  3. Switching between Mag+GPS and VIO indoors
vio
8 Posts 4 Posters 4.8k Views 1 Watching
  • Rowan DempsterR Offline
    Rowan Dempster
    wrote on last edited by Rowan Dempster
    Hi Modal,
    Cleo is looking into using Magnetometer+GPS combo for outdoor heading and positioning. We're wondering how Modal handles the switch between indoor and outdoor flight, specifically how does the EKF2 know when to stop fusing the magnetometer (definitely don't want to try to keep heading via mag inside)?
    Rowan
    • Cliff WongC Offline
      Cliff WongC Offline
      Cliff Wong
      Hi there, if you're using GPS+mag+vio then you'll need the following PX4 params changes in addition to our vio_gps_baro.params helper file:
      EKF2_MAG_TYPE = automatic (voxl default)
      EKF2_MAG_CHECK = 1 [or 2/3 for more sensitivity] (voxl default is 0)
      Having mag_check = 1 will activate EKF2's field strength checker such that as you proceed indoors should stop mag fusion completely when the field strength goes outside thresholds (hardcoded within PX4 ~ .4gauss variance). It's similar to GPS's DOP threshold where we expect both (gps and mag) to exceed the thresholds where PX4 will stop fusion of those modalities and eventually use vio solely.
      PX4's logic tries to maintain "smooth flight", so expect some delay/drift as it starts turning on/off the above (i.e. it will not be instant). Hence, adjust performance in those transitions, you'll need to modify ekf2's baro, gps, and mag *_GATE params accordingly.
      Note PX4 will adopt whatever heading is being derived from the activated sensors (GPS/Mag/vio) to construction its "global frame", so proceeding indoors you will still be operating under a global frame coordinate system (will still have a north reference based on last good mag/gps check).
      Rowan DempsterR 1 Reply Last reply
      • Cliff WongC Cliff Wong
        Rowan Dempster
        Hi @Cliff-Wong thank you for the response!
        In the version of PX4 that Modal is using (commit: https://github.com/modalai/px4-firmware/blob/b5c45bb232afc6a936b8349f4fa0be1efeb17707/src/modules/ekf2/ekf2_params.c) I see MAG_CHECK as:
         * Magnetic field strength test selection
         * When set, the EKF checks the strength of the magnetic field
         * to decide whether the magnetometer data is valid.
         * If GPS data is received, the magnetic field is compared to a World
         * Magnetic Model (WMM), otherwise an average value is used.
         * This check is useful to reject occasional hard iron disturbance.
         * @group EKF2
         * @boolean
        PARAM_DEFINE_INT32(EKF2_MAG_CHECK, 1);
        Do you suggest updating the EKF2 code to the more recent version that supports more advanced mag health checks:
        EKF2_MAG_CHECK:
              description:
                short: Magnetic field strength test selection
                long: 'Bitmask to set which check is used to decide whether the magnetometer
                  data is valid. If GNSS data is received, the magnetic field is compared
                  to a World Magnetic Model (WMM), otherwise an average value is used. This
                  check is useful to reject occasional hard iron disturbance. Set bits to
                  1 to enable checks. Checks enabled by the following bit positions 0 : Magnetic
                  field strength. Set tolerance using EKF2_MAG_CHK_STR 1 : Magnetic field
                  inclination. Set tolerance using EKF2_MAG_CHK_INC 2 : Wait for GNSS to find
                  the theoretical strength and inclination using the WMM'
              type: bitmask
              bit:
                0: Strength (EKF2_MAG_CHK_STR)
                1: Inclination (EKF2_MAG_CHK_INC)
                2: Wait for WMM
              default: 1
              min: 0
              max: 7
            EKF2_MAG_CHK_STR:
              description:
                short: Magnetic field strength check tolerance
                long: Maximum allowed deviation from the expected magnetic field strength
                  to pass the check.
              type: float
              default: 0.2
              min: 0.0
              max: 1.0
              unit: gauss
              decimal: 2
            EKF2_MAG_CHK_INC:
              description:
                short: Magnetic field inclination check tolerance
                long: Maximum allowed deviation from the expected magnetic field inclination
                  to pass the check.
              type: float
              default: 20.0
              min: 0.0
              max: 90.0
              unit: deg
              decimal: 1
        What we are worried about is the mag being used when the measurements are unhealthy.
        • Rowan DempsterR Rowan Dempster
           * @group EKF2
           * @boolean
          EKF2_MAG_CHECK:
                description:
                type: bitmask
                bit:
                  2: Wait for WMM
                default: 1
                min: 0
                max: 7
              EKF2_MAG_CHK_STR:
                description:
                    to pass the check.
                type: float
                default: 0.2
                min: 0.0
                max: 1.0
                unit: gauss
                decimal: 2
              EKF2_MAG_CHK_INC:
                description:
                    to pass the check.
                type: float
                default: 20.0
                min: 0.0
                max: 90.0
                unit: deg
                decimal: 1
          @Rowan-Dempster Mainline PX4 now works on VOXL 2. It hasn't received that much testing yet but you are welcome to try it out.
          S 1 Reply Last reply
            S Offline
            S Offline
            Sarika Sharma
            Hii @Eric-Katzfey we wanted to confirm whether ModalAI has a recommended parameter set or procedure to achieve a smooth transition between outdoor and indoor flight on VOXL 2 mini ??
            • S Sarika Sharma
              @Sarika-Sharma We have a variety of parameters sets available in the voxl-px4-params repo https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/ However, they are mostly for either indoor or outdoor use. Older versions of PX4, like what our fork is based off of, had a hard time with external vision based navigation coexisting with GPS based navigation. Newer versions of PX4, supposedly, are much better at this but we have not spent the time to prepare a parameter set for that yet. You are free to experiment with our mainline PX4 build here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mainline-px4_1.17.0-1.0.2-202602240859_arm64.deb. However, if you decide to use the mainline build, be aware that it is considered "experimental" at this point and has very little testing on voxl2 so use extreme caution.
                S Offline
                S Offline
                Sarika Sharma
                Hii @Eric-Katzfey ,
                I am trying to install the voxl-mainline-px4 package on a VOXL2 Mini (M0104) running VOXL SDK 1.6.3.
                The installation fails due to a dependency on a newer version of libfc-sensor.
                System information
                • Hardware: VOXL2 Mini (M0104)
                • SDK: 1.6.3
                • Installed library:
                libfc-sensor 1.0.9
                Command used
                sudo dpkg -i voxl-mainline-px4_1.17.0-1.0.2-202602240859_arm64.deb
                Error
                voxl-mainline-px4 depends on libfc-sensor (>= 1.0.10); however:
                Version of libfc-sensor on system is 1.0.9.
                Package metadata
                Running dpkg -s voxl-mainline-px4 shows:
                Depends:
                libfc-sensor (>= 1.0.10),
                voxl-px4-params (>= 0.3.10),
                voxl2-system-image (>= 1.5.4),
                modalai-slpi (>= 1.1.16)
                Repository check
                The SDK repository only provides:
                libfc-sensor 1.0.9
                apt-cache policy libfc-sensor
                Installed: 1.0.9
                Candidate: 1.0.9
                Question
                How to solve this issue???
                Thanks.
                • S Sarika Sharma
                  Hii @Eric-Katzfey ,
                  System information
                  • SDK: 1.6.3
                  libfc-sensor 1.0.9
                  Command used
                  Error
                  Package metadata
                  Depends:
                  Repository check
                  libfc-sensor 1.0.9
                  Installed: 1.0.9
                  Candidate: 1.0.9
                  Question
                  Thanks.
                  @Sarika-Sharma You can get v1.0.10 here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/libfc-sensor_1.0.10-202602041609_arm64.deb
