  3. Switching between cameras in QGC
image-sensor
3 Posts 3 Posters 664 Views 1 Watching
  • LRL Offline
    LRL Offline
    LR
    I have a Starling v2 max with VOXL2 and when I connect to QGround Control I can see the images sent by the front camera. I want to switch between those and the images coming from the camera facing down, how can I do that?
    Jetson NanoJ Eric KatzfeyE 2 Replies Last reply
    • LRL LR
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @LR you might to change voxl-streamer config to change the feed to what is needed.
      • LRL LR
        @LR If you just want to change the camera that is streaming then modify /etc/modalai/voxl-streamer.conf to specify the desired camera. If you want to stream two or more cameras then you need to start a voxl-streamer instance for each one and specify a different port for each one. Then use voxl-mavcam-manager to inform QGC of the availability of the multiple streams. See https://docs.modalai.com/voxl-mavcam-manager/
