  2. VOXL SDK and Software
  3. MAVSDK example program on VOXL 2 not running
voxl-sdk
2 Posts 2 Posters 746 Views
  • A Offline
    achanana
    wrote on last edited by achanana
    I am working with the Starling (QRB5165 VOXL 2 running sdk-1.2.0). I am trying to follow the voxl-docker-mavsdk-cpp tutorial to get the takeoff and land script to work.
    I was able to get the docker server running and pulled the MAVSDK image. However, I get the following error when trying to execute the takeoff and land script:
    root@m0054:/home/MAVSDK/examples/takeoff_land#  ./takeoff_and_land udp://:14551
    [03:15:33|Info ] MAVSDK version: 0.28.0 (mavsdk_impl.cpp:26)
    [03:15:33|Debug] New: System ID: 0 Comp ID: 0 (mavsdk_impl.cpp:377)
    Waiting to discover system...
    No system found, exiting.
    This is the output I got from voxl-inspect-services:
    voxl2:~$ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  |   Running   |    90.9%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.4%
     voxl-imu-server          |  Enabled  |   Running   |     3.8%
     voxl-mapper              | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     2.6%
     voxl-neopixel-manager    | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.7%
     voxl-px4-imu-server      |  Enabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    24.6%
     voxl-qvio-server         |  Enabled  |   Running   |    34.3%
     voxl-softap              |  Enabled  |  Completed  |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-tflite-server       |  Enabled  |   Running   |     3.1%
     voxl-vision-hub          |  Enabled  |   Running   |     2.6%
    Do you have any idea what might be the issue here? Should voxl-px4-imu-server be running? Could that be the issue?
    Thanks for your help!
    • ModeratorM Offline
      @achanana said in MAVSDK example program on VOXL 2 not running:
      voxl-px4-imu-server
      is for the Qualcomm Flight RB5 architecture and is not relevant to Starling
      It is likely your voxl-mavlink-server is not configured properly. MAVSDK communicates with the port opened up in voxl-mavlink-server
