    Vision Hub Issue
    • KrisK
      Kris
      Hello, I am having a problem with my VOA and VIO unstable flights.
      I am on the Seeker Voxl1 with a fresh stable release of the voxl_SDK_1.2.0.
      This is the error message when I check my voxl-vision-hub;
      voxl:~$ voxl-vision-hub
      loading our own config file
      config_file_version:        1
      MAVROS / MAVSDK
      en_localhost_mavlink_udp    1
      localhost_udp_port_number:  14551
      VIO
      en_vio:                     1
      vio_pipe:                   qvio
      secondary_vio_pipe:         ov
      en_reset_vio_if_initialized_inverted: 1
      vio_warmup_s:               3.000000
      send_odom_while_failed:     1
      APQ8096-ONLY FEATURES
      en_set_clock_from_gps:      1
      en_force_onboard_mav1_mode: 1
      en_reset_px4_on_error:      1
      MISC FEATURES
      horizon_cal_tolerance:      0.500000
      OFFBOARD MODE
      offboard_mode:              trajectory
      follow_tag_id:              0
      figure_eight_move_home:     1
      robot_radius:               0.300000
      collision_sampling_dt:      0.100000
      max_lookahead_distance:     1.000000
      FIXED FRAME RELOCALIZATION
      en_tag_fixed_frame:         0
      fixed_frame_filter_len:     5
      COLLISION PREVENTION (VOA)
      en_voa:                     1
      voa_upper_bound_m:          -0.150000
      voa_lower_bound_m:          0.150000
      voa_memory_s:               1.000000
      voa_max_pc_per_fusion:      100
      voa_pie_min_dist_m:         0.250000
      voa_pie_max_dist_m:         20.000000
      voa_pie_under_trim_m:       1.000000
      voa_pie_threshold:          3
      voa_pie_slices:             36
      voa_pie_bin_depth_m:        0.150000
      voa_send_rate_hz:           20.000000
      voa_input #0
          enabled:            1
          type:               point_cloud
          input_pipe:         dfs_point_cloud
          frame:              stereo_l
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          x_fov_deg:          68.000000
          y_fov_deg:          56.000000
          conf_cutoff:        0
      voa_input #1
          enabled:            1
          type:               point_cloud
          input_pipe:         stereo_front_pc
          frame:              stereo_front_l
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #2
          enabled:            1
          type:               point_cloud
          input_pipe:         stereo_rear_pc
          frame:              stereo_rear_l
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #3
          enabled:            1
          type:               tof
          input_pipe:         tof
          frame:              tof
          max_depth:          6.000000
          min_depth:          0.150000
          cell_size:          0.080000
          threshold:          3
          x_fov_deg:          106.500000
          y_fov_deg:          85.099998
          conf_cutoff:        125
      voa_input #4
          enabled:            1
          type:               rangefinder
          input_pipe:         rangefinders
          frame:              body
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      loading extrinsics config file
      loading horizon cal file
      existing instance of voxl-vision-hub found, attempting to stop it
      starting geometry module
      starting autopilot monitor
      starting mavlink IO
      Waiting to connect to voxl-mavlink-server
      Connected to voxl-mavlink-server
      starting mavlink for ros
      starting fixed pose input
      starting vio manager
      Connected to VIO pipe: qvio
      Geometry module updating to use imu: imu1 for VIO
      new T imu wrt body:
       0.0465   0.0332  -0.0130
      new R imu to body:
       0.0000  -0.0000   1.0000
       1.0000   0.0000  -0.0000
      -0.0000   1.0000   0.0000
      done updating transforms to use imu: imu1
      Detected Autopilot Mavlink SYSID 1
      starting tag manager
      starting voa manager
      Connected to VOA input pipe: dfs_point_cloud
      Connected to VOA input pipe: tof
      starting horizon cal module
      starting offboard trajectory
      Trajectory Monitor connected to voa pointcloud
      Init complete
      ERROR validating TOF2 data received through pipe: read partial packet
      read 693516 bytes, but it should be a multiple of 693516
      make sure you are using a recent voxl-camera-server that publishes a tof2_data_t type
      it's likely you are using an old voxl-camera-server
      WARNING in VOA manager, no attitude data from px4
      requesting autopilot_version
      Detected autopilot version: 1.11.3
      ^C
      received SIGINT Ctrl-C
      Starting shutdown sequence
      stopping offboard trajectory
      exiting offboard trajectory thread
      stopping horizon_cal
      stopping voa manager
      exiting VOA thread
      stopping tag manager
      stopping vio manager
      stopping fixed pose in module
      Stopping mavlink for ros module
      exiting mavlink for ros localhost udp listener thread
      udp mavlink for ros stopped
      Stopping mavlink io module
      waiting for mavlink timer thread to join
      Stopping autopilot monitor
      closing remaining client pipes
      closing remaining server pipes
      Removing PID file
      exiting
      Here is what is currently running;
      voxl:~$ voxl-inspect-services
      Scanning services...
       docker-daemon            | Disabled  | Not Running |
       voxl-camera-server       |  Enabled  |   Running   |     6.5%
       voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
       voxl-dfs-server          |  Enabled  |   Running   |    13.0%
       voxl-imu-server          |  Enabled  |   Running   |     0.0%
       voxl-mavlink-server      |  Enabled  |   Running   |     4.3%
       voxl-portal              |  Enabled  |   Running   |     0.0%
       voxl-qvio-server         |  Enabled  |   Running   |     6.5%
       voxl-streamer            | Disabled  | Not Running |
       voxl-vision-hub          |  Enabled  |   Running   |     2.1%
      voxl:~$ voxl-vision-hub -s
      MAVROS / MAVSDK
      VIO
      en_vio:                     1
      vio_pipe:                   qvio
      MISC FEATURES
      OFFBOARD MODE
      follow_tag_id:              0
      en_voa:                     1
      voa_pie_slices:             36
      voa_input #0
          enabled:            1
          type:               point_cloud
          frame:              stereo_l
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #1
          enabled:            1
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #2
          enabled:            1
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #3
          enabled:            1
          type:               tof
          input_pipe:         tof
          frame:              tof
          max_depth:          6.000000
          min_depth:          0.150000
          cell_size:          0.080000
          threshold:          3
          conf_cutoff:        125
      voa_input #4
          enabled:            1
          type:               rangefinder
          frame:              body
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      starting mavlink IO
      new T imu wrt body:
      new R imu to body:
      Init complete
      slice  0  dist none back
      slice  1  dist none
      slice  2  dist none
      slice  3  dist none
      slice  4  dist none
      slice  5  dist none
      slice  6  dist none
      slice  7  dist none
      slice  8  dist none
      slice  9  dist none left
      slice 10  dist none
      slice 11  dist none
      slice 12  dist none
      slice 13  dist none
      slice 14  dist none
      slice 15  dist none
      slice 16  dist none
      slice 17  dist none
      slice 18  dist none forward
      slice 19  dist none
      slice 20  dist none
      slice 21  dist none
      slice 22  dist none
      slice 23  dist none
      slice 24  dist none
      slice 25  dist none
      slice 26  dist none
      slice 27  dist none right
      slice 28  dist none
      slice 29  dist none
      slice 30  dist none
      slice 31  dist none
      slice 32  dist none
      slice 33  dist none
      slice 34  dist none
      slice 35  dist none
      slice  1  dist none
      slice  2  dist none
      slice  3  dist none
      slice  4  dist none
      slice  5  dist none
      slice  6  dist none
      slice  7  dist none
      slice  8  dist none
      slice 10  dist none
      slice 11  dist none
      slice 12  dist none
      slice 13  dist none
      slice 14  dist none
      slice 15  dist none
      slice 16  dist none
      slice 17  dist none
      slice 19  dist none
      slice 20  dist 1.91m
      slice 21  dist none
      slice 22  dist none
      slice 23  dist none
      slice 24  dist none
      slice 25  dist none
      slice 26  dist none
      slice 28  dist none
      slice 29  dist none
      slice 30  dist none
      slice 31  dist none
      slice 32  dist none
      slice 33  dist none
      slice 34  dist none
      slice 35  dist none
      slice  1  dist none
      slice  2  dist none
      slice  3  dist none
      slice  4  dist none
      slice  5  dist none
      slice  6  dist none
      slice  7  dist none
      slice  8  dist none
      slice 10  dist none
      slice 11  dist none
      slice 12  dist none
      slice 13  dist none
      slice 14  dist none
      slice 15  dist none
      slice 16  dist none
      slice 17  dist none
      slice 19  dist none
      slice 20  dist 1.91m
      slice 21  dist none
      slice 22  dist none
      slice 23  dist none
      slice 24  dist none
      slice 25  dist none
      slice 26  dist none
      slice 28  dist none
      slice 29  dist none
      slice 30  dist none
      slice 31  dist none
      slice 32  dist none
      slice 33  dist none
      slice 34  dist none
      slice 35  dist none
      voxl:~$ voxl-version
      system-image: 4.0.0
      kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
      hw platform:  VOXL
      mach.var:     1.0
      voxl-suite:   1.2.0
      Packages:
      Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-1.2/binary-arm64/
      Last Updated: 2024-06-28 07:54:15
      List:
      	apq8096-dfs-server          0.3.1
      	apq8096-imu-server          1.1.0
      	apq8096-libpng              1.6.38-1
      	apq8096-rangefinder-server  0.1.3
      	apq8096-system-tweaks       0.2.3
      	apq8096-tflite              2.8.3-1
      	libapq8096-io               0.6.1
      	libmodal-cv                 0.4.0
      	libmodal-exposure           0.1.0
      	libmodal-journal            0.2.2
      	libmodal-json               0.4.3
      	libmodal-pipe               2.10.0
      	libvoxl-cci-direct          0.2.1
      	libvoxl-cutils              0.1.1
      	voxl-camera-calibration     0.5.4
      	voxl-camera-server          1.9.2
      	voxl-configurator           0.5.6
      	voxl-cpu-monitor            0.4.8
      	voxl-docker-support         1.3.1
      	voxl-jpeg-turbo             2.1.3-5
      	voxl-lepton-server          1.2.0
      	voxl-logger                 0.4.0
      	voxl-mavcam-manager         0.5.3
      	voxl-mavlink                0.1.1
      	voxl-mavlink-server         1.4.0
      	voxl-modem                  1.0.9
      	voxl-mongoose               7.7.0-1
      	voxl-mpa-to-ros             0.3.7
      	voxl-mpa-tools              1.1.5
      	voxl-opencv                 4.5.5-2
      	voxl-portal                 0.6.5
      	voxl-qvio-server            1.0.2
      	voxl-streamer               0.7.4
      	voxl-suite                  1.2.0
      	voxl-system-image           4.0-r0
      	voxl-tag-detector           0.0.4
      	voxl-tflite-server          0.3.2
      	voxl-utils                  1.3.9
      	voxl-uvc-server             0.1.6
      	voxl-vision-hub             1.7.4
      	voxl-vpn                    0.0.6
      voxl:/$ voxl-inspect-qvio
      waiting for server
       dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state||
         30.0 |    0.00    0.00    0.00|  -0.0   -0.1    0.1|    23  |  100% | OKAY |C
      closing and exiting
      voxl-inspect-cam qvio
      | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fpt
      ERROR: invalid metadata, magic number=88429860, expected 1448040524
      most likely client fell behind and pipe overflowed
      voxl-inspect-cam stereo
      |    stereo |  614400 |  640 |  480 |  5.07 |  125 |     8787 |     28.0  | 30
      voxl-inspect-cam tracking
      | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  t
      |  tracking |  307200 |  640 |  480 |  5.01 |  100 |    10838 |     12.3  | 3C
      voxl-inspect-cam tof
      |       tof |       0 |    0 |    0 |  0.00 |    0 |        0 |     25.4  |  8
      ERROR: invalid metadata, magic number=0, expected 1448040524
      Everything in Voxl Portal seems to be working as normal though.
      KrisK 1 Reply Last reply Reply Quote 0
      • KrisK
        Kris @Kris
        I have also reverted the SDK to voxl_platform_0.9.5 and everything was working fine. It does not seem like a hardware issue. So I am wondering why the two newer SDK's are giving me issues with VIO and VOA.
        • ModeratorM
          Moderator ModalAI Team @Kris
          @Kris we would need a lot more information to provide an educated guess.
          Have you gone through the Troubleshooting VIO document? https://docs.modalai.com/flying-with-vio/#troubleshooting-vio
          Have you looked at the qvio_overlay?
          "unstable flight" could mean so many things. We recommend you break it down into smaller problems.
          1. how well does it fly in manual? Do the PX4 logs look good?
          2. how well does it fly with VIO?
          3. Does qvio_overlay indicate any issues?
          4. enable VOA, do things change?
          5. do the VOA diagnostic tools show anything?
          • KrisK
            Kris @Moderator
            @Moderator
            Thank you for your reply,
            Yes, I have gone through the troubleshooting guides for VIO.
            Yes, I have looked at the qvio_overlay. It was actually one of the first things I did. Everything looked normal but then suddenly the point percentage would drop from 100% to 0% when the seeker was on the bench.
            1. The seeker performs as usualy in manual flight modes, otherthan the usual low stick throttle when trying to ascend.
            2. It will fly ok in VIO, the main problem is with VOA. I cannot even disable the VOA. After disabling VOA in voxl-vision-hub.conf, nothing changes in PX4. QGC says that VOA is still on and the Seeker does not move in any direction. When VOA is enabled, Obstacle distance remains at 2001,2001,2001,2001.... and does not change when I place my hand in front of the sensors on the Seeker. Then I will try to fly the Seeker with VOA enabled at 0.6 to 1 meter stopping distance, VOA does not work.
            3. qvio_overlay does not indicate any issues.
            4. Enabling and disabling VOA changes things but not in a good way as I mentioned above in #2 response.
            5. I posted the diagnostics of all these issues above in my first post.
            This only happens with voxl_SDK_1.1.0, 1.1.1, 1.1.2, and 1.2.0 releases.
            There are no problems with the voxl_platform_0.9.5 release.
            • KrisK
              Kris @Kris
              voxl:/$ voxl-list-pipes -t
              camera_image_metadata_t
              	dfs_disparity
              	dfs_disparity_scaled
              	qvio_overlay
              	stereo
              	tof_conf
              	tof_depth
              	tof_ir
              	tracking
              cpu_stats_t
              	cpu_monitor
              ext_vio_data_t
              	qvio_extended
              imu_data_t
              	imu0
              	imu1
              mavlink_message_t
              	mavlink_ap_heartbeat
              	mavlink_attitude
              	mavlink_from_gcs
              	mavlink_gps_raw_int
              	mavlink_local_position_ned
              	mavlink_onboard
              	mavlink_sys_status
              	mavlink_to_gcs
              point_cloud_metadata_t
              	dfs_point_cloud
              	tof_pc
              	voa_pc_out
              pose_vel_6dof_t
              	vvhub_body_wrt_fixed
              	vvhub_body_wrt_local
              string
              	gcs_ip_list
              text
              	horizon_cal_io
              tof_data_t
              	tof
              vio_data_t
              	qvio
              James StrawsonJ 1 Reply Last reply Reply Quote 0
              • James StrawsonJ
                James Strawson ModalAI Team @Kris
                @Kris I found and fixed a bug in voxl-camera-server that seems to be the culprit. I flashed my seeker with SDK1.2.0 and sideloaded the following voxl-camera-server with the bugfix to re-enable ingestion of TOF data into voxl-vision-hub
                http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64/voxl-camera-server_1.9.7_202407111658.ipk
                Note VOA simply does not work in the default PX4 acceleration-based position mode so MPC_POS_MODE needs to be set to 0 (velocity control) as done by the voa_enable px4 param helper file here:
                https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/dev/params/v1.14/voa_helpers/voa_enable_indoor.params?ref_type=heads
