  3. Unknown px4 firmware after SDK upgrade
rb5
7 Posts 2 Posters 1.5k Views 1 Watching
  • V Offline
    V Offline
    vjuliani
    After I flashed VOXL SDK 1.1.2 on RB5, the firmware version is unknown in QGC.
    This is voxl-version:
    What should I do?
    Also, I lost the calibration files of gyroscope, accelerometer, gps, etc. Can you send me them?
    • V Offline
      V Offline
      vjuliani
      To flash VOXL SDK 1.12, I used an ubuntu 22.04 laptop and did run the install.sh script.
      After that I had the error above in QGC.
      Is there any more steps necessary to upgrade the SDK and PX4 firmware?
      • V Offline
        V Offline
        vjuliani
        The files missing are:
        • V vjuliani
          Eric KatzfeyE Online
          @vjuliani Can you rerun those calibrations?
          • V vjuliani
            What should I do?
            @vjuliani QGC may complain about our version of PX4 but that is okay. We have a forked version of PX4 and the parameter sets don't necessarily align perfectly with what QGC wants to see.
            • V Offline
              V Offline
              vjuliani
              Hi, @Eric-Katzfey
              Thanks for your reply!
              I runned voxl-configure-mpa again and the problem was fixed.
              Also, I did all the sensors calibration and it worked.
              However, even after upgrading VOXL SDK from 0.9.5 to 1.1.2, I am still having the same issue when trying outdoor flight.
              The issue is similar to the https://forum.modalai.com/topic/3410/outdoor-navigation-problem one.
              When I try an outdoor flight in position mode using EKF2_GPS_CHECK to 245, QGC shows a lot of GPS Speed Accuracy too low failure messages. With that, the drone status remains in Not Ready and it can't fly.
              If I try to set EKF2_GPS_CHECK to 1, I get Pre-flight check failure: GPS Position Required messages from QGC. So, the status remains in Not Ready and the drone can't fly.
              The only manner I found the drone flight to work was to set COM_ARM_WO_GPS to 1 and use altitude or manual flight mode.
              I think it might be a gps hardware issue, like the one in the topic linked above.
              The GPS model I had is M8N and I already had this issue with VOXL SDK 0.9.5.
              Any suggestions?
              • V Offline
                V Offline
                vjuliani
                wrote on last edited by vjuliani
                I created a new topic about the GPS problem https://forum.modalai.com/topic/3612/outdoor-navigation-gps-problem
