  3. Attempt to improve odometry using Opticalflow(&rangefinder)
2 Posts 1 Posters 471 Views 1 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hey @Eric-Katzfey, @James-Strawson @Tom-Kaufmann,
    I've been using Starling for quite a while. Congratulations on a great product.
    One of the things I noticed was that when using voxl-mapper for a significant time (like 15mins), the accumulated drift becomes a serious issue. I want to try and reduce the accumulated drift.
    An option to solve this issue is to use an OpticalFlow/Rangefinder with an external FC. I have completed this setup successfully. I can use my MAV in position mode with the fused odometry without issues. VOA works as well.
    I know from the docs and GitLab that voxl-mapper takes 2 inputs whub_body_wrt_fixed and tof. Is there a way to pass the fused odometry instead of whub_body_wrt_fixed? [ I want the mapper to use this data instead of whub_body_wrt_fixed]. The message type of the fused odometry is nav_msgs/Odometry.
    1. Will I need to modify the voxl-mavlink-server to achieve this?
    2. How do I get the mapper to use the fused odometry data?
    3. How do I synchronize these new position estimates and the pointcloud?
    I'm currently working on this project. So any suggestions or ideas will be instantly implemented, tested and reported back. i hope to hear from you.
    Thank you
    • Jetson NanoJ Jetson Nano
      Thank you
      Jetson Nano
      Veteran
      @Chad-Sweet, @James-Strawson, @tom any updates?
