to 0.
                    The camera configuration file is located in /etc/modalai/voxl-camera-server.conf. It is probably going to be easier to edit the file in a text editor, unless you are comfortable with vi / vim
                    If you want to add back other cameras, you first add the sensormodules back to /usr/lib/camera, then perform voxl-camera-server -l scan and see which cameras are detected as which IDs. Then update camera config file to add back the camera you need and double check the camera IDs that are listed in the camera config should match what you saw in voxl-camera-server -l. you can tell which camera is which by looking at Slave Address and Sensor Id output of voxl-camera-server -l.
                    For example the signature for IMX412 is:
                    When camera server starts up, it goes through all the sensormodules in /usr/lib/camera and tries to use them to detect cameras on corresponding camera slots (each sensormodule is specific to a camera slot). Then the camera IDs are assigned the following way: lets say you detected three cameras in slots 1, 3, 4, so they will correspond to camera IDs (to be used in camera server config) as 0,1,2 (in the order of slot ids).
                      J Offline
                      J Offline
                      jcai
                      @Alex-Kushleyev Thanks, everything looks alright now that I've removed the other cameras from the config file
