  2. VOXL SDK and Software
  3. voxl-mavlink-server GCS udp port
voxl-sdk
13 Posts 5 Posters 4.1k Views 1 Watching
  • J Offline
    jmltt
    Is there any benefit to making the udp port the mavlink server uses to communicate with QGC/the groundstation configurable? Like by loading in a value from the config file else defaulting to 14550
    Besides the udp ports used for the mavlink streams to/from px4 and voxl-mavlink-server (14556-14559) are there any other ports used by voxl services? I was probably going to just use 14560 - 14570 unless they're reserved for something else
    Reason:
    I'm trying to get a multi-vehicle (sentinels w/ latest sdk and microhard network) set up working and I'm noticing weird behavior when I try to connect to multiple vehicles in QGC. They (the vehicles) all have distinct mavlink sys ids and static ips on the same subnet but I noticed they're all using the same udp port to connect to the groundstation (hard coded in voxl-mavlink-server to 14550). I set up separate comm links in QGC for each vehicle with server address = <voxl-microhard-ip>:14550.
    When I start up qgc with 4 vehicles running and I try to connect to one of the vehicles it randomly connects to two additional vehicles. Then when I try to connect the remaining vehicle it switches the first vehicles that connect to a "secondary comm link" and the connection profile name gets mapped to the wrong vehicles. When I restart QGC after that it connects to all vehicles at once regardless of which connection profile I connect to and the comm link profile names don't get shown next to the vehicle.
    I'm assuming this is happening because they're all sending messages to the same udp port on the gcs pc. Doesn't seem like a big deal at the moment but I feel like it could lead to unexpected behavior if I try to interact with any of the vehicles through QGC. I'm not sure how QGC establishes the connection if it's actually binding a socket to the server address or just broadcasting locally on the designated port
    • J jmltt
      Reason:
      @jmltt This sounds more like a QGC issue. Are you sure QGC supports what you are trying to do?
      J 1 Reply Last reply
        jmltt
        @Eric-Katzfey I'm just trying to connect to and monitor multiple vehicles, yes QGC supports that
        I tested a modified voxl-mavlink-server with the configurable gcs udp port and assigned separate ports for each vehicle and it resolved the issue.
        I don't think it's a qgc issue unless their link manager is designed to differentiate multiple vehicles publishing to the same udp port on the ground station. I can raise the issue on their forum as well though
        I'm assuming 14560 - 14580 is a safe range, but is there any way to verify there are no conflicts short of going through every voxl service to check which publish/receive over udp?
        A 1 Reply Last reply
        • J Offline
          jmltt
          I just realized you could also probably resolve this issue by leaving the gcs ip addresses blank in the config file for voxl-mavlink-server. That would force QGC to make a server side connection because there wouldn't be any heartbeats on the local port (I think QGC link manager checks local udp port first, hence the auto connection issue).
          • J jmltt
            ashwin
            @jmltt Hi Man, so we are also trying to do something similar. We want to change the hard coded UDP port on the voxl crafts, it would be really helpful if you could share the modified voxl-mavlink-server with the configurable gcs udp port which worked for you. Thank you.
            • A ashwin
              jmltt
              @ashwin I just added a parameter called qgc_udp_port to config_file.h/c in voxl-mavlink-server (you can use the same syntax as used for any of the other port number variables in the config file to add it) and then added some logic to the gcs_io.c file where it makes the connections and rebuilt voxl-mavlink-server locally. I don't have that version somewhere publically available, but the required changes are so minor you could easily update and rebuild voxl-mavlink-server yourself
              In the gcs_io_init(void) function in gcs_io.c you could replace the line
              si_me_gcs.sin_port = htons(GCS_UDP_PORT);
              with something like
              si_me_gcs.sin_port = htons((uint16_t)qgc_udp_port);
              where qgc_udp_port is the variable you add to the config file. You'd also need to go the _add_connection(unsigned long ip) function and replace
              connections[i].sockaddr.sin_port = htons(GCS_UDP_PORT);
              with something like
              connections[i].sockaddr.sin_port = htons((uint16_t)gcs_udp_publish_port);
              I also added some logic to check that the user generated port number is within a valid range and only change it for each connection if it's not equal to the value defined by GCS_UDP_PORT (14550), but that's not strictly necessary.
              This was all done for voxl-mavlink-server in SDK 1.3.5. I don't know how much the logic has changed in the more recent SDK versions, but I imagine these changes would carry over
              Eric KatzfeyE Aaron PorterA 2 Replies Last reply
              • J jmltt
                with something like
                with something like
                @jmltt There were some places in voxl-mavlink-server where the system id was hardcoded to 1. This may have been causing problems when trying to enable multi-uav support in QGC. That has now been fixed and so it should be possible to use multi-uav in QGC now where each vehicle is assigned a separate system id. http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mavlink-server_1.4.12-202509181025_arm64.deb
                • J jmltt
                  with something like
                  with something like
                  Aaron PorterA Offline
                  Aaron Porter
                  @jmltt So reading the original issue that you were having back in November. The Deb file that Eric posted will solve the issue of mismatching communication links in QGC. I tested it and it works. The problem was that the voxl-mavlink-server was assigning every drone sys id 1 regardless of the MAV_SYS_ID parameter. This resulted in QGC assuming each of the drones were the same since the SYS ID on connection were the same.
                  Now as for why the drones were all connecting at once sounds like the autoconnect for UDP is enabled. The drones should not connect unless given the IP address + Port number in the comm link like you described. If QGC is setup to autoconnect to any UDP connections then that would explain why since all of the drone are set to communicate on 14550.
                  https://docs.qgroundcontrol.com/master/en/qgc-user-guide/settings_view/general.html#auto_connect
                  I understand why changing the port number would help prevent confusion but I don't think 4 drones using port 14550 is the issue as other have had multiple drones all on 14550 connected to a single QGC instance. There are issues if you are suing a simulation but not for physical drones.
                  • Aaron PorterA Aaron Porter
                    jmltt
                    @Aaron-Porter I'm sure the system id fix might have resolved the issue. I just find having separate ports for each vehicle to establish a connection over a cleaner option. This isn't an issue for me anymore, I was just responding to the question on the approach I used to resolve it
                    Aaron PorterA 1 Reply Last reply
                    • J jmltt
                      Aaron Porter
                      @jmltt I understand it is personal preference, I just wanted to give more detail on the issue that you were originally seeing incase anyone else ran into the same problem. Shouldn't happen in the future with the recent changes, but some still use older SDK versions.
                      • B Offline
                        B Offline
                        brandon
                        I am also having this issue. I think that the voxl-mavlink-server may have an incorrect implementation of the "server" side of the UDP connection. My evidence would be that using mavproxy.py from a remote computer in client mode (e.g. mavproxy.py --master=udpout:192.168.83.254:14550) does not receive packets from the server, but the server does detect the connection.
                        I took a look at wireshark and saw that the voxl-mavlink-server in "server" mode is not replying to the mavproxy.py client on the correct port. It is replying to 14550 at the client (incorrect). See the picture below, but ignore IPs as data capture was on a different network. You can see the mavproxy client sending from port 33935 to voxl at 14550, but the voxl incorrectly replies back to 14550 on the client computer when it should be replying back to 33935.
                        The side-effect of this is that you cannot have two independent clients (talking to different drones) running on the same computer because both drones will send their data to the same port. Computers only allow one process to be a server on a given port.
                        • B brandon
                          @brandon Agreed, the code has a fixed port but should use the source port. We will fix that and also add configurable ports for the gcs IP addresses in the configuration file.
                          • B brandon
                            @brandon The latest voxl-mavlink-server is available here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mavlink-server_1.4.12-202511040816_arm64.deb. This has added configuration for the GCS ports and also fixes the above issue so that it now responds to the correct port.
