  3. Vision Hub Issue
Vision Hub Issue
6 Posts 3 Posters 1.9k Views 1 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    wrote on last edited by Kris
    Hello, I am having a problem with my VOA and VIO unstable flights.
    I am on the Seeker Voxl1 with a fresh stable release of the voxl_SDK_1.2.0.
    This is the error message when I check my voxl-vision-hub;
    voxl:~$ voxl-vision-hub
    loading our own config file
    config_file_version:        1
    MAVROS / MAVSDK
    en_localhost_mavlink_udp    1
    VIO
    en_vio:                     1
    vio_pipe:                   qvio
    secondary_vio_pipe:         ov
    vio_warmup_s:               3.000000
    send_odom_while_failed:     1
    APQ8096-ONLY FEATURES
    en_set_clock_from_gps:      1
    en_force_onboard_mav1_mode: 1
    en_reset_px4_on_error:      1
    MISC FEATURES
    horizon_cal_tolerance:      0.500000
    OFFBOARD MODE
    offboard_mode:              trajectory
    follow_tag_id:              0
    figure_eight_move_home:     1
    robot_radius:               0.300000
    collision_sampling_dt:      0.100000
    max_lookahead_distance:     1.000000
    FIXED FRAME RELOCALIZATION
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    COLLISION PREVENTION (VOA)
    en_voa:                     1
    voa_upper_bound_m:          -0.150000
    voa_lower_bound_m:          0.150000
    voa_memory_s:               1.000000
    voa_max_pc_per_fusion:      100
    voa_pie_min_dist_m:         0.250000
    voa_pie_max_dist_m:         20.000000
    voa_pie_under_trim_m:       1.000000
    voa_pie_threshold:          3
    voa_pie_slices:             36
    voa_pie_bin_depth_m:        0.150000
    voa_send_rate_hz:           20.000000
    voa_input #0
        enabled:            1
        type:               point_cloud
        input_pipe:         dfs_point_cloud
        frame:              stereo_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        x_fov_deg:          68.000000
        y_fov_deg:          56.000000
        conf_cutoff:        0
    voa_input #1
        enabled:            1
        type:               point_cloud
        input_pipe:         stereo_front_pc
        frame:              stereo_front_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #2
        enabled:            1
        type:               point_cloud
        input_pipe:         stereo_rear_pc
        frame:              stereo_rear_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #3
        enabled:            1
        type:               tof
        input_pipe:         tof
        frame:              tof
        max_depth:          6.000000
        min_depth:          0.150000
        cell_size:          0.080000
        threshold:          3
        x_fov_deg:          106.500000
        y_fov_deg:          85.099998
        conf_cutoff:        125
    voa_input #4
        enabled:            1
        type:               rangefinder
        input_pipe:         rangefinders
        frame:              body
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    loading horizon cal file
    existing instance of voxl-vision-hub found, attempting to stop it
    starting geometry module
    starting autopilot monitor
    starting mavlink IO
    Waiting to connect to voxl-mavlink-server
    starting mavlink for ros
    starting fixed pose input
    starting vio manager
    Connected to VIO pipe: qvio
    Geometry module updating to use imu: imu1 for VIO
    new T imu wrt body:
     0.0465   0.0332  -0.0130
    new R imu to body:
     0.0000  -0.0000   1.0000
     1.0000   0.0000  -0.0000
    -0.0000   1.0000   0.0000
    done updating transforms to use imu: imu1
    Detected Autopilot Mavlink SYSID 1
    starting tag manager
    starting voa manager
    Connected to VOA input pipe: dfs_point_cloud
    Connected to VOA input pipe: tof
    starting horizon cal module
    starting offboard trajectory
    Trajectory Monitor connected to voa pointcloud
    Init complete
    ERROR validating TOF2 data received through pipe: read partial packet
    read 693516 bytes, but it should be a multiple of 693516
    make sure you are using a recent voxl-camera-server that publishes a tof2_data_t type
    it's likely you are using an old voxl-camera-server
    WARNING in VOA manager, no attitude data from px4
    requesting autopilot_version
    Detected autopilot version: 1.11.3
    ^C
    received SIGINT Ctrl-C
    Starting shutdown sequence
    stopping offboard trajectory
    exiting offboard trajectory thread
    stopping horizon_cal
    stopping voa manager
    exiting VOA thread
    stopping tag manager
    stopping vio manager
    stopping fixed pose in module
    Stopping mavlink for ros module
    exiting mavlink for ros localhost udp listener thread
    udp mavlink for ros stopped
    Stopping mavlink io module
    waiting for mavlink timer thread to join
    Stopping autopilot monitor
    closing remaining client pipes
    closing remaining server pipes
    Removing PID file
    exiting
    Here is what is currently running;
    voxl:~$ voxl-inspect-services
    Scanning services...
     Service Name             |  Enabled  |   Running   |  CPU Usage
     docker-autorun           | Disabled  | Not Running |
     docker-daemon            | Disabled  | Not Running |
     modallink-relink         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  |   Running   |     6.5%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          |  Enabled  |   Running   |    13.0%
     voxl-imu-server          |  Enabled  |   Running   |     0.0%
     voxl-lepton-server       | Disabled  | Not Running |
     voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server      |  Enabled  |   Running   |     4.3%
     voxl-modem               | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.0%
     voxl-qvio-server         |  Enabled  |   Running   |     6.5%
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-remote-id           | Disabled  | Not Running |
     voxl-streamer            | Disabled  | Not Running |
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-time-sync           | Disabled  | Not Running |
     voxl-uvc-server          | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     2.1%
     voxl-wait-for-fs         |  Enabled  |  Completed  |
    voxl:~$ voxl-vision-hub -s
    MAVROS / MAVSDK
    VIO
    en_vio:                     1
    vio_pipe:                   qvio
    MISC FEATURES
    OFFBOARD MODE
    follow_tag_id:              0
    en_voa:                     1
    voa_pie_slices:             36
    voa_input #0
        enabled:            1
        type:               point_cloud
        frame:              stereo_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #1
        enabled:            1
        type:               point_cloud
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #2
        enabled:            1
        type:               point_cloud
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #3
        enabled:            1
        type:               tof
        input_pipe:         tof
        frame:              tof
        max_depth:          6.000000
        min_depth:          0.150000
        cell_size:          0.080000
        threshold:          3
        conf_cutoff:        125
    voa_input #4
        enabled:            1
        type:               rangefinder
        frame:              body
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    starting mavlink IO
    new T imu wrt body:
    new R imu to body:
    Init complete
    slice  0  dist none back
    slice  1  dist none
    slice  2  dist none
    slice  3  dist none
    slice  4  dist none
    slice  5  dist none
    slice  6  dist none
    slice  7  dist none
    slice  8  dist none
    slice  9  dist none left
    slice 10  dist none
    slice 11  dist none
    slice 12  dist none
    slice 13  dist none
    slice 14  dist none
    slice 15  dist none
    slice 16  dist none
    slice 17  dist none
    slice 18  dist none forward
    slice 19  dist none
    slice 20  dist none
    slice 21  dist none
    slice 22  dist none
    slice 23  dist none
    slice 24  dist none
    slice 25  dist none
    slice 26  dist none
    slice 27  dist none right
    slice 28  dist none
    slice 29  dist none
    slice 30  dist none
    slice 31  dist none
    slice 32  dist none
    slice 33  dist none
    slice 34  dist none
    slice 35  dist none
    slice  1  dist none
    slice  2  dist none
    slice  3  dist none
    slice  4  dist none
    slice  5  dist none
    slice  6  dist none
    slice  7  dist none
    slice  8  dist none
    slice 10  dist none
    slice 11  dist none
    slice 12  dist none
    slice 13  dist none
    slice 14  dist none
    slice 15  dist none
    slice 16  dist none
    slice 17  dist none
    slice 19  dist none
    slice 20  dist 1.91m
    slice 21  dist none
    slice 22  dist none
    slice 23  dist none
    slice 24  dist none
    slice 25  dist none
    slice 26  dist none
    slice 28  dist none
    slice 29  dist none
    slice 30  dist none
    slice 31  dist none
    slice 32  dist none
    slice 33  dist none
    slice 34  dist none
    slice 35  dist none
    slice  1  dist none
    slice  2  dist none
    slice  3  dist none
    slice  4  dist none
    slice  5  dist none
    slice  6  dist none
    slice  7  dist none
    slice  8  dist none
    slice 10  dist none
    slice 11  dist none
    slice 12  dist none
    slice 13  dist none
    slice 14  dist none
    slice 15  dist none
    slice 16  dist none
    slice 17  dist none
    slice 19  dist none
    slice 20  dist 1.91m
    slice 21  dist none
    slice 22  dist none
    slice 23  dist none
    slice 24  dist none
    slice 25  dist none
    slice 26  dist none
    slice 28  dist none
    slice 29  dist none
    slice 30  dist none
    slice 31  dist none
    slice 32  dist none
    slice 33  dist none
    slice 34  dist none
    slice 35  dist none
    voxl:~$ voxl-version
    system-image: 4.0.0
    kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
    hw platform:  VOXL
    mach.var:     1.0
    voxl-suite:   1.2.0
    Packages:
    Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-1.2/binary-arm64/
    Last Updated: 2024-06-28 07:54:15
    List:
    	apq8096-dfs-server          0.3.1
    	apq8096-imu-server          1.1.0
    	apq8096-libpng              1.6.38-1
    	apq8096-rangefinder-server  0.1.3
    	apq8096-system-tweaks       0.2.3
    	apq8096-tflite              2.8.3-1
    	libapq8096-io               0.6.1
    	libmodal-cv                 0.4.0
    	libmodal-exposure           0.1.0
    	libmodal-journal            0.2.2
    	libmodal-json               0.4.3
    	libmodal-pipe               2.10.0
    	libvoxl-cci-direct          0.2.1
    	libvoxl-cutils              0.1.1
    	voxl-camera-calibration     0.5.4
    	voxl-camera-server          1.9.2
    	voxl-configurator           0.5.6
    	voxl-cpu-monitor            0.4.8
    	voxl-docker-support         1.3.1
    	voxl-gphoto2-server         0.0.10
    	voxl-jpeg-turbo             2.1.3-5
    	voxl-lepton-server          1.2.0
    	voxl-libgphoto2             0.0.4
    	voxl-libuvc                 1.0.7
    	voxl-logger                 0.4.0
    	voxl-mavcam-manager         0.5.3
    	voxl-mavlink                0.1.1
    	voxl-mavlink-server         1.4.0
    	voxl-modem                  1.0.9
    	voxl-mongoose               7.7.0-1
    	voxl-mpa-to-ros             0.3.7
    	voxl-mpa-tools              1.1.5
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.5
    	voxl-qvio-server            1.0.2
    	voxl-remote-id              0.0.9
    	voxl-streamer               0.7.4
    	voxl-suite                  1.2.0
    	voxl-system-image           4.0-r0
    	voxl-tag-detector           0.0.4
    	voxl-tflite-server          0.3.2
    	voxl-utils                  1.3.9
    	voxl-uvc-server             0.1.6
    	voxl-vision-hub             1.7.4
    	voxl-vpn                    0.0.6
    voxl:/$ voxl-inspect-qvio
    waiting for server
     dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state||
       30.0 |    0.00    0.00    0.00|  -0.0   -0.1    0.1|    23  |  100% | OKAY |C
    closing and exiting
    voxl-inspect-cam qvio
    | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fpt
    ERROR: invalid metadata, magic number=88429860, expected 1448040524
    most likely client fell behind and pipe overflowed
    voxl-inspect-cam stereo
    |    stereo |  614400 |  640 |  480 |  5.07 |  125 |     8787 |     28.0  | 30
    voxl-inspect-cam tracking
    | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  t
    |  tracking |  307200 |  640 |  480 |  5.01 |  100 |    10838 |     12.3  | 3C
    voxl-inspect-cam tof
    |       tof |       0 |    0 |    0 |  0.00 |    0 |        0 |     25.4  |  8
    ERROR: invalid metadata, magic number=0, expected 1448040524
    Everything in Voxl Portal seems to be working as normal though.
    KrisK 1 Reply Last reply
    • KrisK Kris
      MAVROS / MAVSDK
      VIO
      en_vio:                     1
      vio_pipe:                   qvio
      MISC FEATURES
      OFFBOARD MODE
      follow_tag_id:              0
      en_voa:                     1
      voa_pie_slices:             36
      voa_input #0
          enabled:            1
          type:               point_cloud
          frame:              stereo_l
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #1
          enabled:            1
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #2
          enabled:            1
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #3
          enabled:            1
          type:               tof
          input_pipe:         tof
          frame:              tof
          max_depth:          6.000000
          min_depth:          0.150000
          cell_size:          0.080000
          threshold:          3
          conf_cutoff:        125
      voa_input #4
          enabled:            1
          type:               rangefinder
          frame:              body
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      starting mavlink IO
      new T imu wrt body:
      new R imu to body:
      Init complete
      ^C
      exiting VOA thread
      Removing PID file
      exiting
      MAVROS / MAVSDK
      VIO
      en_vio:                     1
      vio_pipe:                   qvio
      MISC FEATURES
      OFFBOARD MODE
      follow_tag_id:              0
      en_voa:                     1
      voa_pie_slices:             36
      voa_input #0
          enabled:            1
          type:               point_cloud
          frame:              stereo_l
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #1
          enabled:            1
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #2
          enabled:            1
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #3
          enabled:            1
          type:               tof
          input_pipe:         tof
          frame:              tof
          max_depth:          6.000000
          min_depth:          0.150000
          cell_size:          0.080000
          threshold:          3
          conf_cutoff:        125
      voa_input #4
          enabled:            1
          type:               rangefinder
          frame:              body
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      starting mavlink IO
      new T imu wrt body:
      new R imu to body:
      Init complete
      slice  1  dist none
      slice  2  dist none
      slice  3  dist none
      slice  4  dist none
      slice  5  dist none
      slice  6  dist none
      slice  7  dist none
      slice  8  dist none
      slice 10  dist none
      slice 11  dist none
      slice 12  dist none
      slice 13  dist none
      slice 14  dist none
      slice 15  dist none
      slice 16  dist none
      slice 17  dist none
      slice 19  dist none
      slice 20  dist none
      slice 21  dist none
      slice 22  dist none
      slice 23  dist none
      slice 24  dist none
      slice 25  dist none
      slice 26  dist none
      slice 28  dist none
      slice 29  dist none
      slice 30  dist none
      slice 31  dist none
      slice 32  dist none
      slice 33  dist none
      slice 34  dist none
      slice 35  dist none
      slice  1  dist none
      slice  2  dist none
      slice  3  dist none
      slice  4  dist none
      slice  5  dist none
      slice  6  dist none
      slice  7  dist none
      slice  8  dist none
      slice 10  dist none
      slice 11  dist none
      slice 12  dist none
      slice 13  dist none
      slice 14  dist none
      slice 15  dist none
      slice 16  dist none
      slice 17  dist none
      slice 19  dist none
      slice 20  dist 1.91m
      slice 21  dist none
      slice 22  dist none
      slice 23  dist none
      slice 24  dist none
      slice 25  dist none
      slice 26  dist none
      slice 28  dist none
      slice 29  dist none
      slice 30  dist none
      slice 31  dist none
      slice 32  dist none
      slice 33  dist none
      slice 34  dist none
      slice 35  dist none
      slice  1  dist none
      slice  2  dist none
      slice  3  dist none
      slice  4  dist none
      slice  5  dist none
      slice  6  dist none
      slice  7  dist none
      slice  8  dist none
      slice 10  dist none
      slice 11  dist none
      slice 12  dist none
      slice 13  dist none
      slice 14  dist none
      slice 15  dist none
      slice 16  dist none
      slice 17  dist none
      slice 19  dist none
      slice 20  dist 1.91m
      slice 21  dist none
      slice 22  dist none
      slice 23  dist none
      slice 24  dist none
      slice 25  dist none
      slice 26  dist none
      slice 28  dist none
      slice 29  dist none
      slice 30  dist none
      slice 31  dist none
      slice 32  dist none
      slice 33  dist none
      slice 34  dist none
      slice 35  dist none
      system-image: 4.0.0
      hw platform:  VOXL
      mach.var:     1.0
      voxl-suite:   1.2.0
      Packages:
      List:
      	libapq8096-io               0.6.1
      	libmodal-cv                 0.4.0
      	libmodal-json               0.4.3
      	voxl-libuvc                 1.0.7
      	voxl-logger                 0.4.0
      	voxl-mavlink                0.1.1
      	voxl-modem                  1.0.9
      	voxl-opencv                 4.5.5-2
      	voxl-portal                 0.6.5
      	voxl-streamer               0.7.4
      	voxl-suite                  1.2.0
      	voxl-utils                  1.3.9
      	voxl-vpn                    0.0.6
      waiting for server
      closing and exiting
      KrisK Offline
      KrisK Offline
      Kris
      I have also reverted the SDK to voxl_platform_0.9.5 and everything was working fine. It does not seem like a hardware issue. So I am wondering why the two newer SDK's are giving me issues with VIO and VOA.
      ModeratorM 1 Reply Last reply
      • KrisK Kris
        @Kris we would need a lot more information to provide an educated guess.
        Have you gone through the Troubleshooting VIO document? https://docs.modalai.com/flying-with-vio/#troubleshooting-vio
        Have you looked at the qvio_overlay?
        "unstable flight" could mean so many things. We recommend you break it down into smaller problems.
        1. how well does it fly in manual? Do the PX4 logs look good?
        2. how well does it fly with VIO?
        3. Does qvio_overlay indicate any issues?
        4. enable VOA, do things change?
        5. do the VOA diagnostic tools show anything?
        • ModeratorM Moderator
          KrisK Offline
          KrisK Offline
          Kris
          @Moderator
          Thank you for your reply,
          Yes, I have gone through the troubleshooting guides for VIO.
          Yes, I have looked at the qvio_overlay. It was actually one of the first things I did. Everything looked normal but then suddenly the point percentage would drop from 100% to 0% when the seeker was on the bench.
          1. The seeker performs as usualy in manual flight modes, otherthan the usual low stick throttle when trying to ascend.
          2. It will fly ok in VIO, the main problem is with VOA. I cannot even disable the VOA. After disabling VOA in voxl-vision-hub.conf, nothing changes in PX4. QGC says that VOA is still on and the Seeker does not move in any direction. When VOA is enabled, Obstacle distance remains at 2001,2001,2001,2001.... and does not change when I place my hand in front of the sensors on the Seeker. Then I will try to fly the Seeker with VOA enabled at 0.6 to 1 meter stopping distance, VOA does not work.
          3. qvio_overlay does not indicate any issues.
          4. Enabling and disabling VOA changes things but not in a good way as I mentioned above in #2 response.
          5. I posted the diagnostics of all these issues above in my first post.
          This only happens with voxl_SDK_1.1.0, 1.1.1, 1.1.2, and 1.2.0 releases.
          There are no problems with the voxl_platform_0.9.5 release.
          • KrisK Kris
            @Moderator
            KrisK Offline
            KrisK Offline
            Kris
            voxl:/$ voxl-list-pipes -t
            camera_image_metadata_t
            	dfs_disparity
            	dfs_disparity_scaled
            	qvio_overlay
            	stereo
            	tof_conf
            	tof_depth
            	tof_ir
            	tracking
            cpu_stats_t
            	cpu_monitor
            ext_vio_data_t
            	qvio_extended
            imu_data_t
            	imu0
            	imu1
            mavlink_message_t
            	mavlink_ap_heartbeat
            	mavlink_attitude
            	mavlink_from_gcs
            	mavlink_gps_raw_int
            	mavlink_local_position_ned
            	mavlink_onboard
            	mavlink_sys_status
            	mavlink_to_gcs
            point_cloud_metadata_t
            	dfs_point_cloud
            	tof_pc
            	voa_pc_out
            pose_vel_6dof_t
            	vvhub_body_wrt_fixed
            	vvhub_body_wrt_local
            string
            	gcs_ip_list
            text
            	horizon_cal_io
            tof_data_t
            	tof
            vio_data_t
            	qvio
            James StrawsonJ 1 Reply Last reply
            • KrisK Kris
              	dfs_disparity
              	qvio_overlay
              	stereo
              	tof_conf
              	tof_depth
              	tof_ir
              	tracking
              cpu_stats_t
              	cpu_monitor
              ext_vio_data_t
              	qvio_extended
              imu_data_t
              	imu0
              	imu1
              mavlink_message_t
              	mavlink_attitude
              	mavlink_from_gcs
              	mavlink_gps_raw_int
              	mavlink_onboard
              	mavlink_sys_status
              	mavlink_to_gcs
              	dfs_point_cloud
              	tof_pc
              	voa_pc_out
              pose_vel_6dof_t
              string
              	gcs_ip_list
              text
              	horizon_cal_io
              tof_data_t
              	tof
              vio_data_t
              	qvio
              James StrawsonJ Offline
              James Strawson
              @Kris I found and fixed a bug in voxl-camera-server that seems to be the culprit. I flashed my seeker with SDK1.2.0 and sideloaded the following voxl-camera-server with the bugfix to re-enable ingestion of TOF data into voxl-vision-hub
              404 Not Found
              favicon
              (voxl-packages.modalai.com)
              Note VOA simply does not work in the default PX4 acceleration-based position mode so MPC_POS_MODE needs to be set to 0 (velocity control) as done by the voa_enable px4 param helper file here:
              https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/dev/params/v1.14/voa_helpers/voa_enable_indoor.params?ref_type=heads
