  3. Voxl-suite disappeared on Starling
3 Posts 3 Posters 721 Views 1 Watching
  • V Offline
    V Offline
    viralp
    wrote on last edited by viralp
    Hey guys!
    I came across a strange anomaly last week on a starling drone I have. I was missing the voxl2 SDK version/ "voxl-suite" parameter as the drone boots up.
    e17b0b1c-a05d-44a1-b089-4e94828e8d39-Screenshot from 2024-05-17 08-54-49.png
    I remember, the week before I use to see "1.1.2" over there. The drone was still functioning and the voxl2 was not damaged in anyway. To move to a newer release I did an update and this is what happened.
    First I did a sudo apt update, followed by sudo apt-get upgrade.
    The output of the upgrade looked like below,
    I did as suggested, "sudo apt autoremove", and below is the list of pacRemoving qrb5165-dfs-server (0.2.0) ...
    Removing voxl-vision-hub (1.7.3) ...
    Removing voxl-camera-server (1.8.9) ...
    Removing libmodal-exposure (0.1.0) ...
    Removing libvoxl-cci-direct (0.2.1) ...
    Removing voxl-remote-id (0.0.9) ...
    Removing libmodal-journal (0.2.2) ...
    Removing qrb5165-rangefinder-server (0.1.1) ...
    Removing voxl-lepton-server (1.2.0) ...
    Removing voxl-elrs (0.1.3) ...
    dpkg: warning: while removing voxl-elrs, directory '/usr/share/modalai/voxl-elrs/tools' not empty so no
    t removed
    dpkg: warning: while removing voxl-elrs, directory '/usr/share/modalai/voxl-elrs/esptool/esptool/target
    s' not empty so not removed
    Removing voxl-esc (1.3.7) ...
    dpkg: warning: while removing voxl-esc, directory '/usr/share/modalai/voxl-esc-tools' not empty so not
    removed
    Removing qrb5165-imu-server (1.0.1) ...
    Removing voxl-qvio-server (1.0.0) ...
    Removing voxl-utils (1.3.3) ...
    Removing qrb5165-system-tweaks (0.2.3) ...
    Removing voxl-tflite-server (0.3.1) ...
    Removing qrb5165-tflite (2.8.0-2) ...
    Removing voxl-bind-spektrum (0.1.0) ...
    Removing voxl-camera-calibration (0.5.3) ...
    Removing voxl-configurator (0.4.8) ...
    Removing voxl-portal (0.6.3) ...
    Removing voxl-cpu-monitor (0.4.7) ...
    Removing voxl-docker-support (1.3.0) ...
    Removing voxl-flow-server (0.3.3) ...
    Removing voxl-feature-tracker (0.3.2) ...
    Removing voxl-gphoto2-server (0.0.10) ...
    Removing voxl-logger (0.3.5) ...
    Removing voxl-jpeg-turbo (2.1.3-5) ...
    Removing voxl-libgphoto2 (0.0.4) ...
    Removing voxl-uvc-server (0.1.6) ...
    Removing voxl-libuvc (1.0.7) ...
    Removing voxl-mavcam-manager (0.5.3) ...
    Removing voxl-mavlink (0.1.1) ...
    Removing voxl-mavlink-server (1.3.2) ...
    Removing voxl-modem (1.0.8) ...
    Removing voxl-mongoose (7.7.0-1) ...
    Removing voxl-mpa-to-ros (0.3.7) ...
    Removing voxl-neopixel-manager (0.0.3) ...
    Removing voxl-tag-detector (0.0.4) ...
    Removing voxl-px4-imu-server (0.1.2) ...
    Removing voxl-streamer (0.7.4) ...
    Removing libmodal-cv (0.4.0) ...
    Removing libqrb5165-io (0.4.2) ...
    dpkg: warning: while removing libqrb5165-io, directory '/usr/local/lib/python3.6/dist-packages' not emp
    ty so not removed
    Removing voxl-mpa-tools (1.1.3) ...
    Removing librc-math (1.4.2) ...
    Removing voxl-opencv (4.5.5-2) ...
    kages that were removed;
    After this, the voxl2 looks like below,
    I flashed the voxl2 with the latest SDK to revive it but in the process I lost a few setup files and containers I had installed on the drone for my work. I had to redo the setup of the drone and now everything looks operational but still it would be good to know if anybody has any ideas why the "voxl-suite" would become blank in the first place.
    • C Offline
      C Offline
      c0u1r
      I have a question and the same problem that occurred with @viralp .. Can the members here help or provide the best solution? thank you friends.
      • V viralp
        Hey guys!
        t removed
        removed
        ty so not removed
        @viralp Behind the scenes "voxl-suite" is really just a meta package with dependencies on all of the debian packages in VOXL Suite.
        Therefore if any of the packages that voxl-suite depends on are modified (either removed or downgraded) then "voxl-suite" will no longer be installed.
        This includes the system image. Contained in the system image is another meta package called voxl2-system-image which is versioned the same as the System Image. Therefore if there is a system image / voxl-suite mismatch you will see the same effect.
        This isn't a major issue, it just means that you are straying from the exact package list defined by that version of VOXL Suite.
        If you would like to get to a known good state you download the latest SDK from our downloads page and install it with it's install.sh script
