  3. IO board for PWM output using the 4in1 ESC M0138-1
voxl-2-io
13 Posts 2 Posters 3.6k Views 1 Watching
  • R Offline
    R Offline
    restore
    @Alex-Kushleyev I would like to use the IO board to output a PWM for this camera trigger adapter. I do not need it to control motors as we are using the FPV 4in1 ESC.
    Can you please give me instructions on how to configure voxl and QGC to output the PWM? Do I need to upgrade the IO board firmware?
    • R restore
      @restore , Can you please clarify: are you planning to use an IO board (which one?) while also using the M0138 FPV ESC?
      Or are you asking whether the M0138 ESC board is capable of outputting standard PWM signals?
      R 1 Reply Last reply
        R Offline
        R Offline
        restore
        @Alex-Kushleyev yes I am looking to output standard PWM signals. We have the VOXL2 I/O expander board (MDK-M0065). We originally got it for RC connection but we’re also hoping to use the PWM capability for camera triggering.
        • R restore
          @restore , got it. Please check this doc: https://docs.modalai.com/voxl2-io-user-guide/
          You should definitely install the latest firmware for the M0065 and you probably want to use the following use case (Modal AI ESC in combination with M0065 pwm expander): https://docs.modalai.com/voxl2-io-user-guide/#voxl-2-io-sbus-input-and-4-in-1-uart-esc-output (even though it mentions RC input, you don't have to plug in the RC in order to use PWM output)
          Since you mentioned the RC.. if you use the M0065 board, you may not have room (UART ports) left to plug in the RC receiver, which means you will need to plug in the RC into M0065, which only supports SBUS (currently).
          If you provide more information regarding how you want to connect your RC, we can figure out the rest.
            R Offline
            R Offline
            restore
            @Alex-Kushleyev we are all good on the RC front. We have the PWM expansion board and are trying to understand how to configure QGC. In the actuators tab, the I/O board is recognized but in the VOXL2 IO output tab it only shows 4 pwm channels that are all set to motors (which we don’t need). How can we use one of the other channels or configure one of the first 4 to provide a standard PWM that we can use for our camera trigger interface?
            • R restore
              @restore , if you only see 4 pwm outputs in the VOXL2 IO tab, then you are using older version of PX4.
              We updated voxl2_io driver 2 months ago (commit to enable 8 channels. You need to use voxl-px4 version 1.14.0-2.0.70 or later. You will see the 8 actuators show in the picture here : https://docs.modalai.com/voxl2-io-user-guide/#sdk-130-1
              You also need to update the M0065 board firmware based on the instructions in voxl2-io-user-guide
              Then you will be able to use up to 8 channels and map them to any function just like a normal PWM output in PX4.
              Since you will still use VOXL ESC for motors and not connecting RC to M0065, then you would connect ESC to J18 and M0065 to J19 (pins 10,11 rx,tx) and you may have to modify your /usr/bin/voxl-px4-start script to start both the voxl_esc driver and voxl2_io driver, but latter with RC function disabled:
              # -e to disable RC input, -p 7 for DSP UART 7 (J19)
              qshell voxl2_io start -e -p 7
                R Offline
                R Offline
                restore
                @Alex-Kushleyev okay I upgraded px4 and updated the px4-start script - now see 8 pwm channels.
                I need to configure the camera trigger as shown in the image below (it is shown in mission planner and I am not sure how to do it in QGC)
                Can you please explain how I can configure the PWM output to trigger a shutter "pushed".
                • R restore
                  @restore ,
                  I am not sure about this one. This is a question specific to details of PX4 (not VOXL) and I don't think we've ever set up the trigger this way. You might want to try asking / searching the PX4 forums.
                  As long as you are able to map your trigger to any channels that you can select in QGC to map to PWM outputs, it should work.
                  By the way, does your camera require just one pulse to trigger or continuous pulses? If you wanted to set up VOXL2_IO in one pulse mode, that could be tricky, since it will run continuously, outputting the latest pulse values set by PX4 mixer.
                    @restore ,
                    R Offline
                    R Offline
                    restore
                    @Alex-Kushleyev Okay I can do some searching for how to setup the trigger.
                    For the camera trigger.
                    Neutral state is 1500 microseconds
                    To trigger the camera, change the duty cycle to yield 1200 microseconds and hold that for one second before switching back to 1500 microseconds
                    Is that something that can be done?
                    • R restore
                      @restore , yes sounds simple enough sequence. I am assuming px4 can generate that type of sequence, so voxl2_io driver will just execute. This is no different from sending out regular pwm signals, except the control signal is not coming from actuator mixer.
                        R Offline
                        R Offline
                        restore
                        @Alex-Kushleyev I am looking to enable the seagull trigger in camera interfaces as shown here , but I do not see that option. I see that the interface is in the modalai repo but how do I enable it to show up in QGC?
                        • R restore
                          R Offline
                          R Offline
                          restore
                          @Alex-Kushleyev I found that the parameters were just not used and once I set them with px4-param set PARAM_NAME param-value that they show up in QGC
                          One that I am still stuck on though. I am looking for a parameter TRIG_PINS that is not in the list of params in px4-param show -a
                          The default is 56 and I need to know how to map the pins to the PWM expansion board. From px4 documentation:
                          TRIGGER_INTERFACE = 2
                          "Enables the Seagull MAP2 interface. This allows the use of the Seagull MAP2 to interface to a multitude of supported cameras. Pin 1 of the MAP2 should be connected to the lower AUX pin of TRIG_PINS (therefore, pin 1 to AUX 5 and pin 2 to AUX 6 by default). In this mode, PX4 also supports automatic power control and keep-alive functionalities of Sony Multiport cameras like the QX-1."
                          • R restore
                            @restore , i don't think this module will work with VOXL2_IO because it seems the Seagull MAP2 interface expects direct connection to the I/O pins, which is not the case when using VOXL2_IO module.
