  3. Missing C27 config file for Starling 2 Image Sensor Micro-coax Front-end Adapter (MDK-M0173) in voxl 2.
7 Posts 3 Posters 827 Views 1 Watching
  • aryan yadavA Offline
    aryan yadav
    When running voxl-configure-sku in voxl 2 there is no config file for c27 configuration, how to setup for c27 camera configuration for Starling 2 Image Sensor Micro-coax Front-end Adapter MDK-M0173-1-02.
    Jetson NanoJ tomT 2 Replies Last reply
    • aryan yadavA aryan yadav
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @aryan-yadav Which SDK version are you using and are you getting any options for c27 config while running voxl-configure-cameras ?
      aryan yadavA 1 Reply Last reply
        @aryan-yadav When loading the SDK via the install.sh script you need to make sure you choose the correct kernel option for the M0173 board. I would recommend running through the install again and selecting the M0173 kernel option which unlocks the C26-30 camera config options
        • Jetson NanoJ Jetson Nano
          aryan yadav
          @Jetson-Nano said in Missing C27 config file for Starling 2 Image Sensor Micro-coax Front-end Adapter (MDK-M0173) in voxl 2.:
          Hi @Jetson-Nano I'm running 1.3.5 and No I'm not getting option 27 that is basically for c27 camera configuration.
            aryan yadav
            @tom I've bought the pre flashed voxl 2 devkit, so I didn't run any install.sh script, I directly plugged the board with camera board i.e. starling 2 front end and directly performed adb shell using my host device. Do I need to reflash the image and build the kernel or can the kernel be updated/reconfigured without flashing?
              @aryan-yadav You'll just need to download SDK 1.3.5, unzip it, and run install.sh, it'll ask you what config you'd like to flash and you'll want to select the M0173 option which will flash the correct kernel in order to support the M0173 and those camera configs
                @aryan-yadav If you had purchased a drone with the M0173 it would've already had the correct kernel flashed but we ship bare boards with the default kernel
