  2. Software Development
  3. ROS
  4. Issue with ROS2 set-up, Deserialization of UORB Topics
17 Posts 5 Posters 4.0k Views 1 Watching
  • J Online
    J Online
    jmltt
    I have a Sentinel running VOXL SDK v1.1.2. I installed ros2 foxy a while ago when the documentation linked to a bash script here to install it
    Link Preview Image
    GitHub - jetsonhacks/installROS2: Scripts to install ROS2 on the NVIDIA jetsons
    Scripts to install ROS2 on the NVIDIA jetsons. Contribute to jetsonhacks/installROS2 development by creating an account on GitHub.
    favicon
    GitHub (github.com)
    I'm running the mircodds agent and trying to listen to one of the PX4 topics (specifically vehicle_local_position) but I'm getting the same deserialization issue that was brought up here
    Link Preview Image
    Unable to subscribe to vehicle_command_position topic
    Hi @Moderator I have been trying to subscribe to vehicle_local_position ROS2 PX4 topic in my code but that wasn't working so I checked by echoing the topic d...
    favicon
    ModalAI Forum (forum.modalai.com)
    I thought I must have pulled the px4_msg repo from the main branch instead of the release/1.14 branch as mentioned in that thread, but I've deleted and reinstalled everything according to the documentation and still can't get it to work. I purged and reinstalled voxl-microdds and voxl-ros2-foxy from the offline suite. I even built voxl-mpa-to-ros2 from source and explicitly pulled the correct branches. Is this a known issue or am I doing something wrong?
    • J Online
      J Online
      jmltt
      wrote on last edited by jmltt
      I think I found the issue but not sure how to solve it.
      Every branch of voxl-mpa-to-ros2 that I've seen in the voxlSDK gitlab repo is pulling from the branch of px4_msgs @ a692ca42
      (see here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/tree/sdk-1.1.0/colcon_ws/src?ref_type=tags)
      which has one more variable in the message definition of VehicleLocalPosition.msg at line 42 than the message definitions included in all recent branches of the px4-firmware:
      float32 unaided_heading # Same as heading but generated by integrating corrected gyro data only
      Here's the message definition for the master branch of voxl-px4: https://github.com/modalai/px4-firmware/blob/b5c45bb232afc6a936b8349f4fa0be1efeb17707/msg/VehicleLocalPosition.msg
      Here's the message definition every branch of voxl-mpa-to-ros2 is linking to: https://github.com/PX4/px4_msgs/blob/a692ca426e35d8f5085979febc9065fe60907cb7/msg/VehicleLocalPosition.msg
      Not sure how many other messages this affects. Is this an easy fix on the dev side?
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        Hi @jmltt - will try and recreate the same issue you are seeing and the solution you proposed as a fix!
        If this is the case I will merge in a PR and it will be on the most recent dev branch for voxl-mpa-to-ros, anyways - will test out the solution soon.
        Zach
        J 1 Reply Last reply
          Zach
          J Online
          J Online
          jmltt
          @Zachary-Lowell-0 Sounds good, thank you!
            Zachary Lowell 0
            @jmltt said in Issue with ROS2 set-up, Deserialization of UORB Topics:
            So @jmltt it looks like this isnt necessarily an issue with the branch itself as mainline px4_msgs also has the unaided_heading in part of the VehicleLocalPosition:
            https://github.com/PX4/px4_msgs/blob/f90685f29174d4debfe31e22b4cf1412c3c16448/msg/VehicleLocalPosition.msg#L42C9-L42C24
            Trying to figure out a way to remove it without recreating a new submodule - will hopefully have a fix soon.
            Zach
              Zachary Lowell 0
              Ok @jmltt I fixed it - there was a giant conflict with versioning on px4_msgs and px4_ros_coms which was fun to deal with 🙂 - anyways I have a branch waiting for approval to be merged into the most recent nightly and you can then pull the dev from the apt repository when it gets merged in - until then feel free to rebuild voxl-mpa-to-ros2 deb and install on your voxl2 from the branch zach/submodule update: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/tree/zach/submodule_update
              Cheers!
              Zach
              Eric KatzfeyE J 2 Replies Last reply
                Cheers!
                Zach
                Eric KatzfeyE Online
                @Zachary-Lowell-0 The updated Debian package can be found here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mpa-to-ros2_0.0.3-202406240850_arm64.deb
                  Cheers!
                  Zach
                  J Online
                  J Online
                  jmltt
                  @Zachary-Lowell-0 Awesome, thanks for fixing this I really appreciate it!
                  T 1 Reply Last reply
                  • J jmltt
                    T Offline
                    T Offline
                    tahawaru
                    @Zachary-Lowell-0
                    I'm following the tutorial at https://docs.modalai.com/building-ros2-nodes/
                    I dont get the 's' for 'px4_ros_coms'.
                    Instead, I have 'px4_ros_com' which doesn't have an executable. So I get:
                    rb5:~/colcon_ws$ ros2 run px4_ros_com px4_ros_com
                    No executable found
                    Any help on this is welcome.
                      Zachary Lowell 0
                      Hi @tahawaru looks like its just a type on the documentation I will update it:
                      Please just try running ros2 run px4_ros_com px4_ros_com - no s anywhere in site. Note this package is fully managed by PX4 - not modalAI and can be followed here: https://github.com/PX4/px4_ros_com
                      LMK if this helps,
                      Zach
                        LMK if this helps,
                        Zach
                        T Offline
                        T Offline
                        tahawaru
                        @Zachary-Lowell-0
                        Still getting the same issue
                        No executable found
                          Zachary Lowell 0
                          @tahawaru said in Issue with ROS2 set-up, Deserialization of UORB Topics:
                          No executable found
                          @tahawaru why are you trying to run px4_ros_com's package in general? The package pertinent to voxl-mpa-to-ros2 is voxl_mpa_to_ros2 - what is it exactly you are trying to do?
                          T 2 Replies Last reply
                            No executable found
                            T Offline
                            T Offline
                            tahawaru
                            @Zachary-Lowell-0
                            I'm following this content https://docs.modalai.com/building-ros2-nodes/
                            After sourcing, and getting the "no executables found" error, I tried
                            rb5:~/colcon_ws$ ros2 pkg executables px4_ros_com
                            px4_ros_com debug_vect_advertiser
                            px4_ros_com offboard_control
                            px4_ros_com sensor_combined_listener
                            px4_ros_com vehicle_gps_position_listener
                              No executable found
                              T Offline
                              T Offline
                              tahawaru
                              @Zachary-Lowell-0
                              I'm having a similar error from running a ros2 command
                              rb5:~/colcon_ws$ ros2 run voxl_offboard_figure8 voxl_offboard_figure8
                              [INFO] [1723134293.283379373] [offboard_figure8_node]: Offboard Figure 8 Node Alive!
                              2024-08-08 16:24:53.442 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:53.950 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              [INFO] [1723134294.428290964] [offboard_figure8_node]: Switching to offboard mode
                              [INFO] [1723134294.428816835] [offboard_figure8_node]: Arm command sent
                              2024-08-08 16:24:54.452 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:54.951 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:55.452 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:55.961 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:56.461 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:56.971 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:57.482 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:57.988 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:58.488 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:58.998 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:24:59.507 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:25:00.016 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              2024-08-08 16:25:00.528 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
                              My Rb5 specs:
                              rb5:~/colcon_ws$ voxl-version
                              system-image: 1.7.1-M0052-14.1a-perf-nightly-20231025
                              kernel: #1 SMP PREEMPT Thu Oct 26 05:24:02 UTC 2023 4.19.125
                              hw version: M0052
                              voxl-suite:
                              Packages:
                              Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
                              Last Updated: 2024-07-19 09:01:43
                              List:
                              libmodal-cv 0.4.0
                              libmodal-exposure 0.1.0
                              libmodal-journal 0.2.2
                              libmodal-json 0.4.3
                              libmodal-pipe 2.9.2
                              libqrb5165-io 0.4.2
                              libvoxl-cci-direct 0.2.1
                              libvoxl-cutils 0.1.1
                              mv-voxl 0.1-r0
                              qrb5165-bind 0.1-r0
                              voxl-mavlink 0.1.1
                              voxl-mavlink-server 1.3.2
                              voxl-microdds-agent 2.4.1-0
                              voxl-modem 1.0.8
                              voxl-mongoose 7.7.0-1
                              voxl-mpa-to-ros 0.3.7
                              voxl-mpa-to-ros2 0.0.4
                              voxl-mpa-tools 1.1.3
                              voxl-neopixel-manager 0.0.3
                              voxl-opencv 4.5.5-2
                              voxl-portal 0.6.3
                              voxl-px4 1.14.0-2.0.63
                              voxl-px4-imu-server 0.1.2
                              voxl-px4-params 0.3.3
                              voxl-qvio-server 1.0.0
                              voxl-remote-id 0.0.9
                              voxl-ros2-foxy 0.0.1
                              voxl-streamer 0.7.4
                              voxl-tag-detector 0.0.4
                              voxl-tflite-server 0.3.1
                              voxl-utils 1.3.3
                              voxl-uvc-server 0.1.6
                              voxl-vision-hub 1.7.3
                              There is no response from the drone.
                              • T tahawaru
                                @Zachary-Lowell-0
                                My Rb5 specs:
                                hw version: M0052
                                voxl-suite:
                                Packages:
                                List:
                                libmodal-cv 0.4.0
                                libmodal-json 0.4.3
                                libmodal-pipe 2.9.2
                                libqrb5165-io 0.4.2
                                mv-voxl 0.1-r0
                                qrb5165-bind 0.1-r0
                                voxl-mavlink 0.1.1
                                voxl-modem 1.0.8
                                voxl-opencv 4.5.5-2
                                voxl-portal 0.6.3
                                voxl-streamer 0.7.4
                                voxl-utils 1.3.3
                                T Offline
                                T Offline
                                tahawaru
                                @tom
                                Hi Tom,
                                I have downloaded the src files from https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/tree/master/colcon_ws/src?ref_type=heads
                                Then I build with colcon build
                                The command "ros2 run voxl_offboard_figure8 voxl_offboard_figure8 " outputs the following while the rb5 is not responding at all
                                [INFO] [1727710160.087447748] [offboard_figure8_node]: Offboard Figure 8 Node Alive!
                                [INFO] [1727710161.215068375] [offboard_figure8_node]: Switching to offboard mode
                                [INFO] [1727710161.225198835] [offboard_figure8_node]: Arm command sent
                                [INFO] [1727710170.118029165] [offboard_figure8_node]: Doing figure 8 now
                                [INFO] [1727710183.178457539] [offboard_figure8_node]: Switching to land mode
                                Can someone update the short introduction to ROS2 usage with the rb5? Please.
                                @Zachary-Lowell-0
                                My Rb5 specs:
                                hw version: M0052
                                voxl-suite:
                                Packages:
                                List:
                                libmodal-cv 0.4.0
                                libmodal-json 0.4.3
                                libmodal-pipe 2.9.2
                                libqrb5165-io 0.4.2
                                mv-voxl 0.1-r0
                                qrb5165-bind 0.1-r0
                                voxl-mavlink 0.1.1
                                voxl-modem 1.0.8
                                voxl-opencv 4.5.5-2
                                voxl-portal 0.6.3
                                voxl-streamer 0.7.4
                                voxl-utils 1.3.3
                                • B Offline
                                  B Offline
                                  brahim
                                  @tahawaru there are a few intermediate steps to get ros2 offboard control:
                                  • disable offboard_mode (set to false) in voxl-vision-hub.conf line 237: "offboard_mode": "false"
                                  • Ensure voxl-microdds-agent is running. You can check by running systemctl status voxl-microdds-agent
                                  • Once these steps are complete, and you have the ros2 offboard fig 8 running, you should be able to echo the offboard control mode info either in an adb shell or mavlink console:
                                  In adb you can use the command px4-listener offboard_control_mode which should return this
                                      timestamp: 314055050 (0.031338 seconds ago)
                                      position: True
                                      velocity: False
                                      acceleration: False
                                      attitude: False
                                      body_rate: False
                                      actuator: False
                                  • A way to verify the figure 8 ros2 node is sending setpoints to px4 is to echo trajectory setpoints: ros2 topic echo /fmu/in/trajectory_setpoint
                                  • When you kill the ros2 offboard node, you can echo that offboard mode status again and the timestamp should go stale and no longer update.
                                  • B brahim
                                        position: True
                                        velocity: False
                                        acceleration: False
                                        attitude: False
                                        body_rate: False
                                        actuator: False
                                    T Offline
                                    T Offline
                                    tahawaru
                                    @brahim
                                    @tom
                                    Hi and sorry for the delayed response.
                                    Main result : no response from the rb5
                                    Comments: the offboard code example in cpp is running in Gazebo but I cannot get the drone to arm via ROS2 run px4_ros_com offboard_control.
                                    This is the output from my terminal
                                    ~/ros2_ws$ ros2 run px4_ros_com offboard_control
                                    Starting offboard control node...
                                    [INFO] [1729601421.989530505] [offboard_control]: Arm command send
                                    Notes: The offboard setting is "off" not "false" on the voxl-vision-hub.conf.
                                    Do you have a recent tutorial on how to use ROS2 with the rb5?
                                    Best wishes,
