  3. Sentinel segmentation fault after running voxl-uvc-server -v [camera id] -d
sentinel
30 Posts 4 Posters 9.8k Views 2 Watching
  • Róbert DévényiR Offline
    Róbert Dévényi
    I have bought the SIYI A8 mini gimbal camera and Sentinel perfectly detects it and I was able to stream video from it. Then, the next day something happened and since then I have been receiving this error: (the camera id is 534d, this is for certain)
    voxl2:~$ voxl-uvc-server -v 534d -d
    loading config file
    Enabling debug messages
    width: 640
    height: 480
    fps: 30
    pipe_name: uvc
    voxl-uvc-server starting
    Image resolution 640x480, 30 fps chosen
    Vendor ID 0x534d chosen
    UVC initialized
    Device 534d:0000 found
    Device opened
    uvc_get_stream_ctrl_format_size succeeded for format YUYV
    Streaming starting
    Segmentation fault:
    Fault thread: voxl-uvc-server(tid: 17803)
    Fault address: 0x7f9d661000
    Access to this address is not allowed.
    Segmentation fault
    So it seems that the camera is recognized perfectly fine, streaming is started but then a segmentation fault occurs.
    I would appreciate any help in this matter. I tried restarting the drone, the camera, killing the camera processing etc. hundreds of times, it seems that restarting / rebooting does not work
    and this is some persistent problem.
    Thanks for any help in advance.
    Róbert DévényiR Eric KatzfeyE 2 Replies Last reply
    • Róbert DévényiR Róbert Dévényi
      loading config file
      width: 640
      height: 480
      fps: 30
      pipe_name: uvc
      UVC initialized
      Device opened
      Streaming starting
      Segmentation fault:
      Segmentation fault
      Róbert Dévényi
      @Róbert-Dévényi the SDK version is 1.2.0 and voxl-uvc-server version is 0.1.6.
        loading config file
        width: 640
        height: 480
        fps: 30
        pipe_name: uvc
        UVC initialized
        Device opened
        Streaming starting
        Segmentation fault:
        Segmentation fault
        @Róbert-Dévényi That isn't a camera that we have available to try unfortunately. In our experience bringing up a new UVC camera usually involves a bit of work. Perhaps try a lower frame rate and see if that changes anything. Another idea is to stop all other services and just run voxl-uvc-server. Does it still crash?
        Róbert DévényiR 1 Reply Last reply
          Róbert Dévényi
          @Eric-Katzfey when I run voxl-uvc-server -f 15, 20, ... all lower frame rates give me the same seg fault. How can I stop other services from running?
            @Róbert-Dévényi You can use the voxl-inspect-services utility to see what services have been enabled. For each of those services you can either stop them or disable them. If you just stop them they will still start automatically on next reboot. If you disable them then you will have to re-enable them once you are done debugging. Stopping a service: systemctl stop <service name>, disabling a service systemctl disable <service name>.
            Róbert DévényiR 2 Replies Last reply
              Róbert Dévényi
              @Eric-Katzfey Thanks. Which services are the most likely to cause a segfault?
                Róbert Dévényi
                @Eric-Katzfey it seems that for some reason the voxl-uvc-server service just stops running by itself even after I run systemctl start voxl-uvc-server or systemctl enable voxl-uvc-server. Probably that causes the segfault, that the service is not running.
                  @Róbert-Dévényi Nothing should be causing a segfault. I'm just offering suggestions on how to debug what is going on.
                    @Róbert-Dévényi The service just runs the application.
                      Róbert Dévényi
                      @Eric-Katzfey so I stopped all services except for voxl-uvc-server:
                      Scanning services...
                      Service Name | Enabled | Running | CPU Usage
                      docker-autorun | Disabled | Not Running |
                      modallink-relink | Disabled | Not Running |
                      voxl-camera-server | Enabled | Not Running |
                      voxl-cpu-monitor | Enabled | Not Running |
                      voxl-dfs-server | Disabled | Not Running |
                      voxl-feature-tracker | Disabled | Not Running |
                      voxl-flow-server | Disabled | Not Running |
                      voxl-imu-server | Enabled | Not Running |
                      voxl-lepton-server | Disabled | Not Running |
                      voxl-mavcam-manager | Enabled | Not Running |
                      voxl-mavlink-server | Enabled | Not Running |
                      voxl-modem | Enabled | Not Running |
                      voxl-neopixel-manager | Disabled | Not Running |
                      voxl-open-vins-server | Disabled | Not Running |
                      voxl-portal | Enabled | Not Running |
                      voxl-px4-imu-server | Disabled | Not Running |
                      voxl-px4 | Enabled | Not Running |
                      voxl-qvio-server | Enabled | Not Running |
                      voxl-rangefinder-server | Disabled | Not Running |
                      voxl-remote-id | Disabled | Not Running |
                      voxl-softap | Disabled | Not Running |
                      voxl-static-ip | Disabled | Not Running |
                      voxl-streamer | Enabled | Not Running |
                      voxl-tag-detector | Disabled | Not Running |
                      voxl-tflite-server | Disabled | Not Running |
                      voxl-time-sync | Disabled | Not Running |
                      voxl-uvc-server | Enabled | Running | 0.0%
                      voxl-vision-hub | Enabled | Not Running |
                      voxl-wait-for-fs | Enabled | Completed |
                      And I am still getting the exact same segfault.
                        Róbert Dévényi
                        loading config file
                        width: 640
                        height: 480
                        fps: 30
                        pipe_name: uvc
                        UVC initialized
                        Device opened
                        Streaming starting
                        Segmentation fault:
                        Fault thread: voxl-uvc-server(tid: 16852)
                        Fault address: 0x7f7dda3000
                        Segmentation fault
                          Róbert Dévényi
                          @Eric-Katzfey I don't know if it helps but whenever I run voxl-uvc-server, the segfault happens and after that the voxl-uvc-server service stops running, but is still enabled.
                            @Róbert-Dévényi The service just runs the application. If the application stops then the service stops. Are you familiar with Linux and systemd? It's just a standard Linux startup mechanism. But you want to stop all services, even for voxl-uvc-server, then try to start voxl-uvc-server on the command line and see if it still segfaults. There are ways to debug segfaults. But you would need to understand how to get Linux to generate a core file after the segfault and how to load the core into gdb.
                              Róbert Dévényi
                              @Eric-Katzfey I would appreciate it if you could tell me what commands to use to stop all the services and then restart voxl-uvc-server or any resource that helps with debugging segfaults in general.
                                Róbert Dévényi
                                @Eric-Katzfey I reset all mpa services to factory settings and I keep getting the same segfault.
                                  Alex KushleyevA Online
                                  #16
                                  @Róbert-Dévényi ,
                                  You can stop the systemd service for voxl-uvc-server using the following command:
                                  systemctl stop voxl-uvc-server
                                  this will stop the service / server but will not prevent it from auto-starting during next reboot
                                  Then you can run the voxl-uvc-server in foreground. Just run it with the normal arguments:
                                  voxl-uvc-server <your additional arguments here>
                                  Confirm that this still crashes.. then run the same executable in gdb:
                                  > gdb /usr/bin/voxl-uvc-server
                                  (gdb) r <your additional arguments here>
                                  wait for crash...
                                  bt
                                  bt command in gdb will print the backtrace of the call stack and will tell you which function the seg fault happened in (and you will see the call stack). Maybe this will help with debugging.
                                    @Róbert-Dévényi ,
                                    wait for crash...
                                    bt
                                    Róbert Dévényi
                                    @Alex-Kushleyev Thank you very much hopefully I can figure it out.
                                      @Róbert-Dévényi ,
                                      wait for crash...
                                      bt
                                      Róbert Dévényi
                                      @Alex-Kushleyev I can probably show you the backtrace log so that you can take a look at what causes the segfault.
                                      A 1 Reply Last reply
                                        AndriiHlyvko
                                        @Róbert-Dévényi @Eric-Katzfey @Alex-Kushleyev I am getting the same seg fault with a boson+ camera. I determined that the seg fault occurs when the uvc_start_streaming function is called (I am running a modified version of voxl-uvc-server). I have the stack trace from gdb. If I figure out the cause of the problem I will post it here.
                                        (gdb) run
                                        Starting program: /usr/bin/voxl-uvc-server
                                        [Thread debugging using libthread_db enabled]
                                        Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
                                        VOXL UVC Server
                                        loading config file
                                        VOXL UVC Server parsed argument
                                        Image resolution 640x512, 30 fps chosen
                                        [New Thread 0x7ff7a7e1c0 (LWP 2189)]
                                        UVC initialized
                                        Device found
                                        [New Thread 0x7ff727d1c0 (LWP 2190)]
                                        Device opened
                                        Found desired frame format: 1
                                        uvc_get_stream_ctrl_format_size succeeded for format NV12
                                        bmHint: 0001
                                        bFormatIndex: 2
                                        bFrameIndex: 1
                                        dwFrameInterval: 333333
                                        wKeyFrameRate: 1
                                        wPFrameRate: 0
                                        wCompQuality: 0
                                        wCompWindowSize: 0
                                        wDelay: 0
                                        dwMaxVideoFrameSize: 491520
                                        dwMaxPayloadTransferSize: 983044
                                        bInterfaceNumber: 1
                                        [New Thread 0x7ff6a7c1c0 (LWP 2191)]
                                        [New Thread 0x7ff627b1c0 (LWP 2192)]
                                        [New Thread 0x7ff5a7a1c0 (LWP 2193)]
                                        Mavlink Onboard server Connected
                                        [New Thread 0x7fe70ef1c0 (LWP 2194)]
                                        Streaming starting
                                        [New Thread 0x7feffff1c0 (LWP 2195)]
                                        Thread 3 "voxl-uvc-server" received signal SIGSEGV, Segmentation fault.
                                        [Switching to Thread 0x7ff727d1c0 (LWP 2190)]
                                        __memcpy_generic () at ../sysdeps/aarch64/multiarch/../memcpy.S:185
                                        185     ../sysdeps/aarch64/multiarch/../memcpy.S: No such file or directory.
                                        (gdb) bt
                                        #0  __memcpy_generic () at ../sysdeps/aarch64/multiarch/../memcpy.S:185
                                        #1  0x0000007ff7ed32a0 in _uvc_process_payload () from /usr/lib/libuvc.so.0
                                        Backtrace stopped: previous frame identical to this frame (corrupt stack?)
                                        • A AndriiHlyvko
                                          (gdb) run
                                          VOXL UVC Server
                                          loading config file
                                          UVC initialized
                                          Device found
                                          Device opened
                                          bmHint: 0001
                                          bFormatIndex: 2
                                          bFrameIndex: 1
                                          wKeyFrameRate: 1
                                          wPFrameRate: 0
                                          wCompQuality: 0
                                          wCompWindowSize: 0
                                          wDelay: 0
                                          bInterfaceNumber: 1
                                          Streaming starting
                                          (gdb) bt
                                          #20
                                          @AndriiHlyvko , we have gotten another report about this recently. It seem there is a bug in libuvc which has been fixed, but we are using older version of the library.
                                          Inserting the following check at the line below has been reported to fix the issue:
                                          if (strmh->got_bytes + data_len > strmh->cur_ctrl.dwMaxVideoFrameSize) {
                                              UVC_DEBUG("Transfer too large and will overflow the buffer. Dropping data!");
                                              _uvc_swap_buffers(strmh);
                                              return;
                                          here: https://github.com/modalai/libuvc/blob/3fb2d2fd31f215f76bd5d6782785385fd0927ce5/src/stream.c#L757
                                          It seems the fix in the official libuvc release is here:
                                          https://github.com/libuvc/libuvc/blob/master/src/stream.c#L779
                                          https://github.com/libuvc/libuvc/blob/master/src/stream.c#L787
                                          We have not fixed this officially, please look at the code snippet i provided official fix and implement something similar until we fix it.
